10-06-2015, 12:51 PM
houston
LED Lights... Too blue?? Harsh in the morning...
We've had our '15 intl serenity now for a while, and what I've learned is that the lights inside are harsh... especially in the morning.
They are like.. very blue or something - zero warmth to them, and if you get up before the sun comes up and start flicking on lights - it's just weird.
I'm wondering if this bothers anyone else? And I'm wondering what you might have done about it?
'15 27fb Signature
'12 Chevy 2500HD Gasser
10-06-2015, 01:02 PM
2005 30' Classic
Burlington
, Ontario
Depending on the specifics of the LED bulbs in your trailer, if it is a real concern to you, you should be able to replace them with LED's having a warmer colour temperature.
Probably worth experimenting with a replacement bub before you buy a whole bunch in order to get one that suits you.
Here is info on colour temperatures.
Choosing Color Temperature
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
10-06-2015, 02:14 PM
1974 Argosy 20
Kooskia
, Idaho
The ones supplied by Airstream are, in my opinion, way too "cold" that is too blue white, especially when used with all the shiny aluminum interior walls. I believe that they are in the range of 3500 to 4000 k in color temp. An incandescent light and most halogen lights are in the 2700 to 3000 k range, much "warmer" in that they are yellower and not as blue.
Like you, I disagree with Airstream's choice. The only real way to change it is to replace the lights themselves. Some may recommend color filtering gel's but they simply take out more light and make the fixtures less efficient.
You might look at my post on using household 120 volt LED bulbs for a nice warm home like look, at low cost and low energy cost.
http://www.airforums.com/forums/f447...am-126542.html
10-06-2015, 04:24 PM
Wise Elder
2010 30' Classic
South of the river
Color temperature and color rendition matter greatly to some people but don't seem to bother most.
Poor color from the lights absolutely drives me up the wall. My trailer predates the LED era having been made in 2010. It has fluorescent lights. The originals had a blue cast, and after quite a bit of searching I found some that have a more natural color.
Not sure quite what to suggest for your LEDs, other than replace them. $$$
10-06-2015, 06:29 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Always found that the Warm White for indoors, Bright White for outdoors, both from DAN, have worked very well for us over the years...
10-07-2015, 10:49 AM
Proud Owner Vintage SBB
Santa Monica
Color temperature
Cool, blue, or daylight LEDs have more light output than warm. Warm (color) lamps create more contrast with ambient daylight, which I think is a good thing, but some would want to attenuate. My trailer is dark inside so I run my 12vdc LEDs -- all the lights in the trailer -- during the day, even boon docking. All the lighting, including the LED ribbon lights inside the upper cabinets (which are on a micro switch) total fewer than 35watts at 12VDC. And they are all warm as measured in Kelvin.
Michael
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
– Sir Richard Francis Burton
10-07-2015, 11:14 AM
I also have a 2015 International Serenity. All the LEDs except the 2 lights with lamp shades are on the cool side. The interior design of the International Serenity is bright with the exposed aluminum skin and the light reflective cabinets. I believe that's why the interior designers choose a cool LED. As a professional photographer, I am always dealing with light temp. and I like the cool LEDs
10-07-2015, 11:24 AM
2004 22' Safari
Albuquerque
, New Mexico
I replaced all of my non-LED lights (2004 Safari) with warm LEDs from M4 Products (M4products.com) and although it was not cheap, the lights are almost identical to the non-LED as far as color. Initially I replaced the first bulb in the set of two on each fixture. When I saw the color matched, I replaced the remaining ones. I find the blue depressing.
10-07-2015, 11:39 AM
belen
, New Mexico
That is the reason I would NOT buy a new motorhome as they all come that way and being a migraine sufferer makes me way sensitive to that light for some reason!
In my opinion.
10-07-2015, 12:41 PM
2012 25' Flying Cloud
San Antonio
I agree that the Warm White is much more acceptable inside. Like stated above order a few from Led4Rv from Dan and try them out.
10-07-2015, 01:25 PM
2006 19' Safari SE
Tucson
Try putting photo gels in various colors in the lenses to soften the lights...lots cheaper than new bulbs... and you can figure out what works for you without the expense...then you can always replace the bulbs later. (We personally now like the bright white lights, though admittedly, it did get some getting used to.)
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
10-07-2015, 02:04 PM
2010 28' Flying Cloud
Slidell
, Louisiana
Converted all lights in our 2010 FC to warm LED, didn't like at all, then converted the warm to bright daylight (6500). Love it now.
10-07-2015, 02:44 PM
1978 31' Excella 500
Genoa
, Nevada
I bought some 12V LED bulbs at Batteries+Bulbs, I can't tell them from the old original bulb. Have to remember which ones are the new LED. Spendy though, at $20 a 200 lum bulb.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
10-07-2015, 03:01 PM
2015 25' FB Flying Cloud
Eugene
, Oregon
My family and I also didn't like the cool blue LEDs that come with the trailer. But many folks do like them. Definitely a personal preference. But you have plenty of company .
I too worked with Dan at LED4rv to swap out bulbs and fixtures. He is a good man. dan@led4rv.com
Good luck!
10-07-2015, 10:27 PM
Santa Monica
What's funny to me, funny odd, not hah hah, is Airstream cannot be bothered to build their trailers with color-changing LEDs. In other applications I have used, for more than twenty years, RGB LED clusters -- Red, Green, & Blue -- with which one can dial from warm to cool, with simple ease, precise selection. With 256 of each color, one can produce more than 16 million colors. What's more, for more than twenty years this technology has been programmable to cross fade from, say, a preselected "daylight blue" cool color temperature to an "incandescent lamp" warm color temperature.
In fact, for fewer than two hundred bucks, one can replace the MR-16 lamps in their track lighting with RGB LED lamps that can be controlled (as just described) with one's smartphone.
Yawn,
Michael (retired film lighting gaffer)
10-07-2015, 11:13 PM
2019 25' International
Traverse City
, Michigan
Yawn,
I think "mic drop" would fit better here than "yawn" 😉
Oh, can you give us the source for the controllable RGB LED lamps?
"Don't let perfect be the enemy of better."
10-08-2015, 10:59 AM
houston
I'm glad I'm not alone, thanks for all the advice!
'15 27fb Signature
10-08-2015, 11:51 AM
Santa Monica
Apple and Philipps collaborated on a 3-pack available everywhere <http://tinyurl.com/o3an5lj> A a start-up, Color Kinetics, was acquired by Phillips (for $800 million) <
10-08-2015, 12:23 PM
Lower Alabama
, USA
I found the cheaper bulbs were typically more blue. I sorted through three rounds of purchases and then landed with a supplier and a color that I liked.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
