Old 11-05-2011, 08:59 PM   #1
xo1rider's Avatar
2012 27' FB International
Fremont , California
Do you tow in "use" or "store"?
I'm a bit confused. Should I be towing with the use/store switch by the front door in the "use" or "store" position? I've been towing in "store" under the assumption I would not be running down the batteries.
If in the "use" position while towing will the juice from the tow vehicle charge the house batteries?
Thanks..
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
http://polakoff.com/RamblinRose/
Our travel log
xo1rider is offline   Reply With Quote
Old 11-05-2011, 09:10 PM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I don't have such a switch but can tell you the tow vehicle generator does charge the house batteries when towing.
4RXLA is offline   Reply With Quote
Old 11-05-2011, 09:15 PM   #3
monkeypants's Avatar
2009 27' FB Classic
Smithville , New Jersey
We go with "use". Don't know why, it just works :-)
monkeypants is offline   Reply With Quote
Old 11-05-2011, 09:50 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, once I pull my trailer forward and start getting it ready for a trip, I turn the "use" switch on and leave it on until our trip is over. Mainly because I will have my refrigerator running.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-05-2011, 10:15 PM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I'm pretty sure that if you have the switch in Store mode, there won't be 12v supplied to the fridge control board and the fridge won't cool when the engine is off, or maybe not at all. To be sure, disconnect your shore power and connect the umbilical to your tow vehicle. Turn the engine on so that the alternator is providing charge voltage to the trailer's batteries. Now put the switch in store mode and check to see what does or doesn't work in the trailer. Then switch the engine off and see if those things that did work have quit. The battery will always supply voltage to the tongue jack and the breakaway switch for the brakes regardless of the switch position.
Some prefer not to travel with the gas valves open, so if you don't run your fridge en route it probably makes little difference which way you have the battery switch set.
The only time I set the switch to Store is when I've been parked more than a day on shore power so as to not overcharge the batteries.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 11-05-2011, 10:31 PM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have towed Lucy for over 80,000 miles in the "use" position. We run our refrigerator on LP while underway, and this would not work in the store position. We also use Lucy's bathroom while traveling. The water pump would not work in the "store' position.
I don't see any advantage to towing the trailer on the road in the "store" position.
Brian
SuEllyn & Brian McCabe
Old 11-05-2011, 10:57 PM   #7
xo1rider's Avatar
Perhaps my question should have read "do you leave the switch in "use" and turn on the LP to keep the frig cool?"
I towed from Gulfport, Mississippi to Fremont, California in October with average 4-5 hours driving each day with the LP turned off and the switch in "store". If we had over a one hour stop I would turn on the gas, flip the switch to get a bit of cooling going. Each night I checked the stand alone refrigerator thermometer in the frig and at each stop the temp. was satisfactory.
In my last RV, a class "B" I had a 3 way frig and drove on "battery" which I miss with this unit. I was always told not to drive with any flames going, I don't mind the gas open but I'm a bit shy of having a flame.
Since I'm new to Airstreams and travel trailers in general thought I'd ask.
Swami Beyondananda
Our travel log
Old 11-05-2011, 11:18 PM   #8
moosetags's Avatar
We run Lucy's refrigerator on LP while underway. We always have. Many folks run this way. Others are not comfortable with doing this. Do what feels right to you.
Brian
Old 11-06-2011, 01:40 AM   #9
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
We travel with the switch in the "use" mode, the LP valves open, and the refrigerator turned on. We don't want to take any chance with food spoilage.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 11-06-2011, 02:12 AM   #10
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
You are correct... Batteries will not charge in STORE position. My dealer told me that I should never worry about putting the switch in STORE position unless I'm going to leave it for two weeks or more without a shore power connection.
Our fridge is a three way, so we do tow with it on the battery setting, but most people I know tow with the LP on.
Hibby
Hibby is offline   Reply With Quote
Old 11-06-2011, 04:16 AM   #11
airperson
2006 25' Classic
Ft Worth , Texas
Does an o6 classic have a three way fridge?
Airperson is offline   Reply With Quote
Old 11-06-2011, 04:23 AM   #12
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Airperson,
The easiest way to answer that would be to have you look at the power button on the front of the fridge. Mine has three modes, identified by a power cord(electric/shore power), battery (battery only), and flame (LP gas). Every time you press the button, it switches between the three modes.
If you choose a mode that's unavailable or not working, there is a small red alert light that will come on.
Hibby
Old 11-06-2011, 04:32 AM   #13
airperson
2006 25' Classic
Ft Worth , Texas
Thanks, will go over to storage lot and have a look. AP
Old 11-06-2011, 04:48 AM   #14
2011 30' Flying Cloud
Arvada , Colorado
I've found that the batteries still drain in the "store" position (to unsatisfactory levels over a period of time), so I installed a battery disconnect switch.
Jack46 is offline   Reply With Quote
2011 international
Van Conversion/Small Motorhome as tow vehicle? TG2500 Tow Vehicles 0 10-16-2011 06:07 PM
1/2 Ton Tow Vehicles brianw Tow Vehicles 39 09-08-2011 06:44 PM
Tow vehicle wheel base flynmike Tow Vehicles 15 05-09-2011 08:27 PM
Tow Vehicle-2011 GMC Yukon Denali-FC 23/25FB BMay Tow Vehicles 10 04-09-2011 10:24 AM
