Old 06-12-2017, 07:06 PM   #127
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I did some more careful paint removal/exploration on the country list panel. The trailer just have 10-15 coats of paint, the last few with a roller. In some areas the paint was so thick it has cracked and fallen off to bare aluminum. I did find part of the "R" most of the "O" and part of the "P" from "Europe". Click image for larger version
ID:	287420for comparison.
And traces of the Wally Byam Caravan sticker.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
wally:Restoring Wally Byam's 1955 26' European Caravan Trailer![/COLOR]
goransons is offline   Reply With Quote
Old 06-13-2017, 06:39 PM   #128
goransons's Avatar
1963 22' Safari
Another afternoon of stripping paint. I've realized the end caps clearly leaked and were painted with cool seal or something similar. The sides aren't which is great. BUT 3 or more afternoons and I hopefully will have a clean front cap. As you can see inside leaked. I removed the patches to try to id original plumbing and gas holes. Not much of a help! I also removed the nasty patches around the rear marker lights. Thankfully they don't serve much of a purpose and I can reuse both rear corners with just a few extra rivets to fill holes.
ID:	287509Click image for larger version
ID:	287510Click image for larger version
Scott & Megan
Old 06-13-2017, 07:10 PM   #129
goransons's Avatar
1963 22' Safari
Mysteries being solved
Joe found a picture of a young lady in the doorway that showed a hint of a wall furnace behind her. We have a contact with a forums member in the LA area with an interior we plan to pick up this fall from a 55 and it has the same type of heater in great shape (as pictured). The holes in the ceiling make sense, an oval hole for the furnace vent, and a round hole for the exhaust on the refrigerator and signs of the wall dividers on the wall for a narrow bulkhead to hide it. I also removed the patches up front as mentioned in the previous post and found where the gas lines came up.
Blue is where the refrigerator gas line came up through the floor, and red is where the heater gas line came up. Once the stripping is done up front I'm going to remove the inside skins, and front inside end cap for repairs and panel replacement (4 of the 9, yes 9 upper interior segments are completely rotted away but they are flat material. While it's out I can repair the rotted outer metal and seal it all up, rebuild the front window and install a front hold down plate that wasn't there at all. I know it's not original and I intend to keep it original but I don't want the front pulling apart like it did a very long time ago. This trailer has a lot of butt behind the axles.
Name:	Wally's Europe Trailer and Bikini Girl.JPG
ID:	287513   Click image for larger version
ID:	287515   Click image for larger version
Scott & Megan
Old 06-13-2017, 11:19 PM   #130
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
When you come down for the parts we've discussed, bring the dimensions, specs for that heater, I may have some of the mechanical parts for it. I'm updating to a suburban furnace that is hidden under the frig, but keeping the heater grill to hide all the updated electrical controls/monitors.
Harold
57Vintage is offline   Reply With Quote
Old 06-14-2017, 09:00 AM   #131
goransons's Avatar
1963 22' Safari
Thanks Harold! I'm planning on heading that way towards the end of next week. I'll see what I can find out about the heater before then!
Scott & Megan
Old 06-14-2017, 07:26 PM   #132
goransons's Avatar
1963 22' Safari
More stripping this afternoon. It's getting better every day. Still a lot to do on the front cap. While removing the added roof vent for a fridge that someone added I realized that the front kitchen had bulkheads on both sides with lights under. On the curb side they added a vent where the electrical box was. Click image for larger version
ID:	287596Click image for larger version
ID:	287597Click image for larger version
Scott & Megan
Old 06-24-2017, 12:38 PM   #133
goransons's Avatar
1963 22' Safari
Getting there! A couple more hours tomorrow morning and the front end cap segments will be stripped. Then in mornings I will continue to work my way around the lower front and at least back to the wheel well. Tomorrow afternoon I'm going to pull the front inner sheet metal and prep the upper outer cap for repair.
Scott & Megan
Old 06-24-2017, 12:39 PM   #134
goransons's Avatar
1963 22' Safari
ID:	288088Click image for larger version
ID:	288089Click image for larger version
Scott & Megan
Old 06-24-2017, 05:32 PM   #135
Central , Mississippi
That's looking much better!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-24-2017, 07:39 PM   #136
goransons's Avatar
1963 22' Safari
Thanks! It's slow for sure, 1 1/2 segments cleaned up in 3+ hours. The layers as best I can tell
1. green etching primer
2. gray sealer
3. original paint color (tough paint too, I wonder if it wasn't aircraft paint)
4,5,6?? various similar shades
almost top coat seems to be the cool seal rv roof sealer, put on with a brush I think
top coat is silver spray paint.
I've used almost a gallon of Aircraft stripper on just the upper front end cap segments. The good news is the sides don't seem to have as many layers, I'm guessing the front leaked a lot or was beat up going down the road a lot and kept getting new paint.
The 4" round hole was from a vent they added for the refrigerator at some point. It's going to get patched. I'm thinking I'll do a round patch slightly larger then just fill the old screw holes with rivets, unless people think it will look better with a bigger patch using the old holes...
Scott & Megan
Old 06-24-2017, 09:34 PM   #137
If you want to plug an old hole, look into flush rivets. They can disappear when painted.
Old 06-25-2017, 02:11 PM   #138
goransons's Avatar
1963 22' Safari
I did more paint stripping today. Most of the time was detail work on the end cap segments do no great pictures. I did try a garbage bag over the chemical to let it soak in longer without evaporating. Helped some. The door is going to take some work!
I was successful in removing the salvageable half of the inner cap, and the half that is going to be used for patterns. The damage to the cap was from water, the area was packed full of insulation and it was all wet.
I cleaned a lot on the inside surface with sand paper, wire wheel and the like and treated it with baking soda just in case something is eating at it.
Tomorrow I'll do a final cleaning, install the adhesive mesh and put on a coat of the epoxy panel adhesive.
Scott & Megan
Old 06-25-2017, 02:12 PM   #139
goransons's Avatar
1963 22' Safari
ID:	288167Click image for larger version
ID:	288168Click image for larger version
ID:	288169Click image for larger version
Scott & Megan
Old 06-25-2017, 02:46 PM   #140
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Or, make a flush patch
You might consider a flush patch--round piece of aluminum the exact size of the hole with a larger backing piece inside, all secured with flush rivets. That will disappear with a tiny bit of filler and then paint.
1955, 1956, cruiser, european caravan, full monte, wally byam, wbcci
Wally Byam Holiday :: 1954 Airstream Byam Holiday macatak60 Airstream Registry Discussions 0 08-09-2015 09:02 PM
The 1956 European Caravan Ted S. Airstream Lifestyle 0 09-22-2014 07:22 PM
1956 Jan 11th - Monterey Mexico Wally Byam Trailer Caravan waharknesscaravans Airstream History 3 02-15-2010 08:32 PM
