Old 07-05-2017, 01:23 PM   #1
2015 25' FB International
Reno , Texas
How to keep sliding cabinet doors closed?
When traveling our sliding cabinet doors slide open and contents fall out. Any ideas or devices to use to prevent this?
AS2015Ser is offline   Reply With Quote
Old 07-05-2017, 01:28 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
One way to reduce the "things fall out" part is with spring loaded curtain rods. They are dirt cheap at just about any "home goods" store.
Depending on exactly how your sliding cabinet doors are done, something in the track is generally the first thing to try.
Old 07-05-2017, 02:23 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I put a magnetic catch on each panel of the sliding doors on our bathroom cabinet. Works well.
2019 Ford Expedition Platinum
Old 07-05-2017, 02:34 PM   #4
2007 22' International CCD
We have the sliding plastic panels with finger holes in both ends. A properly sized rubber cork in one of the center holes stops casual opening on the road neatly.
rmkrum is online now   Reply With Quote
Old 07-05-2017, 10:27 PM   #5
2016 28' International
2010 25' FB Flying Cloud
Grand Rapids , Michigan
We painted some 1/2 inch dowels gray with a hard clear coat that sit in the tracks of both sliding doors. We just tuck them inside the cabinet once we arrive and pull them back out before we depart.
I'll try to post some pictures tomorrow.
ArkFortyCal is offline   Reply With Quote
Old 07-06-2017, 11:34 AM   #6
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
1/2" Plastic PEX tubing also works in the same way to keep the doors from sliding open.
Greg
greghoro is offline   Reply With Quote
Old 07-06-2017, 11:44 AM   #7
MsRivet's Avatar
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland , Florida
Send a message via Yahoo to MsRivet
Champagne corks worked for us! And just a small piece of paper towel wedged between the medicine cabinet doors.
ID:	288843   Click image for larger version
MsRivet is offline   Reply With Quote
Old 07-06-2017, 11:52 AM   #8
2017 25' International
Framingham , Massachusetts
Take half of a wooden clothes pin. Slide between door panels. Acts as a little wedge to keep sliding doors closed for me.
quietguy is offline   Reply With Quote
Old 07-06-2017, 01:50 PM   #9
Didn't consider a clothes pin wedge! Also a good simple but effective idea.
Corks in the holes have a slight advantage in probably not causing scratches. The champagne cork looks decorative as well
Old 07-06-2017, 03:30 PM   #10
Toaster Life
2008 23' International
Chicago , Arizona
I took a thin sock, put some coins in the toe and tied off the toe. Then added a wine cork and tie off again with some string. You can be fancy and chose the sock color and string to match/ contrast your decor. When getting ready to travel, line up the holes and push the weighted coins through the lined up holes, with the sock covered cork fitting snuggly in the 2 lined up holes. These have stayed in place throughout bumpy roads, and the weights help them stay in place. We bungee cord the kitchen sink and other paired cabinet doors with minature bungees too.
Toasterlife is offline   Reply With Quote
Old 07-06-2017, 04:38 PM   #11
rogerdog1's Avatar
2013 25' FB International
Littleton , Colorado
I cut a 1/4" dowel, tapered it a bit, and drilled holes opposite each other, in both sliding doors, near the bottom of the doors. Takes a little tweaking, but works well, and is inconspicuous. Put a little key spring thru a small hole drilled in the end of the dowel, which helps to remove the dowel, and can be swiveled & tucked behind the aluminum trim, to keep the dowel from falling out.
rogerdog1 is offline   Reply With Quote
Old 02-21-2018, 05:49 PM   #12
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
We had a problem with the upper locker cabinet doors sliding in our 2005 International. It had 3 panels, some time later Airstream changed it to 2 panels. We bought the 1 tapered black rubber stoppers at Home Depot and pushed them in the finger holes to keep the doors from sliding.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Wardrobe Doors - To Keep or Not To Keep? Rhino33 General Interior Topics 2 10-07-2015 03:34 PM
Upper cabinet sliding doors Grand Master Cabinets, Counter Tops & Furnishings 12 01-08-2010 09:00 PM
cabinet sliding doors jimden Cabinets, Counter Tops & Furnishings 4 02-19-2009 08:01 PM
Need info on sliding cabinet doors in 2004 Safari 1911dan Cabinets, Counter Tops & Furnishings 2 10-03-2008 09:16 PM
