10-15-2017, 06:01 PM
#261
1963 22' Safari
2020 27' Globetrotter
State of
FOUND!! Wally Byam's 55 Cruiser - 1956 European Caravan trailer
Has anyone pulled these apart successfully? I think the knob can come out but I'm worried I'd ruin them. Modern replacements just don't look as cool
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
10-16-2017, 05:56 PM
#262
Central
, Mississippi
I couldn't get mine apart. I considered seeing if a gun shop could 'blue' them as an assembly but never followed up.
10-16-2017, 08:29 PM
#263
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
Looks like the knob on the slider was peened into place by the five or so dimples on the back.
Joe
WBCCI/VAC #702 & #6768
10-16-2017, 08:36 PM
#264
Registered User
1957 22' Custom
Lago Vista
Cleaning the screen door latch
Originally Posted by goransons
Has anyone pulled these apart successfully? I think the knob can come out but I'm worried I'd ruin them. Modern replacements just don't look as cool Attachment 297087
I dropped mine in a bucket of carburetor cleaner for 24 hours and they came out slick as a whistle
10-16-2017, 08:58 PM
#265
1963 22' Safari
State of
good to know, I'll try soaking! Joe I was thinking careful grinding might free it up but I'm worried I can't reattach.
Interesting thing, they drilled 3 holes for the back mounting location, the middle hole held an unbucked rivet which kept the slide bolt from dropping out and jamming up. Hard to show without pictures. I'll post those later.
Scott & Megan
10-16-2017, 08:59 PM
#266
1963 22' Safari
State of
I'm going to clean them up first and see how they turn out. I think the slide bolt itself might be brass.
Scott & Megan
10-16-2017, 10:11 PM
#267
1958 26' Overlander
Battle Ground
If you have to grind the shaft off to get the knob off, consider having it put back on with a gas torch and brass rod. An alternative may be TIG with silicone bronze. I'd check with your welder first for his thoughts.
10-20-2017, 11:50 AM
#268
Central
, Mississippi
If you decide to use a brass dump valve, consider pulling out the guts and sandwich a modern valve above it. It would still 'look' correct except for the period correct dribble that brass valves come with. I think I have a brass one or two in my junk pile.
Here is all the junk I have.
10-20-2017, 01:17 PM
#269
Registered User
1957 22' Custom
Lago Vista
I've got a magazine rack
This is a pic before I cleaned it up, but now it looks shiny and new, and I'm not going to reinstall it in my refurb. If you PM me with your address I'll send it to you, no charge. Happy to know it's going to go in such a cool trailer.
10-20-2017, 01:53 PM
#270
1963 22' Safari
State of
That would be amazing!! Thank you!! Sent you a pm. I’m happy to buy and cover shipping!
Scott & Megan
10-20-2017, 01:54 PM
#271
1963 22' Safari
State of
I’m interested in the valve and one of each of the types of fittings. Let me know what you’d like for them and I can send money your way!
Thank you!
Scott & Megan
10-20-2017, 07:51 PM
#272
Central
, Mississippi
Thank you!
A pal sold a race car...
$2000, car and spare parts. $3000 for just the car.
$100 for each part but if you take it all, it's free.
PM me an address.
10-20-2017, 08:40 PM
#273
1966 22' Safari
Fredericksburg
[QUOTE=HiHoAgRV;2024409]A pal sold a race car...
PM me an address
I like your reasoning. I would think Scott does too.
Bubba
10-21-2017, 09:36 AM
#274
1963 22' Safari
State of
I really do appreciate the help! Purists be warned I will not be replicating the wiring methods.
Pouring rain today. Found a couple minor drips but incredibly dry inside so I’m insulating the street side and running new 110 and 12 volt wire.
Scott & Megan
10-21-2017, 09:56 AM
#275
1979 23' Safari
1954 29' Liner
Orange
Thank god, I hope not. Found the same thing rewiring my 1954 Liner.
Bill
I really do appreciate the help! Purists be warned I will not be replicating the wiring methods. Attachment 297422Attachment 297423
Just my personal opinion
https://billbethsblog.blogspot.com/
10-22-2017, 11:57 AM
#276
1963 22' Safari
State of
We received more rain in the last 24 hours than we’ve had combined since May. I knew I’d have some leaks around the door since it’s not finished up yet but found a few small leaks that I took care of today. Mostly missing or loose rivets. Here’s one in the end cap I took down today.
With all the aluminum rot I found from moisture I decided I didn’t want fiberglass in the walls so I went with the foil bubble insulation. 3 layers on the ceiling 2 on the walls. I had a space heater going this morning to take the edge off and
All the wire except the water pump and water heater (which run down below) have been roughed in.
This afternoon I’ll rivet in the rear drip cap then can insulate the rear end cap. It’s in great shape compared to what I dealt with up front.
Now I need to order motors for the roof vents. Both are 110 but I want to run 12 volt so we can run them if need be without hookups.
Anybody know a good source?
Scott & Megan
10-22-2017, 02:23 PM
#277
1966 22' Safari
Fredericksburg
Attachment 297520
Attachment 297521
Attachment 297522
Attachment 297523
Scott, we found 12v motors at etrailer.com. They had a VentLine
BVD0128-00 12v that I needed for the sidewall kitchen vent. Don’t remember what the CFM was, but felt it was more than adequate. Their motors are interchangeable for roof vents. We also purchased the fan blades that fit their motor shaft. Good luck, Bubba
10-22-2017, 03:28 PM
#278
1963 22' Safari
State of
Looked at that, do you have to use the plastic fan blade? Since I'll have the skylights cut those fan blades are front and center. Inland RV has one on their site but once again the shaft size is wrong and they sell a plastic fan blade.
Scott & Megan
10-23-2017, 08:49 AM
#279
1958 18' "Footer"
Idyllwild
You may not like what my solution was but take a look at post #119. They also have a 2 speed in the same configuration. This has a different noise but with a reversible fan it makes it very comfortable inside.
http://www.airforums.com/forums/f106...-122678-9.html
10-23-2017, 04:17 PM
#280
1963 22' Safari
State of
Huston we have a problem. I pulled apart the front inside cap to start making copies and realized 3 bad panels are compound curved. Anyone with English wheel chops want to be hired out to make me replacements? They are shippable.
I do have some 63 exterior end caps I can cut them out of but I had hoped to save those in case our 63 Around the World Caravan trailer had problems down the road
Scott & Megan
