Old 10-01-2017, 02:11 PM   #239
1994 30' Excella
Mississauga , Ontario
I'm impressed with your ambition.! That is a lot of work
Al and Jean
TAC ON-3
BigAl is online now   Reply With Quote
Old 10-01-2017, 02:14 PM   #240
Central , Mississippi
I find it interesting that this trailer had splice in the side panel. I'd seen such in 30' vintage but yours is shorter. Great looking work!!!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-01-2017, 02:20 PM   #241
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Thanks guys. Yes lots of body splices. About a 7 foot panel then the longer on the street side, seemed just in front of the wheel well. On the curb side seamed at the same point. What I find most odd is the 4' piece that goes from the mid point seam just above the base of the windows all the way over the roof and down the other side. Click image for larger version
ID:	295980Click image for larger version
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 10-01-2017, 08:49 PM   #242
goransons's Avatar
1963 22' Safari
A few things to sort out now that I'm almost closed in for the winter.
1. I'm still trying to figure out the black tank situation.
Can you really run a black tank with no vent of any kind? I feel I need to add a vent or the tank would either offgas through the toilet or worse yet not offgas and balloon up. To add a vent I'll have to work a pipe up the wardrobe and install a vent on the roof. To be faithful to the era I need to find one of those eyebrow type sewer vent covers.
While looking at pictures to confirm details on the panel I replaced today I noticed that there appears to be no black tank valve, could it have really just been a cap of some type? I don't see any type of fitting area there for a hose to attach, unless it was a very compact type of valve, no handle visible to drain it either.
Also I need to find a back bumper, or at least good bumper ends I can weld on and reuse the rest. No shops locally seem to even want to try bending some for me, they just don't have the tools to do it. I'd like to get that welded so I can finish painting the last of the frame and finish up those details but am at a loss on what to do unless someone on the forums has some suggestions! Thanks!
ID:	296017   Click image for larger version
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-02-2017, 12:23 AM   #243
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
FOUND!! Wally Byam's 55 Cruiser - 1956 European Caravan trailer
One option would be to get a composting toilet like an Airhead. Of course, that would definitely not be period appropriate, but you wouldn't have to worry about a black tank or putting a hole in your roof.
calais66 is offline   Reply With Quote
Old 10-02-2017, 07:19 AM   #244
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Looks like the street side bumper end is already missing in the top photo (from about 1957?). Could that small rectangular vent panel have been the black tank vent? Or a gray water vent?
I looked at the full original photo and agree I cannot see a dump valve, but do see a round hole or cap below where the toilet would be located. I can't imagine having a tank with no dump valve, but maybe nothing existed at the time.
Would not be pleasant to remove the cap if the tank had "contents". I assume you'll have to add a valve somehow. Most proper likely would be the 2" brass valve that was first used in the late 1950s, but you might be better to just put a modern valve on?
I wonder when the first black tank valve was used in an Airstream. That is not a detail I have researched.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 10-02-2017, 07:24 AM   #245
goransons's Avatar
1963 22' Safari
I thought that at first too but the tire brackets for the Solex are offset to the street side so that the handle bars and seat don't block the tail lights. The street side bracket actually wraps the corner and is still there somewhat.
The vent at first I figured was but here's the odd one, there is nothing there behind it. A 3" diameter hole but no plumbing, no electrical. It's inside a cabinet with no holes drilled in it for any type of pipe. It's a mystery for sure. I thought about venting out that existing hole but worry sewer gasses wouldn't be high up enough not to find their way back in our windows or windows at a neighboring trailer. Not sure how to proceed.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-02-2017, 02:27 PM   #246
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Really enjoying watching your work, wish I had something to contribute but for now I'll just observe and learn
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 10-02-2017, 05:15 PM   #247
If you decide to use a brass dump valve, consider pulling out the guts and sandwich a modern valve above it. It would still 'look' correct except for the period correct dribble that brass valves come with. I think I have a brass one or two in my junk pile.
Old 10-02-2017, 06:07 PM   #248
goransons's Avatar
1963 22' Safari
That's actually a really good idea! I'm thinking I can put in a cable operated valve right below the plywood, then could put that below. I used to have several of the fittings that attach to the flex hose, but gave them away years ago as "who would ever need one of those". Let me know what you have it might be cool to just use it as an attachment point, eye candy of sorts..
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-09-2017, 04:57 PM   #249
goransons's Avatar
1963 22' Safari
Here's a look from the underside of the bath tub. As I sanded off the latex paint I noticed a failed repair. The patch is gone but now I wonder what the best solution is. It's not fiberglass. It's a very flexible plastic that has a black core and a thick cream colored outer layer inside and out. Looks to have been vacuum formed.
I'm open to suggestions. I want to get it repaired and painted before my shop is too cold to paint in.
Also the last big panel bucked in this weekend
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-09-2017, 06:09 PM   #250
1966 22' Safari
Fredericksburg , Texas
Scott, to me that patch material looks like hypalon fabric. I used it about thirty years ago as a roofing material. Nowadays it's used to patch canoes and inflatables. It is flexible and conforms to shapes. If I remember, it was about 40 mils thick. Also, we got our front jalousie installed and operational. Turns out the glass panes weren't green tinted, they were blue tinted. The glass guy said blue tinted was no longer available. We were missing two, so we placed a green tinted on top and one on the bottom. Not really noticeable. Good luck, Bubba.
Bubba L is offline   Reply With Quote
Old 10-09-2017, 06:28 PM   #251
57Vintage's Avatar
1957 26' Overlander
Battle Ground , Washington
Images: 21
tub repair
Is there an area on the tub where you can borrow a scrap slightly larger than the hole? I'd epoxy that from the bottom side with JB Weld. The old style 2 part. It is set in a day and is sandible. Let it set then fill in from the other side with more JB Weld, then feather sand it in.
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-09-2017, 06:38 PM   #252
65CV's Avatar
Western , Massachusetts
Scott,
I've done multiple repairs with West Systems Epoxy and am a firm believer. They now have a plastic-friendly product called G/Flex that I've used on repairs without a failure yet. If you search around their site, they have multiple tests on different materials. If you don't know what yours is, I'd consider a mix of techniques -- 80 grit sanding and a heat gun. Then, use the G/Flex with fiberglass cloth as the usual West Systems stuff recommends.
Hope it works. PM me if you want to talk it through.
John
65CV is offline   Reply With Quote
1955, 1956, cruiser, european caravan, full monte, wally byam, wbcci
Wally Byam Holiday :: 1954 Airstream Byam Holiday macatak60 Airstream Registry Discussions 0 08-09-2015 08:02 PM
The 1956 European Caravan Ted S. Airstream Lifestyle 0 09-22-2014 06:22 PM
1956 Jan 11th - Monterey Mexico Wally Byam Trailer Caravan waharknesscaravans Airstream History 3 02-15-2010 07:32 PM
