Old 07-03-2019, 12:04 PM   #1
aemers22's Avatar
Port Saint Lucie , Florida
Franklin Chef microwave
Extended stay at campground in FL. Use Progressive surge protection, twice my pedestal wonít supply current using it, only direct connection to coach. While troubleshooting attempted to use microwave and it cut off. Now canít get it working even with shore power. I flipped the breaker numerous times, couldnít locate GFI switch, nearly ready to purchase replacement since it will cost more to get tech to find/fix problem, thanks for any advise
aemers22 is offline   Reply With Quote
Old 07-03-2019, 12:41 PM   #2
Mollysdad's Avatar
I'll wager it's not seeing a ground and so the GFI won't pass power.
Does your PI surge protector have a readout? Error code?
LED's code? On mine, if only the green LED is lit, it's showing an open ground.
Correct wiring has both green and blue lit.
The other possibility, is the PI unit is shutting off the power since the voltage is too high or too low. That's only with the EMS units, not the SSP.
Handy tool and cheap! A circuit tester in a adapter.
Franklin Chef Microwave BoMan Stoves, Ovens & Microwaves 2 12-11-2018 06:56 AM
Replacement for Franklin Chef MW rbs Stoves, Ovens & Microwaves 2 09-24-2018 04:11 AM
Franklin Chef Convection Microwave? Narv 2011 - 2015 Classic (all lengths) 11 01-27-2017 03:42 PM
2015 AI Franklin Chef oven CraigL Sprinter and B-van Forum 4 12-01-2014 07:06 PM
Franklin Chef vs. Frigidare micro parts? BBez Stoves, Ovens & Microwaves 0 10-13-2013 06:54 PM
