Old 11-16-2016, 05:39 PM   #1
Carrma's Avatar
2015 27' FB International
stow , Ohio
Canadian Trailers Back in the '70's
It was easy to spot a Canadian AS back then as they had small mudflaps installed behind the rear axle and the LP gas regulator was mounted on the front of the trailer and not on the the tanks like US trailers. They also had a different wiring harness to comply with Canadian (UL) regulations.
The mudflaps made no sense to me since the rear tires are so far forward of the rear of the trailer that even if you were driving on a gravel road it would be hard to kick up stones or rocks to the back. Guess the government finally agreed and did away with that requirement. Have seen tons of Canadian AS in FL with no mudflaps.
Carrma is offline   Reply With Quote
Old 11-16-2016, 06:02 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Got any photos to illustrate your post?
MICHAEL
Old 11-17-2016, 05:18 AM   #3
Carrma's Avatar
stow , Ohio
No photos from back then, but can sure remember the little mudflaps on the AS coming down the assembly line.
Old 11-17-2016, 07:26 AM   #4
dznf0g's Avatar
Oswego , Illinois
I have installed mudflaps on mine....keeps sand and grit from coating the dump valves and getting in the "wrap" compartments.
-Rich-
Old 11-17-2016, 11:12 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
You know, mudflaps to keep the dirt and grime off the dump valves is a great idea!
I could probably redneck tech some out of the leftover bits of rubber from the Rock Tamers.
I did make small mud flaps for my utility trailer out of leftover pieces of Rock Tamers flap because I had just painted the trailer and wanted the paint job to last longer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-17-2016, 11:26 AM   #6
Carrma's Avatar
stow , Ohio
Rich,
Never thought of the dirt and sand issue. I wonder if that is what the Canadian Gov't had in mine when the mandated them.
Mike
Old 11-17-2016, 01:09 PM   #7
dznf0g's Avatar
Oswego , Illinois
Mike, I kind of doubt it.
-Rich-
Old 11-17-2016, 01:10 PM   #8
1978 28' Ambassador
Elk River , Minnesota
This is a great idea!
tpfleg is offline   Reply With Quote
Old 11-17-2016, 07:41 PM   #9
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I made a flap and mounted it just ahead of the valves using a piece of carpet underpaid and straightened metal band from a large hose clamp to protect from wheel spray.
It has worked well all this summer. The valves are clean
I have a photo of it, but don' t know how to post it.
Trailer Trash........."
MelGoddard is offline   Reply With Quote
2017 AI back huge back TV obstructs walkway Perpich Audio, Video & TV 0 10-07-2016 11:48 AM
Back and forth, back and forth.....what 2 do??? WILDRTEXAS Upholstery, Blinds, Walls & Interior Finishes 19 11-30-2009 05:24 PM
Back-up Monitor for Travel Trailers. Inland RV Center, In Commercial Listings 67 04-15-2007 07:29 AM
Odd back-to-back eBay auctions .... summerkid Trailer Values 5 09-12-2005 12:34 PM
Canadian Model Airstream? 53flyingcloud Our Community 5 11-29-2002 05:00 AM
