Old 05-21-2015, 08:40 AM   #1
2014 25' FB International
airstream , zero
Ceiling lights flicker, tail lights are dim
Our '14 Serenity momentarily flashes the ceiling lights on when turning off the shower fan. Umm, does that seem normal?
Also, the dealer replaced the top, right taillight when some of the LEDs became unstable. Now it is the brightest light in the four light system. (I will post a photo or two.). Have you experienced that sort of thing?
Zeitlupe is offline   Reply With Quote
Old 05-21-2015, 09:00 AM   #2
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I did have problems with my running lights and taillights but in my casit was due to dirty connectors in the plugs. A little rub with fine sand paper and lubricant (WD 40) solved my problem.
I also recently had a problem with my led lights when you come in they did not work but I found that the fuze was loose. Not sure how that happen but they work fine now
urnmor is offline   Reply With Quote
Old 05-21-2015, 09:25 AM   #3
airstream , zero
If you would like to see the taillights photos, please find them in my profile area. ��
Old 06-27-2015, 09:47 PM   #4
chaseav's Avatar
2015 25' FB International
My interior overhead LED's make my subwoofer buz (slightly) when they first turn on. Then it goes away. My lights will dim briefly when I turn on the bathroom fan but does not make the lights flash on if they are in the off position. That sounds bad to me.
chaseav is offline   Reply With Quote
Old 06-20-2016, 06:39 AM   #5
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
A bump for this thread.
My shower LED light flickers when I turn on the shower extractor fan. Serious problem or normal?
DuncanK1 is offline   Reply With Quote
Old 06-29-2016, 10:08 AM   #6
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Mine does it too. More often when the antenna booster is on.
Anyone?
DoublTrouble is offline   Reply With Quote
Old 06-29-2016, 02:48 PM   #7
2012 23' FB Flying Cloud
Woodstock , Ontario
radio buzzes when cetain lights turned on
My 1012 Serenity, LED lights, develops a loud radio buzz when cerain lights are on. Problem exists only with the triplex light switch near door and with bathroom light. What is the cause?
terrythomts is offline   Reply With Quote
Old 06-29-2016, 03:08 PM   #8
bwpaint's Avatar
my , house
My shower light flickers on when turning on the shower fan, or it may be when I turn the fan off. I'll have to check it. Don't know about the antenna booster. I'll be checking that too.
bwpaint is offline   Reply With Quote
Old 06-29-2016, 06:44 PM   #9
BW, come to think of it, as I press the fan button the LED shower light does flicker, but it may do it when I'm turning the fan on or off.
Old 06-29-2016, 06:46 PM   #10
Maybe someone has an idea or has had their dealer "fix it " already.
Old 06-30-2016, 07:30 AM   #11
airstream , zero
When the dealer checked my flicker issue at least it was acknowledged. They spoke with the factory who also confirmed the issue but stated they did not have a fix. Oh well.
Old 07-01-2016, 07:29 AM   #12
Thanks Zeitlupe, at least I won't have to spend any time chasing that ghost.
Lights flicker kathy149 General Interior Topics 3 01-31-2014 01:47 PM
Lights dim and flicker tinman9 Lights - Interior & Exterior 1 11-18-2013 08:40 PM
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-07-2011 11:31 PM
dim lights dallas Electrical - Systems, Generators, Batteries & Solar 7 08-23-2006 08:25 PM
Why are my brake lights so dim? balrgn Electrical - Systems, Generators, Batteries & Solar 4 09-11-2005 01:38 PM
