Old 01-10-2011, 06:34 PM   #1
AirEPotter's Avatar
2011 27 FB International
Lubbock , Texas
Fresh water drain
Have a 2011 International. Am looking for the fresh water tank drain valve. The manual is no help. Thanks in advance.
AirEPotter is offline   Reply With Quote
Old 01-10-2011, 06:55 PM   #2
Wayward's Avatar
Cary , North Carolina
On my 25' it is on the port/road side between the two wheels. I just reach up and feel around under the tanks. There is a multi-turn brass petcock with two small handles. There is also a plastic quarter-turn valve which seems to be the "low point" drain for the water lines.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 01-10-2011, 07:02 PM   #3
_
unless the 11s have something new the FTDV looks like this...
http://cdn.airforums.com/forums/atta...2&d=1284067157
it can be very hard to get a finger behind to turn the first time.
but a little food grade silicone lube solves that issue.
________
there are also brass/steel "low point drain valves" on the fresh water (pex) lines...
but they are usually a bit further forward from the tank and farther under the belly...
cheers
2air'
Old 01-10-2011, 07:03 PM   #4
AirEPotter's Avatar
Lubbock , Texas
I find two brass valves but was under the impression (perhaps mistaken) this was the low point drain. I also see a white plastic valve. No idea what it is.
Thanks in advance.
Old 01-10-2011, 07:17 PM   #5
2016 30' Classic
Columbus , Ohio
The white plastic valve is likely your fresh water drain. It is on my trailer and it looks like the picture above.
2016 Classic
2016 Ford F-250 Lariat 6.7PSD
jeff4506 is offline   Reply With Quote
Old 01-10-2011, 07:35 PM   #6
AirEPotter's Avatar
Lubbock , Texas
This confirms it! Thank you.
Old 01-11-2011, 10:27 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Caution on the white plastic valve (yes it is the fresh water drain). It becomes brittle and the first thing you know, the little handle is broken. Very inconvenient to fix and damned inconvenient if it breaks in the open position and you are dry-camping.
So - always be gentle when you turn it.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 01-11-2011, 10:54 AM   #8
AirEPotter's Avatar
Lubbock , Texas
Pat
Duly noted. Thanks
Old 01-11-2011, 11:07 AM   #9
dznf0g's Avatar
Oswego , Illinois
Has anybody found a non-petroleum penetrant lube which can be used to lubricate the o-rings in the valve which is safe for drinking water?
Old 01-11-2011, 11:16 AM   #10
_
yes, as mentioned earlier food grade silicone in spray form works well.
for the industrious there is a food grade silicone grease that can be used...
IF the valve is dissembled 1st (this is what is ON the internals initially)
the links have been posted to specific products but just guggle the key terms...
the valve is nylon and pretty darn tuff, i've seen them withstand wrenches applied to turn...
the key is NOT fully turning it L or R.
the openings are lined up in a very narrow range, about 30-45 degrees at the middle position.
going past EITHER limit fully blocks the 2 holes.
cheers
2air'
Old 01-11-2011, 11:54 AM   #11
dznf0g's Avatar
Oswego , Illinois
cheers
2air'
Sorry, missed that line. Is that spray pretty common wherever small kitchen appliances are sold, or is it a commercial product?
Old 05-04-2011, 03:34 PM   #12
nomad3622's Avatar
2011 23' International
Tafton , Pennsylvania
cheers
2air'
2Air is right! I wish I had read this yesterday afternoon!
Peter
nomad3622 is offline   Reply With Quote
2011 international
Airstream model fresh off the 3d printer Jabba Off Topic Forum 22 12-13-2016 06:53 AM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 10:28 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 08:01 PM
Fresh water intake for '58 Caravanner Ron Banks Fresh Water Systems 8 01-04-2011 11:19 AM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 06:42 PM
