Old 11-14-2017, 08:58 AM   #1
neenah , Wisconsin
Groaning sound
I receintly purchased a 2011 23 ft international. When we trailered it home all was well now after about 1000 miles when ever we are making a sharp turn a groaning sound is heard from the trailer. I am stumped has anyone else had this issue?
john engel is offline   Reply With Quote
Old 11-14-2017, 09:06 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Frame flex, weight distribution or the sound I make every time I have spend another $250 on mine.
MICHAEL
Old 11-14-2017, 09:09 AM   #3
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
My sway control hitch makes this type of noise on sharp, low speed turns. I just turn up the radio:-)
BambiTex is offline   Reply With Quote
Old 11-14-2017, 09:11 AM   #4
2012 19' International
Southeastern MI , Michigan
Gas station egg salad will cause that. Be sure and stay hydrated.
2018 International Serenity 27' FB
Michelin 16 tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 11-14-2017, 10:28 AM   #5
Mollysdad's Avatar
What hitch are you using? I have a Equalizer and it makes a terrible noise at slow speeds. That's it's way of letting you know the anti-sway is working.
Or, you snagged a homeless guy who was sleeping near your frame.
Old 11-14-2017, 11:11 AM   #6
2007 25' Safari FB SE
San Francisco , California
Lube it!
My trailer sounded like a T-Rex until I started lubing it regularly: https://www.equalizerhitch.com/blog/...al-i-zer-hitch
I recommend getting the sway bracket jackets too - one less thing to lube / helps you stay less greasy when removing the hitch.
brvltltoast is offline   Reply With Quote
Super loud cranking groaning clicking hitch! J5MM Hitches, Couplers & Balls 31 04-01-2011 09:50 PM
Groaning from somewhere down under JimmyT Hitches, Couplers & Balls 13 07-16-2010 03:04 AM
Buzzing sound from sound system, walking on floor makes it stop. foqus Electrical - Systems, Generators, Batteries & Solar 9 08-24-2009 08:22 PM
My Brakes are Groaning Alden Miller Brakes & Brake Controllers 6 08-22-2005 08:32 PM
Groaning Sound from Sway Bars Jenturnr Hitches, Couplers & Balls 7 08-09-2004 01:21 PM
