Old 11-08-2014, 02:39 PM   #141
1978 31' Excella 500
Barrie , Ontario
I hitch solo, just line up the handle on my truck cap with the hold down on my propane tanks to get squared up and then use the GOAL method.
Intend to try some of these other ideas too.
"Its what you learn after you know it all that counts'
Bev1940 is offline   Reply With Quote
Old 11-08-2014, 05:41 PM   #142
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Well, after my first season, I use no fancy feature, etc. just line it up and drive to within a foot or two and then gauge corrections based on visual inspection as to what turn to make next and do so. I'll keep my drivers side door open and pick targets on the ground and track against the triangle point of my door hinge. So far, the most I've had to reset the realignment is four trips back to the hitch ball to review. Usually I have it in two or three visits.
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 11-08-2014, 06:14 PM   #143
Olie's Avatar
2004 30' Classic
Beaumont , Texas
I use the magnetic tennis balls to hook up to the Hensley. Works OK, may have to get out of the pick- up and look 2-3 times. Stabbing the pin in the box has to be so exact I often wonder if a backup camera would be worth the cost.
Olie is offline   Reply With Quote
Old 11-08-2014, 07:24 PM   #144
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Yes, a backup camera is worth it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-08-2014, 10:11 PM   #145
2007 22' International CCD
Before I acquired a TV with a backup camera, I sighted center by using the camper cap latch handle and lined it up on the centerline of the AS to aim at the ProPride socket. Dead slow backing, a couple stops and get out and look cycles aid I was usually able to get the stinger aimed right. Then adjust AS jack for height and in it goes with a gentle clunk. Latch and go from there.
Yes, it was a lot easier with a spotter standing clear on one side for safety. IMHO it's too dangerous to stand in harms way where I'm backing a big truck into a small target. Still got out to see 'ground truth' when close.
hitching, solo
Solo fulltiming shinyteepee Solo Streamers 22 07-31-2011 09:37 AM
