10-12-2015, 09:01 PM
2015 25' FB International
Barker Power Jack getting loud
This summer after an extended deployment (5 weeks) the power Jack started getting really "groany" on its way up and sometimes down. I swear I read somewhere in a manual that you do not need to grease the Jack itself but I find that hard to believe. I just hate the sound of metal on metal and thought I'd see what other do. Thanks!
10-13-2015, 12:52 PM
1999 34' Excella
Hillsboro
I removed the "power head" then lubed according to their directions. Much quieter but not quiet.
Peace and Blessings..
Channing
WBCCI# 30676
10-13-2015, 01:05 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Just a place to inspect, run the tube out and look at its surface for gouges. If its all gouged up, tube might be bent.
10-13-2015, 01:07 PM
Biloxi
, Mississippi
MICHAEL
10-13-2015, 01:39 PM
Thanks Chief. I replied to you there.
10-13-2015, 01:59 PM
Lotus
2016 27' International
Nebo
, North Carolina
When you disconnect tow vehicle and the trailer moves any at all, even an inch or so, it will keep the post from being perfectly vertical. As it is moved up or down it will groan and pressure is not applied evenly. It will not damage your Jack, just sound bad. Tight wheel chocks will eliminate this.
10-13-2015, 08:20 PM
Yeah, a side load may be the common denominator but it's a newer development when hooking / unhooking on the same very level surfaces. Maybe I over stressed it at some point along the way.
10-18-2015, 02:05 AM
2021 25' International
Full timer
, Virginia
My jack groaning is always a sign for me that my lift/drop toggle switch is about to go bad. I've gone through about four of the toggle switches so far...
2024 Airstream Globetrotter 30RB
2022 Ford F350 Lariat Diesel
WBCCI 4CU 8118
10-18-2015, 06:07 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
My new 2015 Baker makes a grinding noise, especially when being lowered onto the ball or just lowered. I took it in after our 10,000 mile trip this summer and had our dealer look at it. They greased it, noise was not there first time we used it, but back the next time. Took it back in again and for one other item. They replaced the jack at their expense, now has done it again.
Not sure what next move will be. Thinking on it.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
10-18-2015, 06:26 AM
2012 25' Flying Cloud
Battle Lake
Our Barker 3000 was sounding overworked as well, so before this trip we put on a Barker HI-Power 3500 model. Claims more efficient, 25% less amperage draw with a low friction ball screw design.
http://www.barkermfg.com/hi-power-3500.html
We'll see, we work it pretty hard lifting tongue and rear of truck in our hitching/unhitching operation. Sounds better though.
Doug and Cheryl
