Old 10-14-2013, 08:02 PM   #85
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Time for a long overdue update. It's been a busy summer. The fact that I haven't been posting photos doesn't mean nothing was happening.
I will admit that shortly after my last post reality set in that there was no way the Airstream would be ready to attend the 2013 WBCCI International Rally in June/July.
I continued to work, partially dropping the ceiling to replace all the wiring. I found a couple of places mice had chewed on the wiring, but it was mostly OK. There were a few mouse trails in the insulation above the kitchen, but most was untouched and reusable. I did find a hidden TV antenna cable between the inner and outer skins.
I planned to replace all 12V and 110VAC just to be safe and to allow me to separate it into more separate circuits to limit the effects, should a short ever occur.
I did not want to un-rivet the door frame, and I felt that completely removing and re-installing the ceiling were not a one person jobs, so the ceiling was rolled back from the street side toward the door without being totally removed. The fiberglass endcaps were not removed. This required me to use a fish tape to fish new wires in places that were not exposed.
The attached photos show my progress up to about June 1st, at which time I stopped working on the trailer so that I could prepare two presentations I was scheduled to deliver at the WBCCI International Rally at the end of the month. As work stopped, the ceiling was hanging down and the new wiring was partially installed.
I will continue to update progress from July to October in later posts.
Name:	Starting to Drop the Ceiling.jpg
ID:	197849   Click image for larger version
Name:	Ceiling Dropped.jpg
Name:	Ceiling Insulation.jpg
ID:	197851   Click image for larger version
Name:	Insulation Removed.jpg
Name:	Frayed Wire Covering.jpg
ID:	197853   Click image for larger version
Name:	Hidden TV Antenna Cable.jpg
Name:	Starting to Install New Wire.jpg
Joe
WBCCI/VAC #6768
(Looking for a vintage 1960's fiberglass front window guard)
66Overlander is offline   Reply With Quote
Old 10-14-2013, 08:20 PM   #86
1962 22' Safari
2016 30' Classic
Images: 41
After returning from the WBCCI International Rally in July, work resumed.
Because of some other commitments that somewhat limited the time I had to work on the Airstream, it took until about Labor Day to complete installing all of the new wiring and get the ceiling re-installed. I reused insulation where it was still in good shape and replace sections that had mouse trails.
I also installed new marker lamps, finding that the exterior skin should eventually polish up nicely. I make sure that all exterior lamp wiring had service loops in case I ever need to remove/or replace lamps.
I also got a friend to help me buck rivet the rear exterior molding back in place to prepare for re-installation of the lower rear inner skins.
Name:	Starting to Reinstall Insulation.jpg
ID:	197865   Click image for larger version
Name:	Replaced Mouse Riddled Insultion.jpg
Name:	Ceiling Being Clecoed in Place.jpg
ID:	197867   Click image for larger version
Name:	Ceiling Riveted Back in Place.jpg
Name:	Wiring Loops for Tail Lights.jpg
ID:	197869   Click image for larger version
Name:	New Marker Lamp.jpg
Name:	Rear Molding Bucked Back On.jpg
ID:	197871   Click image for larger version
Name:	Molding Bucked Rivet Closeup.jpg
Joe
WBCCI/VAC #6768
Old 10-14-2013, 08:38 PM   #87
1962 22' Safari
2016 30' Classic
Images: 41
From Labor Day on, the pace of work increased as I attempted to get all of the inner skins re-installed and painted before it got too cold to paint in an unheated garage.
Actually, I wanted to get the interior painted and the new floor tiles installed before it got too cold, but I keep amazing myself at how easy it is to miss self imposed deadlines, not to mention that work has been very stressful lately. I now say that anything involved with restoring a vintage Airstream is going to take 10x as long as it seems like it should. There are just too many little details to address. In the end, I came to accept that getting the interior painted before winter was a more realistic goal.
My next accomplishments were to get the rear and front lower inner skins re-installed. I washed the front and rear lower inner skins BEFORE re-installing them. After re-installation, the contrast to the rest of the inner skins was dramatic. The interior walls would require a THOROUGH cleaning before sanding and painting.
The attached photos get us to about the end of September.
Name:	Rear Insulaion Going Back In.jpg
ID:	197882   Click image for larger version
Name:	Rear Corner Skin Going Back In.jpg
Name:	Rear Skins Riveted Back in Place.jpg
ID:	197884   Click image for larger version
Name:	Front Insulation Going Back In.jpg
Name:	Front Skin Going Back In.jpg
ID:	197886   Click image for larger version
Name:	Front Skip Riveted Back In.jpg
Name:	Clean vs. Dirty Walls.jpg
Joe
WBCCI/VAC #6768
Old 10-14-2013, 08:58 PM   #88
1962 22' Safari
2016 30' Classic
Images: 41
Luckily Michigan Has been experiencing a very nice Indian Summer with high temps mostly in the mid 60's so far. That plus using a couple of vacation days allowed me to re-install the window and roof vent trims, remove window, curtain, and miscellaneous hardware, wash the walls several times, sand the walls, wash the walls again, mask the areas that won't be painted, paint the walls, and remove the masking.
Name:	Walls Cleaned and Sanded, Starting Masking.jpg
ID:	197889   Click image for larger version
Name:	Painting Complete.jpg
ID:	197891   Click image for larger version
Name:	Walls Cleaned and Sanded, Starting Masking Front.jpg
ID:	197893   Click image for larger version
Name:	Masking Done Front.jpg
Name:	Painting Complete Front.jpg
ID:	197895   Click image for larger version
Name:	Unmasking Done Front.jpg
Name:	Door Masking.jpg
Joe
WBCCI/VAC #6768
Old 10-14-2013, 09:11 PM   #89
1962 22' Safari
2016 30' Classic
Images: 41
This brings us up to date.
What paint did I use?
Well, I do not own professional spray painting equipment and I did not want to purchase any and then learn to use it to spray new Zolatone.
But I wanted an original "specked" Zolatone like appearance.
I compromised and used Rustoleum Multicolored Textured aerosol cans in the Caribbean Sand color. I used 38 cans on the inner skins plus three cans of primer (I will use more cans repainting closet and roof locker inner walls before re-installation, since they have already been painted in latex).
I think it looks good. The color is a little lighter than the original Zolatone, but I think it will work fine.
BTW, I masked off areas behind the fridge, cabinets, and bath tub that can't normally be seen, and did not paint them, so whoever re-restores this Airstream in another 50 years will know what the original Zolatone color was.
ID:	197904   Click image for larger version
Name:	38 Cans Plus 3 Primer.jpg
Name:	Caribbean Sand vs. Original Zolatone.jpg
Joe
WBCCI/VAC #6768
Old 11-04-2013, 10:22 PM   #90
1962 22' Safari
2016 30' Classic
Images: 41
Work has continued. Since the last post I finally removed the furnace and the last of the original floor tiles.
I also made an aluminum tray to hold the custom gray tank that I will be adding. But before talking about that, here is some info about the custom gray water tank that I had made to my specifications a few months ago . . .
The gray tank is only about 12.5 gallons, but it will allow limited boon docking for a day or two without dragging out a blue boy. It will fit in a single frame bay without removal of the in floor furnace duct and it will not hang down below the belly pan. It will be mounted in the 2nd bay rearward of the axle, which should not be too bad for weight distribution. The tank is 42" x 21" x 4" and is made from 1/4" thick black polyethylene that was hot air air welded. The two threaded fittings on the top were made made from solid blocks of white polyethylene that were drilled and tapped for superior strength compared to normal spin weld fittings. The discharge pipe will also serve as an inlet from the bath tub and bathroom sink. It was welded to the tank, rather than use a threaded fitting to allow the inside of the pipe to be right at the bottom of the tank to allow for complete drainage. One pipe through the floor will connect to the vent pipe in the closet and the other located under the bed is for water from the kitchen sink.
I made the tray for the gray tank out of an old piece of Reynolds Aluminum 6061-T6 that is 0.050 thick. That heavy panel was originally an outer skin repair panel from my old '55 Safari, but I had to replace it because it too had been creased by a prior owner. I had been holding that panel for a future project and a gray tank holding tray seemed like the perfect use for it.
I then made three gray tank holding straps out of 1' x 1/8" steel straps and as of this last weekend, I had everything temporarily test fit in place before dis-assembly to allow the straps to be painted. Final installation of the tank may not occur until spring.
I also made a brace to strengthen the cross member that I had to cut for the gray tank discharge pipe, but I did not get a photo of it.
There may not be any more updates for a while. Work is probably going to slow down for a while because after the daylight savings time change it is too dark to work after work and I have some weekend commitments coming up.
Name:	Furnace and Floor Tiles Out.jpg
ID:	199342   Click image for larger version
Name:	New Custom Gray Tank and Tray.jpg
Name:	Gray Tank in Tray with Straps.jpg
ID:	199344   Click image for larger version
Name:	Gray Tank Temporarily Hung #1.jpg
Name:	Gray Tank Temporarily Hung #2.jpg
ID:	199346   Click image for larger version
Name:	Gray Tank Holes Thru Floor.jpg
Joe
WBCCI/VAC #6768
Old 07-17-2016, 08:51 AM   #91
1962 22' Safari
2016 30' Classic
Images: 41
Long time no activity on this thread. I last posted in 2013, but work continued through August 2014 before stalling until slowly resuming work earlier this year. I will try to catch things up over the next couple of days. This will be the first update.
In March 2014, I took the tub to a professional to have it refinished. At his suggestion, I went with a paint based rather than gel coat based refinish. He repaired the cracks and sanded it smooth before painting it and he tried to match the original color as close as possible. This option was less than half the cost of gel coat. I guess time will tell if it was the right choice.
Before and after photos are attached.
ID:	267056   Click image for larger version
Joe
WBCCI/VAC #6768
Old 07-17-2016, 09:30 AM   #92
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . Now THAT'S what I call a project ! ! ! glad to see the old girl coming along, thanks for sharing. . . Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 07-21-2016, 08:48 PM   #93
1962 22' Safari
2016 30' Classic
Images: 41
The next overdue update occurred between May and August 2014 (working very infrequently), when I repaired the belly wrap forward of the street side wheel well.
When I got the trailer, there was a repair panel in this area that was installed with a second row of steel rivets that had rusted and had been touched up with silver paint (1st photo). It did not fit right (there were bubbles where it did not fit flat) and worse, the rear edge of this panel at thew wheel well opening was cracked and bent and the wheel well trim was missing.
I removed this panel to expose the much worse damaged original belly wrap (2nd photo). The trailer was obviously pulled along some low object that wrinkled and tore the belly wrap. I have no photo evidence showing this damage during the Around the World Caravan, so I believe this occurred some time after the trailer returned home.
I installed the new repair panel by drilling out the rivets holding the side skin to the C-channel and buck riveting in a new panel (3rd photo) tucked undere the side skin, just like the original belly wrap. I even had a piece of wheel well trim left over from a prior project that I used to dress up the wheel well opening. I think it looks much better now. Most casual observers will never know there was damage there.
Name:	Streetside Belly Wrap Original Repair Panel.jpg
ID:	267440   Click image for larger version
Name:	Streetside Belly Wrap Original Repair Panel Removed.jpg
Name:	Streetside Belly Wrap New Repair Panel.jpg
Joe
WBCCI/VAC #6768
Old 07-21-2016, 11:19 PM   #94
1962 22' Safari
2016 30' Classic
Images: 41
Eagle eyed readers will see some signs of progress on another repair in the photos in my last post.
In August 2014, I also repaired the street side wheel well opening that had bent outward with accompanying rips in the aluminum skin at the front and rear of the wheel well opening. This wheel well opening looks normal in photos from the early part of the Around the World Caravan, but is seen in the same ripped condition in photos from the latter part of the ATWC. I do not know the story of how that damage occurred, but I suspect that the wheel studs likely broke and the wheel came free, ripped the wheel well opening, and then beat up the belly wrap behind the wheel well opening. I had previously repaired that rear belly wrap damage before I replaced the rear section of floor since that provided easy access to both sides for the bucking of rivets.
Attached are before, during, and after repair wheel well opening photos. I did not want to replace the whole side panel. You will see that after bending the ripped section back into place, it did not return to a fully smooth surface, so I decided to rivet on a section of awning rail to hide the waves in the skin. An awning rail of this type has been a common Airstream modification over the decades to allow a wheel skirt to be put in place to keep sun off the tires while parked, so it seemed like a period correct disguise. I also had to add one small patch above the awning rail because the front rip extended above the rail.
As you will see in my next post, I had to use a similar awning rail on the curb side wheel well as well.
Name:	Streetside Wheel Well Damage.jpg
ID:	267459   Click image for larger version
Name:	Streetside Wheel Well Bent Flat.jpg
Name:	Streetside Wheel Well Repaired with Awning Rail.jpg
Joe
WBCCI/VAC #6768
Old 07-21-2016, 11:47 PM   #95
1962 22' Safari
2016 30' Classic
Images: 41
Atfer August 2014, all work stopped until about June 2016 when I finally started working on the curb side wheel well opening. This was the last panel repair needed on the exterior, but it posed one of the biggest challenges, so it got left to last.
The curb side wheel well was also ripped when we got Cramer (our name for old #6768 based upon the last name of the couple that took it around the world). This wheel well was damaged much later and was done purposefully with a saw and pliers. I believe the street side wheel well served a prior owner as inspiration when a tire change was needed and the original axle was frozen in place. I believe the wheel well was cut and bent outward to allow the wheel and tire to be slipped off and back on the hub.
The bigger issue, though was that there was a previous leak above the wheel well and the aluminum skin had experienced galvanic corrosion to the galvanized steel wheel well tub to which it was riveted. I knew that when I started working on this side, a hole was going to open in the aluminum skin and possibly in the galvanized steel tub as well, but I did not want to completely replace the side skin.
In the end, I had to put a patch panel over the holes on the side skin as well as another patch inside the galvanized tub. I then riveted an awning rail over the patch above the wheel well opening as on the street side to make the repair as inconspicuous as possible.
With this post, this thread is now up to date on restoration progress. I will next return to working on a variety of things in the interior.
Name:	Curbside Wheel Well Opening Before.jpg
ID:	267462   Click image for larger version
Name:	Curbside Wheel Well Opening Skin Holes.jpg
Name:	Curbside Wheel Well Opening With Patch.jpg
ID:	267464   Click image for larger version
Name:	Curbside Wheel Well Opening With Rail and Tire.jpg
Joe
WBCCI/VAC #6768
Old 07-22-2016, 02:05 AM   #96
Trnpk Crsr's Avatar
Baltimore , Maryland
Amazing.
Trnpk Crsr is offline   Reply With Quote
Old 06-01-2017, 03:45 AM   #97
Longmont , Colorado
I just joined this forum. I was a member of the Around the World Caravan - my dad wrote the book commemorating the trip. I wonder if anyone knows what happened to 8511, which was the trailer we travelled in?
email2scott is offline   Reply With Quote
Old 06-01-2017, 09:39 AM   #98
1962 22' Safari
2016 30' Classic
Images: 41
Hi Scott,
I met your parents and sister Judy back in 2014 and communicate by email with Judy & Lorie occasionally. I am in touch with several other ATWC participants from other families. It's great to be in touch with you too now. I will also try to reach you via direct email, so that we can catch up on a variety of things, but I will answer your specific question here:
At the current time, I know of almost a dozen surviving Airstream trailers from the 47 that participated on the ATWC. It seems a new survivor is identified every year or two. Unfortunately, the 1963 26' Overlander bearing #8511 that your family used on the ATWC has not been rediscovered yet.
All I have related to #8511 is that according to the copy of a letter that your parents gave me when I visited, they were contacted in 1966 from a couple named Elden and Dexter Johnson of Orange City, FL that stated that they had bought your parents ATWC Airstream. Looking back at old WBCCI Membership Directories, I found that Elden and Dexter Johnson, of Orange City, FL were WBCCI members under the #15237 from 1966 thru 1972 and that they had moved to Sarasota, FL by 1972. We can guess that they owned your ATWC Airstream the entire time they were in the club, but cannot prove it.
I will suspect that if that Airstream is ever found, the number 15237 may be much more visible than the old 8511, given that is newer and likely was on the trailer longer, possibly much longer if not removed after the Johnsons dropped out of the club.
To everyone else reading this, if you ever find a 1963 26' Overlander bearing the number 15237, possibly with a faint #8511 underneath, and quite possibly in Florida (though it could have moved anywhere in the years that followed), please contact me ASAP! Thanks in advance!
Joe
WBCCI/VAC #6768
Newby to the Airstream World - Hello from CO mpmerritt Member Introductions 11 05-30-2011 07:58 PM
