Old 07-03-2018, 12:06 PM   #1
2014 23' FB International
Topsham , Maine
Cannot locate hydraulic jack placement location on 23FB
I have a 2014 International Serenity 23FB. The owner's manual states "To Change a tire with a jack see the label affixed to the underbelly to the rear of the wheels. This label, says JACK with an arrow and points to a plate riveted to the mainframe rail where the jack head must be placed". I can't find any label that says JACK, nor can I see any mainframe material behind the rear of the wheels.
I realize there are other methods to change a flat tire, but I was planning on purchasing a hydraulic bottle jack as suggested on other posts, but can't figure out where it would go.
Geobolduc is offline   Reply With Quote
Old 07-03-2018, 01:10 PM   #2
2007 22' International CCD
The jack point looks like a flat rectangle of metal about 2Ē by 3 inches riveted to the belly pan. The label can come off.
If you canít find it, bang on the belly pan and where it feels like really solid metal, that may be the heavy frame rail that runs front to back on each side. Itís usually just inside the line of the plate the axles are bolted to. The frame rail is hidden by the belly pan.
If they missed the jack point plates at the factory, Iíd get them installed under warranty if possible.
Old 07-03-2018, 01:17 PM   #3
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
I seem to remember not having the jack location plates showing under my 23FB as well. You can jack along the frame in front of, behind, or in between, the wheels. A short length of 2x4 is a good idea (unlike in my photo :-) ) to spread the load from the small round head of the jack, along a few inches of the frame. I certainly wouldn't try to guess where the frame might be underneath the belly pan. Guess wrong and it could be catastrophic. Be careful obviously, and always use jackstand(s) if both wheels are coming off, lowering the jack till the frame is solidly on the jackstands.
pcskier is offline   Reply With Quote
Old 07-03-2018, 01:38 PM   #4
Leilanisteve's Avatar
2015 19' International
Boise , Idaho
One of my jack plates was missing. The label pointed to the general area and I could barely see the outline where it used to be. Have the replacement. Just need to rivet it in place.
Leilanisteve is offline   Reply With Quote
External Antennae - Best Roof Placement Location dhroberts Computers, Internet & Satellite 14 03-23-2018 05:23 PM
No Power to Hydraulic Jack cloudflyer Winterizing, Storage, Carports & Covers 3 03-31-2011 05:28 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Hydraulic power leveler pump location bkahler Mechanics Corner - Engines, Transmission & More... 0 02-25-2007 08:13 PM
