Old 07-28-2011, 02:17 PM   #57
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Originally Posted by Kd9 View Post
We do have two front hitches, but they are on either side, not the middle, so problematical for hitching...
I don't know how else you would use a front hitch with a trailer that's nearly 10 feet tall. When you hitch up in the front, your mirrors are useless pointing in the direction you are not going. So you would want the trailer offset to your passenger side so you could see down the drivers side (which is the curb side of the trailer now). Unless you are backing straight up (in which case you shouldn't need a front hitch) or to the drivers side, you're blind because you are too close to the front of the trailer to see where the other side of the trailer is going... I like front hitches, for bike racks.
newroswell is offline   Reply With Quote
Old 07-28-2011, 02:41 PM   #58
Goal15's Avatar
Dallas , Texas
I guess I would opt for a storage facility where I don't have to back my AS in at a 90 degree angle.
Goal15 is offline   Reply With Quote
Old 07-28-2011, 05:47 PM   #59
casarodante's Avatar
2012 31' Classic
The front hitches I have seen are usually offset toward the passenger side of the truck. Done the proper way, the driver can see down the curbside of the trailer when pushing the trailer backwards.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 07-28-2011, 07:18 PM   #60
Maniacal Engineer
barts's Avatar
Menlo Park , California
Our front hitch is dead center; I don't have any problems seeing when I step out of the truck . The point of the front hitch is really to make it possible to turn more tightly; visibility on the outside of the turn is still impossible.
I guess most of my tight turns w/ the front hitch have been to the left (or with a rig I could see over), so my offset position in the driver seat helps; turning to the right would be harder.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
2011 international
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
1500 Mile Trip to get her home - Suggestions? Bambi_Bandit 1960 - 1964 Overlander 17 03-01-2015 05:17 PM
Help with Hitch set up evaluate First Trip out with TW and F250 Tony S Hitches, Couplers & Balls 11 07-31-2011 03:45 PM
Outer Banks Trip Memorial Day 2011 FLMarine On The Road... 3 06-29-2011 04:58 AM
You Know It's Been Too Long Since Your Last Trip When... rebelstand The Pet Forum 9 05-16-2011 09:37 AM
