06-28-2015, 09:04 PM
2015 25' FB International
Leaking Under Sink
Our under sink in-line water filter just started leaking water the other day. Like someone loosened the fitting for a practical joke. I replaced the filter with the winterizing bypass hose and the leak stopped. Then again this morning a slight leak which I simply tightened down more and nothing has happened today. Water supply connected at all times...
Anyone have any thoughts of have experienced this? I have such weird problems...
06-28-2015, 09:05 PM
PS- And it has me wondering what else might be leaking outside my line of sight.
06-28-2015, 09:16 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I had similar problems with our 2012 23FB and our 2015 25FB. In both Airstreams we had water leaks at the filter and by-pass tube connections. I have found from experience that you have to be very careful to make sure that the gasket at the connections are straight and properly seated.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
06-29-2015, 04:41 AM
Interesting. Well once the season is over I may just plan to bypass the bypass then! All those 90's in there to accommodate that filter seem like a bad idea anyway. Thanks for the reply.
06-29-2015, 08:23 AM
2017 25' International
Carlsbad
FYI, 2015 27FB
My filter is bypassed and last weekend we developed a leak too. I could not find its origin. She's going in for warranty work in 3 weeks, maybe they can find it.
06-29-2015, 09:54 PM
Mine is definitely coming from the fitting that lets you screw on and off the water filter. The one closer to the front. It might be a deteriorating gasket but at 6 months old I find this very odd.
07-01-2015, 02:02 PM
Lotus
2016 27' International
Nebo
, North Carolina
In line filters are trouble for leaks. The vibration of travel can loosen even a tight connection.
07-01-2015, 02:05 PM
Lotus
Nebo
, North Carolina
Remove the filter entirely. If you need a filter use one at your hydrant city water connection where it will be outside and easy to connect at each place you stay.
07-02-2015, 08:10 PM
Yeah, I ordered and installed a Camco in line filter for outside. I cinched down the fittings on the under sink bypass as hard as I dare go. No water in three days, knock on wood. Lousy design under there for sure. Thanks all!
12-18-2015, 09:57 PM
1Boyscout
2015 28' International
Edmond
, Oklahoma
My leak was from the blacktank backflush valve leaking, fixed under warranty.
12-18-2015, 10:19 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Under sink leaks
All of the plumbing around the elbow of a sink is hand tightened - and on an RV that can vibrate loose. About every six months you need to re-tighten the drains.
They can't be glued because you may need to clean out hair, other clogs - or find that missing diamond from your engagement ring... so hand tightened is functional.
Paula
12-18-2015, 10:42 PM
2007 22' International CCD
Corona
A careful coating of plumbers putty will help keep things tight and leak free
12-19-2015, 10:57 AM
Carlsbad
There is also teflon in a tube that's safe for pvc and it doesn't set up like glue(@HD) I've used it at home and in other plumbing repairs. I too had a little leak under AS sink. Hand tighten and check when I think of it.
