Go Back   Airstream Forums > Airstream Community Forums > Our Community > Airstream History
Old 10-16-2017, 11:11 PM   #267
57Vintage's Avatar
1957 26' Overlander
Battle Ground , Washington
Images: 21
If you have to grind the shaft off to get the knob off, consider having it put back on with a gas torch and brass rod. An alternative may be TIG with silicone bronze. I'd check with your welder first for his thoughts.
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-20-2017, 12:50 PM   #268
Central , Mississippi
Originally Posted by HiHoAgRV View Post
If you decide to use a brass dump valve, consider pulling out the guts and sandwich a modern valve above it. It would still 'look' correct except for the period correct dribble that brass valves come with. I think I have a brass one or two in my junk pile.
Here is all the junk I have.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 10-20-2017, 02:17 PM   #269
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
I've got a magazine rack
This is a pic before I cleaned it up, but now it looks shiny and new, and I'm not going to reinstall it in my refurb. If you PM me with your address I'll send it to you, no charge. Happy to know it's going to go in such a cool trailer.
DDickey
1957 Custom
Link to my renovation: http://www.airforums.com/forums/f44/...cy-150509.html
DDickey is offline   Reply With Quote
Old 10-20-2017, 02:53 PM   #270
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
That would be amazing!! Thank you!! Sent you a pm. Iím happy to buy and cover shipping!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 10-20-2017, 02:54 PM   #271
goransons's Avatar
1963 22' Safari
Iím interested in the valve and one of each of the types of fittings. Let me know what youíd like for them and I can send money your way!
Thank you!
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-20-2017, 08:51 PM   #272
Thank you!
A pal sold a race car...
$2000, car and spare parts. $3000 for just the car.
$100 for each part but if you take it all, it's free.
PM me an address.
Old 10-20-2017, 09:40 PM   #273
1966 22' Safari
Fredericksburg , Texas
[QUOTE=HiHoAgRV;2024409]A pal sold a race car...
PM me an address
I like your reasoning. I would think Scott does too.
Bubba
Bubba L is offline   Reply With Quote
Old 10-21-2017, 10:36 AM   #274
goransons's Avatar
1963 22' Safari
I really do appreciate the help! Purists be warned I will not be replicating the wiring methods. Click image for larger version
ID:	297422Click image for larger version
Pouring rain today. Found a couple minor drips but incredibly dry inside so Iím insulating the street side and running new 110 and 12 volt wire.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-21-2017, 10:56 AM   #275
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thank god, I hope not. Found the same thing rewiring my 1954 Liner.
Bill
I really do appreciate the help! Purists be warned I will not be replicating the wiring methods. Attachment 297422Attachment 297423
Just my personal opinion
Old 10-22-2017, 12:57 PM   #276
goransons's Avatar
1963 22' Safari
We received more rain in the last 24 hours than weíve had combined since May. I knew Iíd have some leaks around the door since itís not finished up yet but found a few small leaks that I took care of today. Mostly missing or loose rivets. Hereís one in the end cap I took down today.
With all the aluminum rot I found from moisture I decided I didnít want fiberglass in the walls so I went with the foil bubble insulation. 3 layers on the ceiling 2 on the walls. I had a space heater going this morning to take the edge off and
All the wire except the water pump and water heater (which run down below) have been roughed in.
This afternoon Iíll rivet in the rear drip cap then can insulate the rear end cap. Itís in great shape compared to what I dealt with up front.
Now I need to order motors for the roof vents. Both are 110 but I want to run 12 volt so we can run them if need be without hookups.
Anybody know a good source?
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-22-2017, 03:23 PM   #277
1966 22' Safari
Attachment 297520
Attachment 297521
Attachment 297522
Attachment 297523
Scott, we found 12v motors at etrailer.com. They had a VentLine
BVD0128-00 12v that I needed for the sidewall kitchen vent. Donít remember what the CFM was, but felt it was more than adequate. Their motors are interchangeable for roof vents. We also purchased the fan blades that fit their motor shaft. Good luck, Bubba
Old 10-22-2017, 04:28 PM   #278
goransons's Avatar
1963 22' Safari
Looked at that, do you have to use the plastic fan blade? Since I'll have the skylights cut those fan blades are front and center. Inland RV has one on their site but once again the shaft size is wrong and they sell a plastic fan blade.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-23-2017, 09:49 AM   #279
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
You may not like what my solution was but take a look at post #119. They also have a 2 speed in the same configuration. This has a different noise but with a reversible fan it makes it very comfortable inside.
http://www.airforums.com/forums/f106...-122678-9.html
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 10-23-2017, 05:17 PM   #280
goransons's Avatar
1963 22' Safari
FOUND!! Wally Byam's 55 Cruiser - 1956 European Caravan trailer
Huston we have a problem. I pulled apart the front inside cap to start making copies and realized 3 bad panels are compound curved. Anyone with English wheel chops want to be hired out to make me replacements? They are shippable.Click image for larger version
I do have some 63 exterior end caps I can cut them out of but I had hoped to save those in case our 63 Around the World Caravan trailer had problems down the road
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
1955, 1956, cruiser, european caravan, full monte, wally byam, wbcci
Wally Byam Holiday :: 1954 Airstream Byam Holiday macatak60 Airstream Registry Discussions 0 08-09-2015 09:02 PM
The 1956 European Caravan Ted S. Airstream Lifestyle 0 09-22-2014 07:22 PM
1956 Jan 11th - Monterey Mexico Wally Byam Trailer Caravan waharknesscaravans Airstream History 3 02-15-2010 08:32 PM
Popular Campgrounds
