Old 08-18-2017, 02:55 PM   #197
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
FOUND!! Wally Byam's 55 Cruiser - 1956 European Caravan trailer
Well I finished up the cuts and prep for the rest of the welding this weekend. Tongue was painted with 2 coats of por-15 yesterday and top coated with 3 coats of Alpine White.
Tongue jack is a day behind but it's been stripped, desmantled and por-15'd and will get its top coat tomorrow. Hoping for shell touchdown on the new plywood on Monday.Click image for larger version
ID:	292595Click image for larger version
ID:	292596Click image for larger version
ID:	292597Click image for larger version
ID:	292598Click image for larger version
ID:	292599Click image for larger version
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
wally:Restoring Wally Byam's 1955 26' European Caravan Trailer![/COLOR]
goransons is offline   Reply With Quote
Old 08-18-2017, 03:05 PM   #198
1967 17' Caravel
Is the hinge material the same stuff used on the over bin doors (aka circa 1967)? If so, I have some. PM me.
Originally Posted by goransons View Post
My summer is quickly disappearing. I test fitted the front plywood and sealed the edges with epoxy. We have more welding to do before we can install it for good. Felt nice to have it in place a bit.
Attachment 292437
I'm two clips short of being able to put glass back in. I did my best with some scrap 2024 but it's a little brittle and cracked in the corners. So I'm going to try some other kinds. Here was my first attempt (which wasn't good enough for my taste). I've since made a better template of the old one but didn't bother using the same material again.
Attachment 292441
FYI these weren't Hehr windows. They use 3" clips for the glass and springs to hold it in. If anyone has a donor window I'd be real interested.
While I was at it I made up a new refrigerator access door. I realized the inner hinge has a crack. Anyone have about 10" of this laying around?
Attachment 292442Attachment 292443
Attachment 292444Attachment 292446
David F is offline   Reply With Quote
Old 08-18-2017, 04:39 PM   #199
goransons's Avatar
1963 22' Safari
Sent you a private message. I don't know if it's the same but sent you measurements. Thanks for offering!
Scott & Megan
Old 08-18-2017, 05:35 PM   #200
Central , Mississippi
My '63 has 3" non-hehr windows. Is your trailer a California build also?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-18-2017, 05:52 PM   #201
goransons's Avatar
1963 22' Safari
Yes it is! Our 62 had the same windows
Scott & Megan
Old 08-18-2017, 09:30 PM   #202
goransons's Avatar
1963 22' Safari
I'm working with vintage trailer shop on replacement top and bottom weatherstrip. If he can't find something that fits right he's going to have some made. I have one apart with a good piece for him to copy.
I'm dealing with one window that is missing everything. I have almost all the clips I need but the donor window is one clip shorter, so I'm trying to recreate that springy metal riveted under the clips. I just picked up a metal mini-blind and am trying to cut it down. It's the right gauge and feel and already has a slight radius to it. I'm not going too far into reassembly until I know better on the weatherstrip issue.
Scott & Megan
Old 08-20-2017, 08:15 PM   #203
goransons's Avatar
1963 22' Safari
4 1/2 hours of professional welding and the front 8 feet is done. Some wire wheel work tomorrow and por-15, then spray the step Tuesday and finally I get to bolt in some plywood!!
ID:	292805Click image for larger version
Scott & Megan
Old 08-21-2017, 11:36 AM   #204
goransons's Avatar
1963 22' Safari
Second coat of Por-15 on. White top coat on the step tonight. Click image for larger version
ID:	292887Click image for larger version
ID:	292888Click image for larger version
Scott & Megan
Old 08-21-2017, 09:28 PM   #205
goransons's Avatar
1963 22' Safari
Got some paint on today! Tomorrow the first two sheets go in. Click image for larger version
I can't wait to get the front down finally!!
Scott & Megan
Old 08-22-2017, 11:05 AM   #206
goransons's Avatar
1963 22' Safari
ID:	292957Click image for larger version
It's in! Elevator bolts next. Boy the shell likes sitting on plywood.
Scott & Megan
Old 08-22-2017, 05:30 PM   #207
goransons's Avatar
1963 22' Safari
I'm really excited that I found 2 sconces very close to the originals out of 57 overlander, now I need to find one more but good progress! Anyone got one? Click image for larger version
ID:	292982Click image for larger version
Scott & Megan
Old 08-23-2017, 12:37 PM   #208
goransons's Avatar
1963 22' Safari
Today was an exceptional day of work. I removed 8 feet of floor and found good steel everywhere. Interesting means of lightening the trailer. 2 cross members are just angle iron with one having an aluminum spacer of sorts to attach the belly pan to then 2 normal steel, then two more small with one having aluminum. Cleaned it up and por-15'd. Some minor wheel well repair on the curb side and more floor can go in. Used up the last little paint on the axles but they will come out for new springs and hardware and will get the full treatment this fall Click image for larger version
ID:	293065Click image for larger version
ID:	293066Click image for larger version
ID:	293067even some original paint!!
Scott & Megan
Old 08-23-2017, 03:47 PM   #209
goransons's Avatar
1963 22' Safari
ID:	293079Click image for larger version
3 in 1 about ready and 2 to go. But first I can now bolt in the front, replace the 2 panels, and rebuild a few windows and vents.
Scott & Megan
Old 08-23-2017, 09:44 PM   #210
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Looks like you didn't epoxy the edges on the 3rd sheet. Was that intentional?
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
1955, 1956, cruiser, european caravan, full monte, wally byam, wbcci
Wally Byam Holiday :: 1954 Airstream Byam Holiday macatak60 Airstream Registry Discussions 0 08-09-2015 09:02 PM
The 1956 European Caravan Ted S. Airstream Lifestyle 0 09-22-2014 07:22 PM
1956 Jan 11th - Monterey Mexico Wally Byam Trailer Caravan waharknesscaravans Airstream History 3 02-15-2010 08:32 PM
