Old 09-29-2017, 12:13 AM   #1
Krisanne's Avatar
Minneapolis , Minnesota
Hot water pump light
My light stays constantly on, if I am in electric or gas power. It use to just flicker when turned on. Now after about 4 hours the red light comes on and stays at n. I believe that shouldn't be the case
Krisanne
Krisanne is offline   Reply With Quote
Old 10-10-2017, 11:54 AM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
Constant red light means it is not working, do you have hot water after the 4 hrs when the light comes on? it should flicker for a split second when first turned on and then you should not see a light if everything is happy.
vintagemotor is offline   Reply With Quote
Old 10-10-2017, 12:12 PM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
It is not a pump, but the water fault light. It indicates proper function of the propane part of the water heater, and has nothing to do with the AC electrical heating element.
It should light briefly when the switch is turned on. Ons should be able to hear the burner click and ignite, then the light should go dark.
If the lamp stays on, the burner has failed to light and/or stay lit.
Are you out of propane?
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
being frugal with hot water — best ways to manage hot water cost lbdesign Full-Timing, Winter Living & Workamping 23 12-17-2015 09:14 AM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
