Old 12-14-2017, 01:32 PM   #1
1948 16' Wee Wind
Marshall , Michigan
Brake positive or negative ground,
Does the pklarity matter when wiring up to harness on my old 49 weewind?thank reinee
reinee is offline   Reply With Quote
Old 12-14-2017, 01:55 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
On modern trailers it makes no difference so unless you hear something different from an owner of a '49, I would think the same should apply in that case.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-14-2017, 05:26 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The brake magnets don't care which direction the power comes from ,as long as it is there.
Old 12-14-2017, 06:18 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
When electricity is applied to Electromagnets the behaviors are similar to natural magnets. In electric brakes, controlled magnetism is needed... this is the electromagnet’s special behavior utilized in the braking process.
So, no it isn’t, generally an electric current polarity issue.
It is good to mention here that sending power to a device also requires proper grounding. Do not skimp. The primary brake feed wire and ground must size match on both TV and AS.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-15-2017, 10:49 AM   #5
Vintage Kin
Fort Worth , Texas
I would oversize. ANCOR Wire Products for all components. West Marine, or Waytek. Heat-shrink terminations.
Old 12-15-2017, 10:56 AM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Wouldn’t 1949 be 6 volt?
tjdonahoe is online now   Reply With Quote
[IMG] code is Off
Using ground for circuit negative instead of dedicated neg CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 1 04-19-2017 09:03 PM
Help! Help! Positive Ground Tow Vehicle Moonstruck Brakes & Brake Controllers 77 01-08-2015 10:28 PM
positive to ground short rspivey7919 Electrical - Systems, Generators, Batteries & Solar 9 07-22-2013 04:12 AM
Any ST trailer tire that gets positive reviews? 63air Tires 13 08-06-2006 03:39 PM
WBCCI Families & Youth - Positive Reinforcement LuminumTraila WBCCI Forum 44 07-18-2006 11:51 AM
