Old 10-24-2015, 03:46 PM   #1
2014 23' International
Lohman , Missouri
Help-Pump inlet Port
Its a sad day........putting up our Daisy for the winter. Trying to winterize 23' International 2014 and not sure if I am looking at the right pump as it seems to be stuffed under the wardrobe storage with other electrical and vent tubing is making it hard to see the pump. Not sure which is the inlet to port to siphon the antifreeze...Thank you!
51coke is offline   Reply With Quote
Old 10-24-2015, 05:57 PM   #2
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
Check your owners manual to see if it provides any indication of how to access it. Not familiar with your model but it might be that you have to come in from above (take out a shelf?). On our trailer the intake on our Shur-flo pump is on the left facing the front of the pump and the hose screwed off, exposing garden hose style threads which threaded up to a hose from a Valterra winterizing kit. Maybe someone with the same floorplan as yours can provide additional assistance.
2015 Airstream Bambi Sport 16J
Past Travel Trailers:
*1992 Dutchmen 30' Bunk
*2003 Jayco Designer Series 32' Rear Living
*2015 T@B Sofitel S (exchanged after 3 days for Bambi)
remphoto is offline   Reply With Quote
Furrion Stainless Steel 30A inlet and TV inlet Gsmblue Electrical - Systems, Generators, Batteries & Solar 4 07-27-2015 07:58 PM
Water coming out of inlet port on trailer?! Steve Lohr Plumbing - Systems & Fixtures 2 05-31-2014 04:29 PM
Inlet port on the water pump for 2012 FC urnmor Winterizing, Storage, Carports & Covers 23 11-28-2013 10:16 AM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 09:57 AM
Leak in belly, by city water inlet...HELP rfield54 Fresh Water Systems 26 05-31-2010 07:20 PM
