Old 12-06-2011, 12:20 PM   #1
xo1rider's Avatar
2012 27' FB International
Fremont , California
A couple of random questions
I'm not sure what the floor is made of in my 2012 27FB Intl but I guess it's vinyl. First question what should I use on it other that clean water and a little soap if there's a spot. Do you use wax etc...
Second question: Where is the inverter located on my A/S? I'm guessing it's in the same place as the circuit breakers and fuese but I'm not sure. Also other than the two outlets in the cabinet that holds the Blueray player what other outlets does the inverter power?
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
http://polakoff.com/RamblinRose/
Our travel log
xo1rider is offline   Reply With Quote
Old 12-06-2011, 01:28 PM   #2
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Don't know where your inverter is in your 27' FB.
The inverter plugs should be labeled on each outlet that comes off the inverter. Usually buy the dinette, TV(s) kitchen.
Sphere Guy
AIR 50601
Sphere Guy is online now   Reply With Quote
Old 12-06-2011, 02:04 PM   #3
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
And by your bedroom tv. You should see dual 110v outlets side by side, or one above the other.
Have the same trailer (late model 2011). Think the inverter is down by the breaker panel.
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 12-06-2011, 02:05 PM   #4
DMT
DMT's Avatar
And the floor is vinyl. You can probably use whatever you want.
Old 12-07-2011, 06:36 PM   #5
2010 28' International
Dulles , Virginia
Don't know where the actual inverter is located but you may be looking for the switch to activate the outlets supplied by the inverter because this confused me initially, as I thought the marked outlets would be automatically powered. The On-Off switch should be just below the status monitor.
sbcohn is offline   Reply With Quote
Old 12-07-2011, 06:46 PM   #6
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Your owner's manual calls for any liquid floor cleaning solution for vinyl and warm water.
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline   Reply With Quote
Old 12-07-2011, 07:47 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You should have 4 inverter outlets, each paired with another regular shore power outer next to it and marked with a blue label "Inverter Outlet". Located next to Bluray player, under dinette, front tv, rear tv.
The inverter is not large enough for most kitchen chores such as coffee maker or toaster and therefore not available at the galley, although the switch is there. It is basically there for entertainment features, computer use which is pretty slick because everything else but air conditioner works on 12vdc from the battery.
One might be tempted to increase the inverter size but I wonder (doubt) if the inverter system wiring is large enough to handle it.
doug k
2011 international
Random behaviour of dash instruments. Tony Lee Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 04-21-2013 11:30 PM
Noob with tons of questions! 8string Full-Timing 14 07-20-2011 12:55 AM
Couple of nagging questions.. DanielB Off Topic Forum 13 02-27-2011 10:10 AM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
