Old 12-07-2010, 07:22 PM   #29
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
We have installed a couple of hundred bike racks on Airstreams without it causing a problem. However I wouldn't want to give the impression that any bike rack system is fine to put on an Airstream. The common system of welding a receiver underneath and sliding in a "S" shape rack will cause structural problems on many models of Airstreams.
The rack we install for two bikes works because the rack only weighs 12 pounds, it is supported by the body and the frame, and the bikes are carried very close to the back of the Airstream.
I hope this helps.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-07-2010, 07:58 PM   #30
HowieE's Avatar
Princeton , New Jersey
Images: 12
Nice rack Andrew.
Did we have the same dream?
ID:	116708   Click image for larger version
2004 Excursion 4x4
Old 12-08-2010, 06:12 AM   #31
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Originally Posted by gsmithii View Post
We chose to put the bikes on a Thule rack mounted on a spotting hitch in the front the the TV. As others have observed above there are lots of pro's and con's for any choice.
In addition to the above, as much as we find the bikes in front to be convenient we certainly do look like a Traveling Circus going down the road.
Of course it does leave room to put a kayak on top of the TV later.
Now That will be a bit o' the traveling circus.
Travelling circus for sure...but at least we have all of our toys when we get to the lake! 3 Bikes, 2 tandem kayaks, porta-bote w/Motor...yikes! Locked and loaded.
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 12-08-2010, 06:41 AM   #32
dznf0g's Avatar
Oswego , Illinois
Is there a truck in there....somewhere?
Old 12-08-2010, 08:14 AM   #33
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
ROFLOL, lord thats funny
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 12-08-2010, 08:22 AM   #34
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Where is the periscope?----------------------------------------------------Sal.
noreen&sal is offline   Reply With Quote
Old 12-08-2010, 09:01 AM   #35
1 Rivet Short
1989 25' Excella
Yeah, I know...but that's how it goes when you want to be active outdoors. (Some Folks don't take anything more than a blender!) We don't always travel that loaded up...but for a week up in the mountains..we are loaded.
And yes, there is a truck...and an AS under all that! Paddled up to a Moose on this trip!
No bikes on this trip...this was hiking and paddling...
Any way...we are off topic now...later.
B
ID:	116732   Click image for larger version
Old 12-08-2010, 09:25 AM   #36
Bird's Nest's Avatar
2007 19' Bambi
2005 18' Westphalia
Evans , GA
Our bike rack needs have changed. We love our Yakima Bed heads in our TV but now we use a Westfalia instead of a 28'CCD and GMC 2500 TV.
The Bed Heads work great with all kinds of bikes, even our carbon road bikes. But now we have to switch to a hitch rack. We have one from the early 90's that was considered high-tech when we bought it but it is now reduced to a dinosaur. It worked okay through the cross-bike season since my husbands CX bike is metallic.
We have a short bike-trip break but in February we will start traveling to centuries and the old rack will not cut it with the carbon road frames. We have our eyes on a Kuat NV. Kuat Racks
Plus, my husband has designed a swing away bracket that will allow the bikes to rotate to the side of the Westy for unencumbered rear door access. His plans are at a fabrication shop right now. I will post photos once it is fabricated, powder coated and installed on the Westy.
We loved our CCD but the Westy is just perfect for the quick get-a-ways our current lifestyle demands. We discovered all we need is a little room for our bikes, our Jack Russell and each other.
Bird's Nest is offline   Reply With Quote
Old 08-30-2011, 05:39 PM   #37
arlington , Texas
I'm in the process of choosing a TV for my 59 Streamline. One of my criteria is an extended cab for the truck that will fit my bikes. If your bikes are as expensive and beloved as mine, only inside storage will do.
jjuneau98 is offline   Reply With Quote
Old 08-30-2011, 06:34 PM   #38
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
We tow with a Chevy 1500 crew cab. Using a 2x4 stud and clips purchased from a bike shop we made a rack that mounts on the front rail of the truck bed. We remove the front tires and clip the bikes to the rack and using tie downs straps anchor the rear tires. The longest trip so far is over 800 miles round trip with no problems.
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 08-30-2011, 11:59 PM   #39
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Airstreaming with Bikes -
Here's another school of thought for Airstreaming with bikes... We use a Thule rack with a box for extra items in the middle and a mountain bike on either side. If you want to drive to a trail head and keep the AS parked, no worries - they're with the truck. Been working real well for us, just watch out for low hanging branches...
Name:	AS White Sands Rig with Bikes.jpg
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 08-31-2011, 06:43 AM   #40
1 Rivet Short
1989 25' Excella
If I really had to have my bikes inside, and I can understand why some Folks do...I would serioulsy consider a 3/4 ton van.
They make great TV's...and a fairly safe/sheltered place for stuff!..
B
Surfing, Kayaking, Mtn Biking Rally or Caravan? lovingtahoe Forum Rallies & Meet Ups 14 06-21-2007 10:32 AM
Mtn Biking with the Airstream swebster General Motorhome Topics 19 06-25-2006 04:53 PM
