Old 12-04-2015, 02:57 PM   #1
2016 25' Flying Cloud
Holly Springs , Mississippi
Twin beds on narrow body Airstreams?
In the last 15 or so years, has Airstream built a trailer model with twin beds that was not the 8.5 ft. "wide body?" Something with twin beds that's about 23 feet long and no more than 8 ft. wide is very appealing. This cures heavy tongue weight and overall trailer weight and the need for a 3/4 ton truck.
Has Airstream ever made such a thing?
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 12-04-2015, 03:08 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
My 1995 25ft is not a wide body and has twins. Tongue weight for a dry, empty trailer is listed at 700 lbs. Empty trailer weight is 5300 lbs.. I do not use a 3/4 ton. The prior owner did not either....I don't recall ever seeing a 23 with twins.
CRH is offline   Reply With Quote
Old 12-04-2015, 03:08 PM   #3
Mrjkq's Avatar
Venice , Florida
I'm personally not aware of any Airstream under 25 ft with twin beds, and my 25 matches perfectly with my 1500 RAM truck.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 12-04-2015, 05:11 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Another perfect match, our 25 and Ram 1500. We just carry what each is capable of, which is substantial. If the tongue weight is too heavy, adjust the load and/or equipment. No problem.
Doug and Cheryl
Old 12-04-2015, 07:40 PM   #5
This very helpful input. Thanks.
For those towing with a 1/2 ton truck, did you add a transmission cooler?
2016 FC 25' FB twin
Old 12-04-2015, 07:42 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
My truck is 1/2 ton. It had a tranny cooler added when it was new off the lot before my family started towing with it.
Old 12-04-2015, 08:05 PM   #7
Mrjkq's Avatar
Venice , Florida
That's a must especially in mountain areas. If you have the tow package ( tow/hall mode) it's already included.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 12-05-2015, 12:41 PM   #8
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
My 2005 Chevy Silverado 1500 came equipped with the factory towing package. I just turned 50,000 miles on the vehicle and two months ago I had to replace the transmission.
I climbed a hill and as I was pulling into a rest stop I saw a warning message that I had never seen before, "High Transmission Temperature". This was the middle of the night and I planned on getting a couple hours rest, so when I left later, I went about 1/4 mile and found that the RPMs started racing, but the truck stopped going. It would work in reverse, but no forward gears. Had it (and the 25' Airstream) towed to the next major town and had the transmission replaced, $3,000. Working fine since then.
WindyJim is offline   Reply With Quote
Old 12-05-2015, 01:21 PM   #9
1977 25' Tradewind
Cibolo , Texas
I tow my 1977 25' AS (twin beds) with a F-150 1/2 ton (tow package) EcoBoost 3.5 V6. Book states max loaded trailer wt rating is 11,300 lbs. and pay load of 3060.
GailMac is offline   Reply With Quote
Old 12-05-2015, 01:43 PM   #10
That's a remarkably high payload for an F-150! Well done.
2016 FC 25' FB twin
Old 12-05-2015, 02:07 PM   #11
The SilverSleeper
Beaubill's Avatar
2001 28' Excella
1988 23' Excella
1988 23' Excella
Daphne , Alabama
23 ft with twin beds
The 25 ft Airstream is 25+ft bumper to bumper and the body is only 23ft long. Check it out. There is plenty of room for twins.
Beaubill is offline   Reply With Quote
Old 12-05-2015, 02:35 PM   #12
Mrjkq's Avatar
Venice , Florida
My 25 AS is 25ft 11in B to B.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 12-06-2015, 09:40 PM   #13
BigButtUgly's Avatar
1958 22' Caravanner
not shared , Nebraska
Yes. Just one of many AS design problems. Gut and fold down in front of front and rear windows. 1958 Caravanner 22'. Nobody at AS thinks outside of the box.
BigButtUgly is offline   Reply With Quote
Old 12-07-2015, 07:27 AM   #14
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Airstream made some 22' trailers with permanent twins in the 1950s and maybe a very few rare 22' Safaris with permanent twins in the very early 1960s, up to maybe up to 1963 or so. After that, 22' twins were where the long dinette benches did double duty as the twins at night. This dinette twin setup was actually the much more common 22' Safari twin setup from 1960 or so onward.
From 1969 to 1979, the 23' Safari could be optionally had with permanent twins.
Since then, Airstream gas only offered double beds on 23' and smaller trailers and permanent twins only on Airstreams 25' and longer.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
wanted -twin beds for 1995 airstream 34' wide body hemilust Airstream Classifieds 0 10-22-2014 07:57 PM
1999 34' Airstream Limited Wide Body - 3 Axles - Twin Beds in rear- Dinette eBay Watch Airstreams on eBay 0 02-04-2014 07:00 PM
Wide vs Narrow Body Michigander Airstream Trailer Forums 1 04-13-2011 03:12 PM
upper (narrow) red and blue belting?? charlie tuna 1974 - 1979 Sovereign 5 10-28-2006 06:50 PM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 01:25 PM
