03-31-2011, 10:49 AM
1988 29' Excella
Livingston
Hitching up solo how do you do it?
Howdy!
I posted here since you hitch up your Airstream solo all the time anyway. I have enough problems hitching the AS up with the help of my LW. What tricks do you use to help you hitch up by yourself.
"Happy Trails"
chiefneon
03-31-2011, 11:21 AM
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
I am saving for the camera, but for now, on the cheeper side this is what I use.
Magnetic Trailer Alignment Kit
03-31-2011, 11:25 AM
2011 23' FB Flying Cloud
Missoula
, Montana
Carefully!
03-31-2011, 11:49 AM
1973 31' Excella 500
Spring Green
, Wisconsin
I hitch up by myself a lot. Mostly I line the TV up with the trailer using the driver's side mirror. I know how much of the side I should see when it is following me down the road. When I think I'm within a foot, I hop out and check the remaining distance and allignment. If it is only a short distance, I leave the driver's door open and pick a reference point on the ground to measure the distance I have to back up. I can usually get there with only one or two visits to the back of the TV.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
03-31-2011, 11:52 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
That is almost exactly what I do. It is really pretty easy once you do it enough to get a baseline on what things should look like. I would add, whenever in the least bit of doubt, get out and look!
03-31-2011, 11:57 AM
2004 19' International CCD
Los Angeles
x2 thats almost exactly what I do. (It also helps that Im 6' 235lbs and can manhandle the 19' a few inches easily enough to get the alignment juuust right.)
03-31-2011, 11:59 AM
2007 31' Classic
Pulaski
, Tennessee
Try that with a 31 Classic
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
03-31-2011, 12:11 PM
2000 23' Safari
Vero Beach
I enjoyed the comment someone made about leaving the drivers door open and backing up the last few inches. Once when hitching up there was a tree stump sticking up just enough to catch the bottom of the open door and I whacked the drivers door right off! Neither my A/S or the tree stump (state property!) wasn't damaged! I suspect I will hear about that for the rest of my natural born days!
03-31-2011, 12:15 PM
2004 16' International CCD
Arcata
I use a convex mirror that slips on the tailgate of my truck. The Cipa Fast Hitch Trailer Hookup Mirror. Sold by Amazon and others. Works well for me.
03-31-2011, 12:16 PM
I bought a small wireless camera and mounted it on a flexible camera stalk with a suction cup base. I stick it to the tailgate pointed straight down at the hitch ball. When unneeded, I just hang it inside the rear window.
The cable is long enough that I can also use it as an auxilary review mirror, or to keep an eye on the grandkids in the rear seat.
03-31-2011, 12:37 PM
Sioux Falls
, South Dakota
I back to a wheel chock, same as backing a truck to a dock or a door. My goal is to achieve my goal within 6 tries. Lateral alignment requirement is +/- one inch from center.
03-31-2011, 12:39 PM
1972 21' Globetrotter
nc
, North Carolina
if you have a laptop you can buy a cheap web cam and ext cable. mount it anyway on tail gate and see where you are as you back up.
03-31-2011, 12:43 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I just open the rear door, fold down the seat back and I can see the hitch and the ball.
03-31-2011, 12:54 PM
Wise Elder
2010 30' Classic
South of the river
It's easier with a propride hitch because you don't have to worry about overshooting the way you do with a ball. I always hitch solo.
The magnetic ball thingies work very well and save a lot of trouble and trips out of the driver's seat.
03-31-2011, 01:10 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
My truck has a backup camera as part of the navigation system. If that wasn't part of the truck, I would have added a backup camera. It is well worth the investment if only in terms os avoided frustration and arguments.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
03-31-2011, 01:25 PM
2008 22' Safari
Oracle
Originally Posted by tiger
Yes, I use the balls too. Absolutely no problem.
03-31-2011, 01:34 PM
Sioux Falls
, South Dakota
I don't have the balls for backing.
03-31-2011, 01:39 PM
2002 19' Bambi
Northwestern Ontario
, - on the backside of the map and just above the big green spot
I always hook up alone - much easier to maintain domestic harmony .....
.... and I use the GOAL method (Get Out And Look). The only real secret is getting out early enough to make sure you are lined up properly from the get-go - as long as I've done this early enough it would be rare to have to get out more than 3 times. I also use a hitch-helper which does any necessary side-to-side fine tuning.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
03-31-2011, 01:51 PM
1977 Argosy 24
Hudson
, New Hampshire
Me too. I'm better without help!
~2Alaska
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Solo fulltiming
shinyteepee |
Solo Streamers |
22 |
07-31-2011 09:37 AM |
