Old 11-29-2015, 09:55 PM   #1
Randy
Randyf22's Avatar
2015 27' FB International
Portland , Oregon
Furnace operations
The furnace and heat pump on our 2015 27 ft FB International Serenity run together with the thermostat controller set to "FURN." I would expect only the furnace to run. The outside temps are at or below freezing. Hot air out of furnace ducts. Cool air out of ceiling ducts. Can anyone offer an explanation?
Randyf22 is offline   Reply With Quote
Old 11-29-2015, 10:38 PM   #2
1994 34' Limited
Round Rock , Texas
Not sure why your AC unit is running. Maybe someone else can chime in on that one. However, the heat pump feature will only heat to the mid 30s. Then the furnace has to kick in.
Good luck!
txtwin is offline   Reply With Quote
Old 11-30-2015, 03:14 AM   #3
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Randy, if you have the Fan set to anything other than Auto, it will run while the Furnace is on - check to see if maybe it is set to high, med or low. Best, Joe
jayseejay is offline   Reply With Quote
Old 11-30-2015, 09:13 PM   #4
Randy
Randyf22's Avatar
Portland , Oregon
Thanks guys. I've yet to run the controller on auto. I'll try it this weekend.
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 10:17 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 04:37 AM
Deactivated Furnace will Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-22-2002 09:19 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
