Old 10-13-2015, 09:59 PM   #21
dznf0g's Avatar
Oswego , Illinois
Since I have mouse fur and vinyl ceiling, I only see condensation on the windows. Get a small dehumidifier and don't worry about furnace vs heat pump. My system automatically switches from hp to furnace at 36* f. Turn on the dehumidifier, set the thermostat, and forget it.
-Rich-
Old 10-14-2015, 10:45 AM   #22
jrolls's Avatar
2005 30' Classic
Box Elder , SD
Our system also switches automatically from HP to Furnace about 36-38 degrees. Once that happens we tend to use our Mr. Heater Buddy, a 4k-9k catalytic heater and close off the door to the galley/lounge. It uses very little gas from our small, refillable bottles. We have the mouse fur and vinyl ceilings so we have no moisture issues. If it gets too cold, we then use the furnace, however we rarely camp with night temps below about 25 degrees.
jrolls is offline   Reply With Quote
Old 11-29-2015, 09:58 AM   #23
2015 25' Flying Cloud
Euless , Texas
Trailers have wheels. I like that. As any prev. camper will tell you, this airstream stuff is a camper's Heaven.
Thanks all for the info. I am eventually going to have to read that library that came with my Castel.
Beaerman is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 10:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 05:23 PM
