Old 12-05-2017, 07:54 AM   #323
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Take a look at my Post #16 because it shows the original toilet
But then look at #81 because it shows my modifications to the holding tank and has the fitting removed. I The fitting was a weld in female pipe fitting that was glassed in.
I couldn't find any repair parts at the time & decided to replace my toilet simply because I didn't want to have to deal with that while camping.
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 12-05-2017, 06:39 PM   #324
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Thanks for the pictures! You don't happen to still have that fitting do you?
I've been looking at the valve, it looks in good condition, the gasket at the flap looks dry but I think I can get a buddy with access to a hobby style laser cutter to make me a copy. I'm thinking of trying to polish, or at least burnish the base and leave it raw aluminum. I like that we can control how much water goes in the bowl, versus the combined flush and dump valve on the modern ones. I do have concerns about the flush valve so if anyone has a spare I'd be interested in picking one up.
thanks!
As a minimum I can find a weld on or floor flange and mount that to some stainless and bolt on with a good tank sealer.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
wally:Restoring Wally Byam's 1955 26' European Caravan Trailer![/COLOR]
goransons is online now   Reply With Quote
Old 12-06-2017, 07:41 AM   #325
1958 18' "Footer"
I'll look but it will take a few days, pretty sure I tossed it when nobody wanted the toilet or other parts
Steve
Old 12-06-2017, 06:32 PM   #326
goransons's Avatar
1963 22' Safari
Thanks!
Itís been a frustrating week. All backwards motion. This past weekend I stripped the paint carefully off the sliding Formica over Masonite doors, but then realized the plastic was discolored from the spray paint and stickers. I went back and forth about new vs original but we couldnít live with the staining. I didnít notice it until they were up and I had better light After trying everything I decided to go ahead and paint them a close color to the original Formica.
The last two days they were carefully prepped then painted again
Tonight I installed them. I have to touch up the cabinets themselves since they only had one coat on the outside due to the riveting to install. I liked it overall though, but..
I Click image for larger version
I quickly discovered that the formica served an important function. Due to how thin the doors are, they flex and they rub against each other at times. The Formica can handle the rubbing, the painted surface canít. It scuffs. Soooo I wasted 4 evenings of work but learned something. When I make the front counters I will buy enough laminate to remake all 5 upper cabinet sets of doors in as close a laminate as I can find.
Scott & Megan
Old 12-10-2017, 09:16 PM   #327
goransons's Avatar
1963 22' Safari
I was able to get a lot accomplished this weekend.
First off my preway stove search is complete. Lots of cleaning but I have a good one now.
I sanded the floors, and did some second applications of filler on elevator bolts where the filler shrank a little. Iíll get to sanding again tomorrow.
The last of the holes up front are patched and primed. The last roof locker was stripped to bare metal, primed and painted today. It was the worst one because of the heat from the wood stove they had under it.
The power is on! Itís great to have outlets and lights finally.
Iíve decided to install the tub completely before the cork goes in to avoid the aluminum skirting from possibly scraping the floor.
Test fitting.
All the aluminum needs to be sanded and painted this week then I can assemble, Mark for the drain and get it all fastened in place.
Is it black? I canít tell. Itís dark for sure. Looks very close to the same darkness as the black cabinet knob.
Scott & Megan
Old 12-13-2017, 06:12 PM   #328
goransons's Avatar
1963 22' Safari
FOUND!! Wally Byam's '55 Cruiser - 1956 European Caravan trailer
The little stuff takes so much time. Three nights this week after work paint stripping layer upon layer of paint off the divider wall channels. Cleco’ing in place as I finish them. Not a one reaches the floor. All bottoms are inside cabinets or under beds. Still funny to me. I wanted to get these in and measure out the floor plan so I can run the same tile pattern. I’ve almost finished stripping the tub trim too then I can prime and paint that and install it for good then tile can start this weekend.
Tomorrow I pick up $1000 worth of reproduction custom made leaf springs, shackles, and greasable shackle bolts and new u bolts. I know I could have gone to torsion, and on most any other trailer I would... but not on this one.
Scott & Megan
Old 12-14-2017, 03:21 PM   #329
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Excellent work!
Cochese is offline   Reply With Quote
Old 12-15-2017, 12:02 PM   #330
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Youíre attention to detail is amazing,
Iíve restored a few cars and itís easy to find pictures and unrestored original cars to look at and see how they were built. Youíve got a much more difficult task working from pictures and youíre doing an incredible job of it.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 12-15-2017, 10:08 PM   #331
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
Just catching up to your progress and Iím absolutely amazedóprobably one of the most impressive restos on this site which is saying something.
So bummed about your fridge. Have you considered shimming up and raising the surrounding galley cabinets and fixtures to accommodate it? Of course being 10+ inches taller than what you were thinking the difference might be too much to overcome, but thought Iíd throw it out there. Hate to see all your work go for naught!
calais66 is offline   Reply With Quote
Old 12-15-2017, 10:42 PM   #332
2007 27' Safari FB SE
Forest Grove , Oregon
By far the best post going on this forum in my opinion. Just weighing in so I don't miss any updates. I only dream that I could do what is being done to this trailer.
bweybright is offline   Reply With Quote
Old 12-16-2017, 09:56 AM   #333
goransons's Avatar
1963 22' Safari
Wow guys thank you. I appreciate it. Unfortunately going taller with the cooktop wouldnít allow a usable surface to cook without a foot stool. Now I just hope to find a buyer for the wrong one!
Iím heating the trailer this weekend with the cork inside to finish acclimating it for install this week
In the meantime I am cleaning the shop getting ready to into cabinet rebuild mode.
One cabinet that was virtually complete I really want to save is the wardrobe that shares the tub plumbing. The tub side still had its original laminate, just one coat of paint. I thought perhaps the paint stripper discolored the laminate doors so I tried a straight razor on this panel. Same issue. The lighter color is where the paint had flaked off. The darker is where I did the scraper. The question is what in the environment took off the brown that strippers and scrapers donít. I would think maybe UV but the windows were boarded up with plywood. Any thoughts? Iíve got to figure out something. I donít want to throw this piece away.
Scott & Megan
Old 12-17-2017, 06:21 PM   #334
goransons's Avatar
1963 22' Safari
After trying every cleaner in the garage I had I decided to try and bleach the panel. I tried some toilet bowl gel with bleach. I figured it would stay wet longer. After 4 hours I scrubbed it again and wiped it clean. I scraped the paint off the lower half. I hadnít done everything up above but the test was successful enough Iíve recoated and will let it soak over night. Itís in my shop with good ventilation. The gray is the original color, dark brown stained and the lighter brown after one treatment. Keeping my fingers crossed.
Tomorrow night I should have an update on the cork floor which starts tomorrow morning.
Scott & Megan
Old 12-18-2017, 03:10 PM   #335
goransons's Avatar
1963 22' Safari
Cork going down. Itís remarkably easy to install but very time consuming to come up with a nice mix of all the variety of shades.
Contact cement down
Almost dry.
Main traffic pattern in
I just finished putting glue down on the other areas, and moved my stacks (they need to be flat anyway). Tonight Iíll install the last full tiles. Tomorrow morning I can cut the edge tiles and install those.
Scott & Megan
Old 12-18-2017, 04:23 PM   #336
goransons's Avatar
1963 22' Safari
All the full tiles down.
Scott & Megan
1955, 1956, cruiser, european caravan, full monte, wally byam, wbcci
Wally Byam Holiday :: 1954 Airstream Byam Holiday macatak60 Airstream Registry Discussions 0 08-09-2015 08:02 PM
The 1956 European Caravan Ted S. Airstream Lifestyle 0 09-22-2014 06:22 PM
1956 Jan 11th - Monterey Mexico Wally Byam Trailer Caravan waharknesscaravans Airstream History 3 02-15-2010 07:32 PM
