Go Back   Airstream Forums > Airstream Community Forums > Our Community > Airstream History
Old 12-19-2017, 06:25 PM   #121
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Looking nice, good light. It appears the overhead lights will be head bonkers. I guess they were original equipment.
Your water heater is in the same place where mine is going. Right behind the wheel well. That is under the street side bed in my twin bed layout.
David
Old 12-20-2017, 05:41 PM   #122
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
With the vanity and other cabinets in those lights will be out of bonkers territory unless you’re a basketball player. The lights look great though!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-26-2017, 10:33 PM   #123
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Between Christmas and cold weather, there has not been a lot of progress recently. Quite a few hours over a few days have been spent trying to strip paint and varnish from the divider wall edge trims. It is slow going, but hope to finish that task tomorrow.
Changing subjects, I had registered the name "Cramer" for our ATWC Airstream many months ago on the Airstream Name Registry site at:
http://name.airstream.com/
I recently tried to find the page for our trailer on that site and found the Search function does not work, but by browsing and hitting "Show More" many, many times, I eventually found "Cramer". I was able to capture the attached screen shot.
Name:	Cramer on Airstream Name Registry.jpg
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 12-27-2017, 09:56 AM   #124
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Joe,
That is great, hope to see the Cramer in Salem.
Bill Kerfoot
Just my personal opinion
https://billbethsblog.blogspot.com/
wkerfoot is online now   Reply With Quote
Old 01-03-2018, 07:14 PM   #125
1962 22' Safari
2016 30' Classic
Images: 41
Progress continues. Have worked on something trailer related most days (except for a couple of days around Christmas) since I last posted photos. Since it's been very cold with highs in the teens pretty much every day since about December 20th, so most of my work has been in my garage and basement, rather than in the unheated storage unit where the trailer resides.
The one thing I did get done at the trailer was to install a "gate pull" handle on the inside of the door, so that it can be pulled shut without stressing the vintage Bargman inside door handle. I went with a gate pull rather than something more flashy, so that this addition is "period correct". Photo attached.
I then spend several days stripping paint and varnish from the remaining 5 wall edge trims and the metal tub surround trim, but that task was not photo worthy.
I then moved on to cabinet work, which is easily done on my basement or garage, as the task dictates. And there is A LOT of it to be done. I'm just getting started. I sanded and painted the insides of the three roof locker to freshen them up. I then began to start dealing with delaminated wood. I glued the bottom of the Bed/Tub wall and am now in the process of doing the same on the Kitchen/Bed wall that had more significant delamination at the bottom. I chose these to start, because the bottoms are hidden by cabinets after installation, so they were perfect to practice on. Photos attached.
I am dreading the coming task of refinishing all of the wood items. Getting rid of the drippy varnish that was added later is NOT going to be fun and I have to do that on every cabinet, drawer front, cabinet door, and wall. I want to deal with that in my garage rather than basement due to fumes, but I really need it to get warmer so that I can reasonably heat my garage before starting.
This thread is once again up-to-date.
Name:	Gate Pull Added to Door.jpg
ID:	301798   Click image for larger version
Name:	Roof Locker Interiors Painted.jpg
Name:	Kitchen-Bed Wall Delamination at Floor.jpg
ID:	301800   Click image for larger version
Name:	Kitchen-Bed Wall Gluing in Process.jpg
Joe
Old 01-03-2018, 07:31 PM   #126
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
A little progress every week results in .... COMPLETION
Stripping old finishes from thin, delaminated plywood is tough. That is craftsman work. I'm no good at finishes. But I'm sure your work will be spot on.
David
Old 01-04-2018, 09:12 AM   #127
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
66 question for you.
By delaminated wood I'm thinking you are describing several layers of wood near edges that has come apart or started to peel back like onion layers.
With a proper moistening process and a regluing process can wood be reshaped or encouraged to adhere back to itself.
We have some older cabinets in a 1961 that seem to be in very good shape but the bottoms may have experienced some exposure to moisture thereby having peeled back on the corners.
When we get to that project it would seem as shame to waste most of the cabinet when it's only the bottom corners that are damaged.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 01-04-2018, 10:07 AM   #128
1962 22' Safari
2016 30' Classic
Images: 41
Hi, I must say that I am new to this type of repair, but I have been encouraged about my chances for success by talking to others that have tackled these types of repairs before me.
I did not mention it, or previously post a photo, but the bottom of the Kitchen/Bath wall pictured above was pretty warped before I started the gluing process. The bottom edge was probably 1" offset from the straight part of the wall. I misted both sides of the panel and a little bit in between the layers with a spray water bottle. I then set the panel on a flat surface, wrapped the panel end in plastic to hold the moisture in, put a flat board on top, and then started adding weight, at first a little to not risk cracking the wood and not enough to get it completely flat, and then more weight as time went on and the panel seemed to straighten. Over about 24 hours, I got most of the warp out and probably could have gotten more out if I worked with water and weight longer. I eventually removed the plastic layer and reapplied the weight to allow the wood to dry straight(er). Once I removed the weight after drying, there was still a little curl, but much less than original and subsequent the glue and clamp between flat boards process has re-hardened the wall in a completely straight/flat condition.
I was intimidated before I started this part of the project, but in retrospect it does not seem like rocket science. Time will tell how long the repair will last, but I did choose a Wood Glue that was certified as "water resistant". I sanded the inner wood layers as best I could to remove old glue and dirt before applying new glue. I found that West Marine Epoxy Resin Syringes worked well to get the Wood Glue deep under the lifted top and bottom layers of the plywood (although you need to clean the glue out of them very quickly using hot water or soap and water, if you want to reuse them - I have already had to cut the tip off one that set up before I got done clamping). Once the glue was injected, I used a thin metal putty knife/scrapper to spread the glue around. I glued both the top and bottom sides at the same time. I then put wax paper on both sides and them clamped the wall between two boards to keep it straight while the glue dried.
I found the glue started to set up so quick (within maybe 3-5 minutes, but that is a guess since I was not watching a clock), such that I could only do a few inches (maybe 8" to 12") at a time. It took me three glue sessions to just get the bottom edge glued (I am now working additional glues sessions to deal with lifting up one side of the panel). Working the small area was also dictated by my not having an unlimited supply of clamps. I tried to put the clamps very close together to maximize the pressure while the glue dried.
These first panels are tests for me as the majority of the bottom edges will be hidden between cabinets after re-installation, so perfection is not required. When I get to edges that will be visible after re-installation, I may end up having to apply a slightly larger than original shoe molding at the bottom if there are small places that the top layer is missing. The other option would be to find a donor panel and cut little veneer patches out of using an exacto knife that could be glued in to fill in missing areas. This would pretty much be invisible at floor level unless one was inspecting on their hands and knees. Time will tell if I find any areas that I will try this type of veneer transplant.
Good Luck with your project!
Name:	Straightening the Bottom of the Kitchen-Bed Wall.jpg
ID:	301838   Click image for larger version
Name:	West Marine Epoxy Resin Syringes.jpg
Joe
Old 01-04-2018, 12:15 PM   #129
1962 28' Ambassador
Mesa , Arizona
Thank you for the very well written and clear response to my question. It will certainly be well worth a try when that time comes. If I get it done anytime soon I'll let you know.
Hittenstiehl
Old 01-04-2018, 03:44 PM   #130
1962 22' Safari
2016 30' Classic
Images: 41
Quick update. As I continued work today I had the second syringe plug up as I worked and had to cut the tip off, which shortens the length, but worse greatly increases the width of the tip making it harder to get in tight spaces and increases the glue flow rate, making it harder to apply glue in a controlled manner.
The West Marine syringes must be at the limit of what works for wood glue. I need to go buy more tomorrow, because the West Marine near me is already closed for the day and I need the tiny tip for my next glue session. I'd recommend the 12-pack (rather than the 2-pack I originally purchased) for anyone with more than one panel to repair.
Joe
Old 01-15-2018, 10:05 PM   #131
1962 22' Safari
2016 30' Classic
Images: 41
Gotta show a little progress from time to time. Since my last post I have continued to work on cabinets. A little more gluing has occurred, but I am far from done on that task. I did learn that a pin can unclog the tip of the West Marine syringes, so I keep one handy and no longer need to cut the tips off. A woodworking store recommended "Hide Glue" for veneer repair, so I bought a bottle and may try that next time I need to glue down some lifted veneer. They also recommended oxalic acid for brightening wood that has darkened due to water exposure. I bought some, but have not used it yet. It comes as a powder that you mix with water.
Now starting to strip the finish off the cabinets and other woodwork. After some tests to figure out what they were "varnished" with, I came to the conclusion that they were refinished, probably in the 1970s or 1980s or maybe even 1990s with . . not lacquer . . . not shellac . . . not polyurethane . . . but alkyd varnish. Denatured alcohol did nothing (would have removed shellac), lacquer thinner did nothing (would have removed lacquer). Several other chemicals did nothing. This indicated they were re-coated with either varnish or poly. Given the yellowing, varnish it was and a more aggressive stripper was needed.
I hate working with harsh chemicals, so first I tried stripping with a heat gun and scrapper. It worked, but was slow. The woodworking shop recommended Blue Bear Paint & Urethane Stripper as reasonably easy to work with and not too caustic, but not as fast as the nasty chemicals. It cleans up with water, so that is good. I still need to do some cleanup with a scrapper and occasionally the heat gun and/or a rub down with denatured alcohol and a rag after the chemical strip if there were drips or other irregularities in the varnish application thickness, but it seems to get the job done. So far I've only stripped a few pieces, but now that I know what I'm doing it should go faster.
I even though the stripper fumes are low enough to work in my basement, I still suit us as "Chemical Man" when working with the chemical stripper.
Name:	Heat Stripping.jpg
ID:	302509   Click image for larger version
Name:	Chemical Stripping.jpg
Name:	Mr. Chemical Man Selfie.jpg
Joe
Old 01-16-2018, 06:10 AM   #132
2007 22' International CCD
Around the World Airstream #6768
Nice to see a portrait of a person wearing good PPE for the task at hand!!
Old 01-16-2018, 06:33 PM   #133
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Joe: I just read your great article in the Nov 17 Blue Beret. (At least I assume it was your piece.) I found it very, very interesting, truly an adventure of a lifetime for the participants. It was the mother of all WBCCI caravans. This was all done after Wally Byam's passing.
It sure puts new meaning in your Safari project for me. I can hardly imagine your trailer being pulled out of Southeast Asia mud by a couple of elephants.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 01-16-2018, 09:31 PM   #134
1962 22' Safari
2016 30' Classic
Images: 41
David
Hi David,
Yes, that was my article in the Blue Beret.
Not being pulled by elephants, but the attached photo is my trailer being pulled thru the mud on the Kra Peninsula in Thailand. You can barely see the trailer, but I know it is mine because I can identify Ralph & Gerry Cramer's tow vehicle, a Ford F250 4x4 pickup with a unique cap on the back.
Name:	Road Trip - Kra Peninsula, Thailand.jpg
Joe
Old 01-17-2018, 05:09 AM   #135
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you for the photo. I don't see any elephants in the mud scene.
Okay, now back to work on 6768, one warped and delaminated piece of wood at a time.
David
Old 01-18-2018, 09:30 PM   #136
1962 22' Safari
2016 30' Classic
Images: 41
I had planned to leave my biggest woodworking project, rebuilding the bath cabinet, to last so that I could hone my woodworking skills on easier projects before tackling it. Today I decided that would not be a good plan in case I hit some bumps in the road while rebuilding it.
I partially disassembled it today and bought some new wood to redo part of the framing that had rotted and also to add a little more structure where Airstream didn't originally feel it was necessary. I have some lifted veneer to repair on the front of the cabinet, pretty much just the area above the black tank cutout. I will add framing structure behind that area to reinforce it, because it was only the 3/16" plywood when it left the Airstream factory. I will also replace the interior floor that is totally delaminated, but again is nothing more than 3/16" plywood. This part should be pretty straight forward.
My challenge is what to do with the top. The 5-layer plywood is toast, pretty much totally delaminated and wavy the full area. The Formica still looks good, so I have the possibly insane idea that I can strip the Formica from the bad wood and re-glue it to a new piece of plywood to make a brand new top with Formica that that still matches the Formica on the kitchen counter and over the fridge.
That was it today. I'll get back to repairing minor determinations and stripping the finish from other wood items when I get pockets of open time.
Name:	Bath Cabinet Before Disassembly.jpg
ID:	302648   Click image for larger version
Name:	Bath Cabinet After Disassembly.jpg
Joe
Old 01-19-2018, 05:22 AM   #137
1978 25' Tradewind
1954 15' Byam Holiday
Linden , Michigan
Removing Formica
Joe,
I found this on the WEB:
Removing Formica
repair-remodel-improve-decorate-fix
I get this question a lot so I thought I would post it. In my opinion removing old formica and trying to reuse the old top is not practicle for several reasons.
1. It is time consuming and somewhat expensive.
2. There is some danger involved as you are going to work with a highly flammable solvent.
3. By the time you figure your material cost and time you will find that a ready made top is not that much more money, less mess and a whole lot quicker.
If you decide to give it a try make sure that there are no open flames or pilot lights, no smoking, plenty of fresh air and protect your eyes and skin with safety goggles and apply skin cream to exposed skin. Use solvent resistant rubber gloves.
Still want to try it? OK lets get started.
Materials Needed:
Several thin putty or narrow spackle knives
Lacquer thinner
Safety glasses and rubber gloves
Shim shingles, available at most home bldg supply centers
3-4 pcs of wood 1/2-3/4" thick, 3-4' long
Lots of newspaper to stand the countertop on and absorb the mess.
A fresh water supply nearby for accidential contact with exposed skin as the lacquer thinner will Burn.
Avoid working in direct sun or in a heavy breeze but make sure you have PLENTY of fresh air!!
Turn OFF any and all pilot lights and no open flames or smoking.
When finished soak all rags, newspaper, wood etc in water and allow to dry before disposing. If contained in a closed trashcan or bucket they can burst into flames (spontaneous combustion)
Remove the old top and stand it on edge. Take a thin putty knife or spackle knife and work it into the crack where the formica meets the wood. Once you have the knife inserted a little pour a little lacquer thinner into the crack. The lacquer thinner will soften the adhesive and you can start working the knife in deeper a little at a time. As the glue loosens you start driving in thin wedges of wood, shim shingles are good for this as they are tapered from real thin to about 1/4" thick. As the crack opens keep adding more thinner and drive the shims in until you can start inserting pieces of longer thin wood up to 1/2" thick and as long as the countertop is wide so that they reach the bottom. Try to work the whole edge evenly so as to keep a nice pocket for the thinner. Leave the outside edges intact until the very end.
StevieB is offline   Reply With Quote
Old 01-19-2018, 05:27 AM   #138
1978 25' Tradewind
Linden , Michigan
Formica Removal - YouTube
And a YouTube example:
Regards,
StevieB
Old 01-19-2018, 09:52 PM   #139
1962 22' Safari
2016 30' Classic
Images: 41
Thanks StevieB,
The lacquer thinner method certainly looks quick. I already had someone suggest the heat gun method to me. We'll see what I decide when I get to working on the top, since the plywood is almost totally delaminated. I may only be removing one ply.
In the meantime, today I stripped the last side of my two streetside walls that separate the kitchen from the bedroom and the bedroom from the bath. These large panels are a challenge as they take up my entire work table. Luckily I am done with large panels for a while until I decide to do the two closets. Lots of smaller items (cabinet doors, drawer fronts, shelves, etc.) to strip before I get to the closets.
I also began re-gluing the veneer on the bath cabinet today. Quite a bit was lifted on the curbside end over the black tank, and I needed to re-glue it before any more cracked off. I need to make it solid again before working on the framing structure. I also noticed that I will have to re-glue the entire lower edge at the floor that has also lifted due to water exposure. Gluing all the veneer on the cabinet may take a couple more days because I run out of clamps before I run out of things to glue, and because I decided to try the Hide Glue. It is a little more runny, but more sticky than the standard wood glue I used on earlier veneer repairs. It sets up slower, which gives me more working time, but also increases the time needed to fully set up to 24 hours. The hide glue seems to work great in the West Marine syringes.
Name:	Streetside Walls Stripped.jpg
ID:	302700   Click image for larger version
Name:	Bath Cabinet Beginning Veneer Repair.jpg
Joe
Old 01-20-2018, 06:56 PM   #140
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Lots of pieces parts, all of which need your skilled attention. Your trailer is like restoring a Le Mans winning D Jag. It's going to be a fantastic piece of Airstream history.
David
Newby to the Airstream World - Hello from CO mpmerritt Member Introductions 11 05-30-2011 06:58 PM
