Old 05-30-2011, 06:37 AM   #1
pendletonkm's Avatar
2011 27 FB International
Amarillo , Texas
Send a message via Skype™ to pendletonkm
27FB AC cooling problem
My wife and I have been living full time for the last month in our 27FB in Amarillo, TX. We are both new to full timing, and everything has been great until yesterday. The heat got to 103 and I could not get the trailer to cool down past 87. Any idea's?
-A/C was on full blast.
-I clean the filters every week.
-All window shades and skylights where closed.
Kent
pendletonkm is offline   Reply With Quote
Old 05-30-2011, 06:43 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If your AC unit is a 13.5K BTU, then you at the limit as to what this unit can cool. I had a 28' Safari and experienced a similar problem on it's first time out in 104 degrees and full sun. I added awning on the street side which helped somewhat. When I bought my Classic I upgraded from the standard 13.5K unit to the 15. Never regretted that choice.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-30-2011, 06:55 AM   #3
Jack is correct. If you are fulltiming it makes sense to upgrade to a bigger unit or go North for the summer. Your a.c. is working normally.
handn is offline   Reply With Quote
Old 05-30-2011, 07:07 AM   #4
Amarillo , Texas
Jack,
So, this is normal even with a 15K BTU?
Old 05-30-2011, 07:11 AM   #5
one of those
Gringo's Avatar
'03 F250 PSD , Airstream summers, Catalac winters
but.....the 2011 International 27FB came with the 15,000 btu ac as standard, didn't it?
Ours did.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 05-30-2011, 09:46 AM   #6
Amarillo , Texas
Yes, my 2011 FB has the 15k.
Old 05-30-2011, 10:07 AM   #7
one of those
Gringo's Avatar
hmm. from what jcanavera is reporting, it should do it.
Have you thought of some kind of solar film on the inside of the windows? those spaces between the windows and the interior shades are great little solar furnaces. Problem is that they're inside the trailer with you. Or outside shade. Are you getting direct sun on the trailer?
How bout the skylights and roof vents? Are those out of the direct UV? Do you have vent covers?
Old 05-30-2011, 12:22 PM   #8
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
I had issues when we were in Arizona, and Las Vegas, and I bought a tube fan that I ran all the time. I also ran the air conditioner full blast through the night, and by early morning I could get the temp down to low 70's. Running the fan circulates the air and by noon it would be 80 inside with 112 outside.
The fan made it comfortable even during the hottest of days
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 05-30-2011, 12:35 PM   #9
Amarillo , Texas
Gringo,
Thanks for idea's. I have already put vent covers on and I just went to the store and bought a couple little fans to try and circulate the air better. As you suspected my Airstream is in direct sunlight all of the time. The park we stay in is pretty new with little shade due to the newly planted trees. The trade off is it has the biggest slips in Amarillo and the price is just high enough to keep riff raff out of the park.
Reganzo,
Thank you also for the good info. That gives me some hope. I am an active duty Marine and my wife and will probably be moving to 29 palms california in about a year. I was starting to get concerned that I might need to purchase a second A/C to put in the bedroom area.
Old 05-30-2011, 12:44 PM   #10
JFScheck's Avatar
Rockville , Maryland
Images: 33
Believe it or not (I know I just posted this comment somewhere else) - the pull out canopies really help keep the Stream cool - especially the street side and back.
If your Airstream did not come with them and you live in a "Hot" environment (or hang out in one) it might be worth the expense!
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 05-30-2011, 01:05 PM   #11
Gainesville , Florida
As posted before the ac will only cool to 20 degrees below outside temp. I think it is in the design. jim
Old 05-30-2011, 02:26 PM   #12
Amarillo , Texas
Update.....
Added two small 4" fans, amazing results, much cooler.
Reganzo,
What kind of fan did you buy? Size and brand?
Old 05-30-2011, 02:36 PM   #13
JFScheck's Avatar
Images: 33
Interesting - more airflow - allows for better evaporatoin on skin so feels cooler - Nice Solution!!!
In Between Units
Airstream On Order
**I Love U.S.A.**
Old 05-30-2011, 03:51 PM   #14
Ottawa , ON
Some trailers have the special white paint just on the roof to better reflect the sun's rays. Since it's only on the top, you don't really see it.
If you don't already have that, posters on here have claimed a 10 degree improvement (cooler) just by adding it...
2011 international
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 07-29-2011 09:40 AM
Dometic RM-100 Cooling Problem startrekker2001 Refrigerators 9 11-19-2009 07:30 AM
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
