07-24-2016, 04:54 PM
2016 27' International
Montreal
, Quebec
Is this suppose to look like this
Can anyone tell me what this is. I had never paid attention to this but today as I was lowering the stabilizer jack I just noticed this and I am not really sure what this is.
07-24-2016, 04:57 PM
1991 25' Excella
Stanfield
, Oregon
Looks like a propane line that someone has modified
07-24-2016, 05:09 PM
Retired.
, At Large
That is a ground wire.
07-24-2016, 05:11 PM
1992 25' Excella
Orange County
, New York
Someone attached a ground clamp and ground wire to your propane line.
07-24-2016, 05:15 PM
2012 27' Flying Cloud
W
, New England
The factory?
07-24-2016, 05:16 PM
Montreal
, Quebec
Thanks. Since this is a brand new AS I was curious to find out if is suppose to come like this from the factory. I find it strange that they run that gaz line like that.
07-24-2016, 05:17 PM
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
That is a grounding clamp for electrical grounding clamped to a copper pipe. If that pipe is a LP line, grounding to it is dangerous. If it is a water pipe it's not dangerous. I have never seen an RV electrical system grounded to the water lines but not sure how the electrical system in your unit is grounded.
Judging a person does not define who they are, it defines who YOU are.
07-24-2016, 05:22 PM
1992 25' Excella
Orange County
, New York
Originally Posted by SteveSueMac
The factory?
It probably was, I have one in almost the same spot
07-24-2016, 05:23 PM
Oswego
My understanding is that using the copper line as THE common ground is bad, but grounding the line to the frame is done in trailers where the line is insulated from the chassis. Mine has a ground wire from the line to the chassis, but I can't recall where it is ....and it s pouring rain right now.
-Rich-
07-24-2016, 05:31 PM
Port Orchard
How about "its a ground wire to ground the propane line to the frame to protect it from a static build up causing an arc and blowing up the trailer".
That my guess.
Ken
07-24-2016, 05:42 PM
1992 25' Excella
Orange County
, New York
Mine is run right to the chassis, via the mounting bracket for the stabilizer.
07-24-2016, 05:43 PM
Oswego
Same location as yours
-Rich-
07-24-2016, 05:51 PM
2007 22' International CCD
Corona
I would bet it's a safety ground to bond the propane line to the rest of the AS for safety. My electrical panel ground bonding clamp is on the frame near the rear of the AS.
I don't think my propane lines are covered like that, but it's a good idea to prevent rock damage. Hm. Something else to look into....
07-24-2016, 05:58 PM
Walnut Creek
There are several models that route the LPG line in this way. We found the configuration while kicking back to relax on our first overnight and asked our dealer. Answer was "That's the way they do it." We did ask the folks on the factory tour and got a "I don't know." There has got to be a better route for a gas line. Pat
07-25-2016, 06:11 AM
Montreal
, Quebec
Thanks everyone, haapy to find out it is suppose to be like that .
07-25-2016, 11:02 AM
beloit
, Wisconsin
why would you route a gas line lower than the frame? This can snag on just about everything. grounding to a gas line is also very bad idea.
07-25-2016, 11:12 AM
Montreal
, Quebec
Whether you are right or wrong this is how Airstream does it.
07-25-2016, 11:18 AM
1992 25' Excella
Orange County
, New York
"why would you route a gas line lower than the frame? This can snag on just about everything. grounding to a gas line is also very bad idea."
There are other items like the stabilizer that are lower and would hit the ground first.
07-25-2016, 11:42 AM
Oswego
I believe code requires them to be on the exterior, except for the pass-through in the floor near the appliance. Inside the belly (higher than frame) would be a code violation.
Also, this configuration is not "grounding TO a gas line". It is grounding THE gas line TO the frame, in order to dissipate any potential static charge buildup as gas moves through the line.
-Rich-
07-25-2016, 11:47 AM
Port Orchard
This is not grounding to a gas line. This is grounding of a gas line to the trailer ground. This is done so that static charge cannot build up on the line
I believe that the gas line is routed under the trailer so that in the event of a leak, the gas will dissipate. If the gas line were routed either in the belly pan or worse within the trailer, any tiny leak would cause gas to accumulate until some ignition source like a static discharge ignited it and blew the trailer into little tiny bits. In the best case scenario, the occupants would die peacefully in their sleep from suffocation before the trailer exploded.
There was a tragic story a few miles away from me a couple months or so ago. A small propane leak developed in propane pipes inside a mobile home. The gas expanded until it found an ignition source. The ensuing explosion killed both occupants and blew pieces of the mobile home up to a 1/4 mile away.
Ken
While I was composing this. (I take a while for correcting typing errors) Rich posted essentially the same response, However, without as much drama.
