Old 01-04-2013, 01:08 PM   #1
1962 24' Tradewind
Belfair , Washington
Parking on steep driveway
Hi... Just bought a 62' 24 ft. airstream, need to bring it home. Problem: Live on steep driveway and is the only place I have for it. Need some advice how to keep it stable and the best way to brace it from rolling down the hill while I gut and remodel the inside. Thanks need answers soon PLease
KarensHere is offline   Reply With Quote
Old 01-04-2013, 01:48 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You will need a very good set of chocks for the tires and probably a block to go under the tongue jack. Depending on how steep the driveway, it may not be practical or safe, even with chocks. You could use the type that clamp between the tires and those that go in front.
Remember SAFETY FIRST!!
Old 01-04-2013, 02:01 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Real question is, how steep? If the slope is such that if you level the trailer and the up-slope end touches the ground, forget it. You'd be better off finding somewhere else to do the work, even if you have to rent a place. Working on the trailer where you can't even get it level means problems during remodeling.
When you get it where you want it, take the wheels off, and level it with blocks under the axles (jacking up one wheel at a time to get the block under it). No wheels, it won't roll.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-04-2013, 02:06 PM   #4
dznf0g's Avatar
Oswego , Illinois
See my avitar...or go to my profile screen. I park, when at home, just about as steep as the tail draggin' bars will allow. I use a wedge style chock/lock between the tires. blocks under the tongue jack and jack almost all the way extended. If it is going to be there more than a day, I put about 1.5" of level blocks under the front tires to relieve the stress on the rear axle. very stable....never moves a bit.
-Rich-
Old 01-04-2013, 02:08 PM   #5
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I have a pair of chocks/locks that go inbetween the tires, they seem to work well. You could also pass a chain through the wheels to lock them together so they can't turn.
I also have a truck mostly dedicated to being a tow vehicle so I can just leave the trailer hitched and the truck in park with the park brake on.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 01-04-2013, 02:25 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
A note on in-between-the-tire chocks. If tire pressure is decreased suddenly, or over time, they will not hold. I use them, but do not trust them on a grade.
Also do you ever get freezing rain on the driveway, if so the trailer could slip quickly if traction of wheel chocks is lost.
It sounds extreme, but I wonder if you could drill the driveway and put bolts through wheel chocks to anchor it, like in parking lots. I suppose it would need some sort of removal system would be needed for moving it.
doug k
Old 01-04-2013, 02:39 PM   #7
I thought of something like that, but then edited my previous post to remove it, since if the driveway is steep enough to really need it, it's too steep to level the trailer.
My thought was to drive a long steel rod as an anchor alongside (not through) the driveway near the trailer's rear bumper, and run a steel chain, nylon webbing tow strap, or a steel cable from the rear axle to the steel rod anchor. No need to remove the steel rod afterwards, just drive it even further into the ground, so that the top of the rod is below ground leveland won't catch a lawnmower blade.
WBCCI #1105
TAC LA-4
Old 01-04-2013, 02:39 PM   #8
dznf0g's Avatar
Oswego , Illinois
Doug reminded me, I do chock the wheels on both sides as well as use the between-tire-wedge chock. Never park at home during freezing weather....it's winterized and put away at the "yard". I never thought about sudden deflation. I think I'll add the through wheel heavy cable lock which I use for an additional level of theft deterrent at the storage lot, at home as an anti-roll away device.
-Rich-
Old 01-04-2013, 02:43 PM   #9
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
You may want to consider an anchor and chain.....no kidding if there is a secure fence post, building, tree or rock that you can tie off a chain to the axle. If that would be a trip hazzard then allow the chain to rest on the ground. Yes there would be some slack but if the trailer begins to roll.....
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 01-04-2013, 03:21 PM   #10
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Don't Use Cheap, Plastic Chocks
Go to Harbor Freight and purchase at least four of the heavy, rubber chocks.
For your application, you may want eight chocks.
I would not trust the between the wheel chocks on a really steep driveway for all the reasons already stated.
Name:	wheel chocks.jpg
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 01-04-2013, 05:09 PM   #11
dznf0g's Avatar
Oswego , Illinois
You could also attach an extension to your breakaway switch and stake it back and down into the edge of the drive. Use a little imagination on setup. Of course, 12v would have to be up and running.
-Rich-
Old 01-04-2013, 05:56 PM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by dznf0g View Post
........I think I'll add the through wheel heavy cable lock which I use for an additional level of theft deterrent at the storage lot, at home as an anti-roll away device.
Winter Storage anti-theft device....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-04-2013, 06:29 PM   #13
1988 32' Excella
Robbinsville , New Jersey
Except that would fry the brakes in 5 minutes or so if you couldn't release them.
Old 01-04-2013, 06:32 PM   #14
dznf0g's Avatar
Oswego , Illinois
Not with hydraulic. The pump shuts off after 20 seconds, and a hold solenoid retains hydraulic pressure until 12 volts is removed.
-Rich-
