Old 08-20-2010, 08:07 PM   #1
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
'70s Airstream Model Explanation
Ok..
that might sound stupid , but:
I see advertised (in the 31 to 34 ft) range the Sovereign, Sovereign with LandYacht option ?, Excella, Limited, Classic, and LandYacht..
question : is the Sovereign the Base model and it goes up from there, or are they all completely different models ? i know the Limited is top of the line..
can anybody shed some light on this?
how about value and re-sell on those models ?
thanks
submariner is offline   Reply With Quote
Old 08-20-2010, 08:47 PM   #2
x
XXXX , XXXX
Actually in the 70's Excella 500 was the top of the line.
wasagachris is offline   Reply With Quote
Old 08-20-2010, 08:55 PM   #3
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Let's see:
1970:
Land Yacht: Base series
International: Top of the line
Individual lengths had their own names:
Sovereign 31 ft
Ambassador 29 ft
Overlander 27 ft
Tradewinds 25 ft
Safari 23 ft
Globetrotter 21 ft
1971 thru 1979 Excella 500
(71) Introduction of the Excella 500
The model lines remained consistent thru 79.
1980 names were changed:
Caravelle, International, Excella II and Excella-Limited
34ft length was introduced in 1982 model year.
Airstream's website has information divided by decade relating to the trailers.
Airstream, Inc :: Travel Trailer Specifications
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 08-31-2010, 09:23 AM   #4
1973 31' Excella 500
Spring Green , Wisconsin
Browsing the pages of the Airstream, Inc. site referenced above, it seems likely the Excella 500 was an upgrade package to the Sovereign since there are no floor plans shown for the Excella 500, only specifications. Was the upgrade package available for models other than the Sovereign?
Our AS vin number clearly indicates it is a '73, however the floor plan matches the '74 Sovereign with the bath curbside and the elimination of the full credenza across the back. So, I'm assuming it was manufactured late in the '73 model year.
Is it possible that the change in location of the bath was related to the modified frame design that I've read about on these pages and they made the change in the middle of the model year? Did we possibly get lucky and get a '73 with the "improved" frame? Only time will tell unless someone here knows....
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 08-31-2010, 11:04 AM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The date of manufactured (month/year) should be on the trailers exterior data plate...
Old 08-31-2010, 11:28 AM   #6
I didn't notice a date of manufacture on the data plate, but the VIN is E31A3Jxxxx so it is properly identified as an Excella 31 foot twin center bath manufactured in 1973 in Ohio. I'll have to look again and see if there is a month and year.. Thanks Wabbiteer!
Lew TAC #WI-6
Looking for a "Towing 101" explanation kirkrik Towing, Tow Vehicles & Hitches 2 06-16-2014 09:28 PM
New strip light for Round '70s model Airstream Dan@LED4RV Commercial Listings 0 03-27-2013 04:54 AM
New strip light for '70s model Airstream Dan@LED4RV Commercial Listings 0 03-08-2013 05:55 PM
Belly Pan Explanation roadtrip07 Belly Pans & Banana Wraps 4 08-11-2010 11:19 AM
