Old 07-17-2019, 11:24 AM   #1
2013 27' FB International
Calgary , Alberta
Localized Peeling of Clear Coat
I have a Serenity 27fb in relatively new condition and have recently noticed that there are 2 quarter-sized areas that are peeling on 2 seperate panels? They seem to be in 2 random spots.
1) Is it normal that the clear coat should start peeling in a localized area? The surrounding areas appear to be perfect. Perhaps from Hail strike?
2) Is it common to see this happening on such a (relatively) new trailer?
3) Is there a way to spot patch these 2 spots to prevent it from spreading?
4) What are you using to coat other scratches?
I have searched the forums and the suggestions are to remove the clear coat, and polish, but this suggestion seems to be for older trailers where the coating in failing across large areas. I don't think this trailer is ready to have the coating stripped yet.
danton is offline   Reply With Quote
Alcoa clear coat peeling wponder Exterior Restoration Forum 14 06-13-2019 03:57 PM
Living with peeling clear coat? timmaah Clearcoat, Exterior Paint & Trim 14 04-26-2011 09:20 PM
Clear Coat Peeling lsmith Clearcoat, Exterior Paint & Trim 24 04-20-2010 06:58 AM
Clear Coat(?) on Rear Bumper Peeling/flaking IrishRover2 Cleaning, Stripping & Polishing 3 01-02-2008 04:48 PM
