Old 07-17-2008, 03:04 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Did I find a '62 from a World Caravan?
I just got this 62 Ambassador with a bunkhouse layout and have noticed a couple of things I'm curious about. I has sat for years and if everything is not origiinal at least it is old.
First, along with the other ID plates next to the door there is a plate riveted to the coach stamped 1964 that says "NAN Automobiles Bombay, Calcutta, Delhi.
Second, the bumper is extended with framwork welded on for not one but 2 spares. Could this old girl have been on a Wally Caravan in India in 1964?
I can't find any trace of red numbers as the whole trailer has been painted white but the serial number is 28TSSO306.
Earlier i posted a dozen photos under the new thread I started "My Fugly 62 Ambassador Bunkhouse" (which was also the first forum thread under the 62 Ambassor heading in the knowledgebase. For some reason I don't understand
the thread did not make it past the knowledge base to the "lastest discussiion listing, so I will post a few more photos below.
Old 07-17-2008, 03:17 AM   #2
Lumatic's Avatar
1993 34' Excella
Images: 16
Notice the double level side windows that match up with the bunks. She also has hydraulic brakes with what looks like an actuator
ID:	63877   Click image for larger version
ID:	63879   Click image for larger version
Old 07-17-2008, 05:34 AM   #3
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Nice find! I hope you are able to find out the history of the trailer, especially regarding the caravan. Post some interior pics when you get a chance.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 07-17-2008, 06:22 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Interior Shots
Here ya are pard
ID:	63894   Click image for larger version
ID:	63896   Click image for larger version
Old 07-17-2008, 06:33 AM   #5
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
BULLS GAP , Tennessee
Nice find. If you get a chance, post the pic of the selling dealer's logo.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 07-17-2008, 06:41 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Dealer Logo
The only thing I have seen that looks dealer is the plate I mentioned above that says "NAN Automobiles Bombay, Calcutta, India and is stamped with a 1964 date. It is painted over white, as is the whole exterior, and would not photgraph well.
I need to do some experimentation to figure out how to strip the white and leave the stuff underneath intact. Any suggestions?
The good news is no silicone worries. A PO used thick drippy tar instead.
Old 07-17-2008, 07:05 AM   #7
I think you could use the same products that folks are using to strip clearcoat, and take the same precautions (tape over taillights, markers, etc.). RemoveAll is one of the popular choices, but there are many others.
Old 07-17-2008, 07:13 AM   #8
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That is one unique trailer. Obviously, the tongue was extended and the tanks moved outside the A frame but I wonder what the purpose was. Maybe to have increased access to the rear of the tow vehicle. Another odd set-up is the scare lights, there's one on each end and on on each side. Somebody was really paranoid or was planning on taking the trailer to really dark places.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-17-2008, 07:39 AM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
Special Features
FF
The only time I saw an extended tongue like this was a guy who mounted a genny. He said it made it track better too. Who ever did this did a real good job or it is factory special order. Could also be for a 3rd or 4th spare tire as the propane lines between the tanks are arched maybe to clear the spares. Did you also notice the 2 exterior mounted tractor batteries on the rear end?
Old 07-17-2008, 09:01 AM   #10
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Ohhhh, if only these babies could talk, the stories they would tell!
It'll be fun to see what unfolds as you go along ~
I would try a mild paint stripper to see if you can remove the white overcoating on the plates...something like Goof-Off or Motsenbocker's Lift-Off. Do you know if it is a latex or automotive-type paint?
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 07-17-2008, 09:13 AM   #11
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Did I find a 62 from a world Caravan?
Greetings Lumatic!
While this is not definitive evidence, I did check my copy of the WBCCI Caravan DVD compiled by the Vintage Airstream Club. A trailer very similar to the one that you have purchased did participate on the Around the World Caravan. This is what I discovered while watching the segments on the 1963-1964 Around The World Caravan:
  • India -- Part II Segment
    • A Bunkhouse coach appears early in the segment as well as toward the end.
    • The furnace flue is in the same location.
    • The curbside scare light is in the same location.
    • There is damage on the curbside just below where the segment curves into the roof.
    • There is an air conditioner or swamp cooler on the roof.
    • The tow vehicle appeared to be a white or light color Ford 4x4 pickup (standard cab).
    • The WBCCI number can be clearly seen in two scenes -- that number was #6472
  • Europe -- Part V Segment
    • The coach is again seen in two segments
    • A very good side profile can be seen when the coaches are ferried across a body of water on two barges lashed together.
  • What couldn't be clearly seen:
    • The rear of the coach was never clearly visible.
    • The front tongue area of the coach was never clearly visible.
    • The street-side was never clearly visible.
While not conclusive, this may provide some clues that may eventually help to answer the question. Fred Coldwell may have more detailed information in the history archives.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-17-2008, 11:41 AM   #12
Lumatic's Avatar
1993 34' Excella
Images: 16
Would if fit the picture that there is a dealer's plate riveted to the shell from India stamped 1963?
Who can I contact about getting a copy of that DVD?
FYI The current sellers do not know anything about the coaches history other than they bought it in Long Beach CA
Old 07-17-2008, 12:09 PM   #13
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I, too, would like a working copy of that DVD. I bought one when they first came out oh so many years ago and it never worked properly in any DVD player I've tried it in. I've yet to see much of it.
As for this particular trailer's history and mystery, I can't wait to hear if this pans out to be the one in the DVD and on the caravan.
FF
Old 07-17-2008, 12:12 PM   #14
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
FF
Brad,
Did you see the article in a recent Vintage Advantage, where Forrest described a work around for the problem?
Bill
Just my personal opinion
Around-the-World Caravan Thank You Marco Polo PeeWee WBCCI Forum 29 01-14-2011 05:05 PM
#7702 - Around the World Caravan? Lumatic Airstream History 14 01-01-2011 02:29 PM
1963-1964 Around the World Caravan Photos goransons Airstream History 10 09-14-2010 09:43 PM
Around-the-World Caravan Roster of Caravanners and Trailers PeeWee WBCCI Forum 18 08-19-2008 09:40 AM
Around-the-World Caravan PeeWee WBCCI Forum 1 09-20-2007 09:23 PM
