Old 08-20-2013, 08:10 PM   #21
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Steamy1, i have 2006 Bambi, planning on same rack. Do u lock bikes on, any theft issues? I keep my hoses inside the little door along with a few tools and jack pads, i guess that would still all work? I am so excited to bring my bike.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 08-21-2013, 07:44 AM   #22
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I have been using a cable lock to secure to the rack and bumper, but a U-shaped bar-lock would be better. I am currently looking.
We have not had any theft issues but we take common precautions such as parking in a visible area when grocery shopping or filling with gas, and storeing the bikes inside the trailer when we are away from camp.
We are headed to Glacier National Park next week and will take the bikes with us.
Steamy1
Steamy1 is offline   Reply With Quote
Old 08-21-2013, 07:53 AM   #23
Also, no issues with accessing the rear storage door. It is easier to access if the bikes are not on the rack, but I even keep two five-gallon water bottles in there and can take in and out when needed to refill the fresh water tank, along with a collapsable dolly.
Old 12-02-2013, 09:07 PM   #24
insearchoffun
exallen's Avatar
Box Elder , South Dakota
I thought I'd offer a bit of an update from my March 2012 post about mounting the Fiamma on our 2004 Safari. The problem was mounting the brackets to the trailer per instructions and the video. The tail light assembly was too close the the frame structure and there was not enough space for the bracket. Using rivets only failed after 1300 miles.
After confirming back and forth with Airstream, I remounted the brackets BELOW the tail light assembly which allowed the strainless steel screws to be used to fasten the the vertical framework. Bikes have been riding fine since the reinstall. Perhaps the picture will show the change.
exallen is offline   Reply With Quote
Old 12-02-2013, 09:57 PM   #25
Winemaker
rgwatkin's Avatar
2012 28' Flying Cloud
Avila Beach , California
We have a 2012 28ft FC and I installed the Fiamma in about 2.5 hrs. I found the install fairly straight forward except for some specialized tools required to tighten the nuts on the inside channel of the frame. One of them sits behind the hinge which is really tricky. We have carried our bikes for 1.5 year, 14 trips, 88 days and 14k miles without a single problem. Given that the Fiamma's are pretty popular additions now I would recommend that AS put the storage access doors on the sides as it is very difficult (almost impossible sometimes) to access with bikes on.
rgwatkin is offline   Reply With Quote
Old 03-30-2016, 04:14 PM   #26
Have the rack (added at purchase). +Holds bikes well
-Limits access to rear storage
28' Int Serenity RB
Krusty Buns is offline   Reply With Quote
Old 07-04-2016, 07:38 AM   #27
Pinehurst , North Carolina
What type and size screws did you use to drill in to the airstream for the upper two arms. I notice they do not come with the kit. Thanks
FastBob is offline   Reply With Quote
Old 09-29-2017, 11:53 AM   #28
2016 25' Flying Cloud
2018 28' International
Plainfield , New Hampshire
We have the same trailer, and are getting the bike rack. I'm concerned about the rear access though, as it is the only exterior storage. How bad is the interference?
dogfordrd is offline   Reply With Quote
Old 09-29-2017, 01:11 PM   #29
aftermath's Avatar
Spokane , Washington
This bike rack has been discussed many times. I have one that was installed by the dealer. It is rock solid and stillows access to the storage area. If you do it yourself and then make it fit by adjusting supports you should not be surprised when it fails. The rack is fine, it was how it was mounted.
If I had very expensive bikes or ones that I was sentimentally attached to I probably would put them under a cap. These things do ride outside.
aftermath is offline   Reply With Quote
2011 international
