10-29-2017, 07:55 PM
#21
2014 25' FB Flying Cloud
Des Peres
, Missouri
We converted ours to connect to the front valve quick conn Ct and use a 10 ft extension hose.
Works great
10-30-2017, 10:02 AM
#22
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
At some point, "recycling" the little cylinders probably is not a good idea. I'd put dates on them and retire them after some period of time. Is that 5 years or 1 year? It depends a bit on how excited you get about things .... It also depends a bit on how hard you are on the tanks.
10-30-2017, 10:17 AM
#23
2007 22' International CCD
Corona
If it’s a standard DOT disposable cylinder it’s both illegal and highly dangerous to refill them. Real refillable small cylinders have a 10% valve that opens with a wrench to prevent overfilling. Standard disposable cylinders do not, and for this reason can be overfilled and present a fire and explosion hazard.
Not a good idea to just buy a bulk to small cylinder refill adapter and use it on non-refillable bottles. Highly hazardous.
10-31-2017, 05:48 PM
#24
2016 28' International
Perry
, Georgia
Is there a measurable advantage of the 3/8 inch hose over the 1/4 inch hose?
Not sure if an increase in hose diameter would be advantageous over a 20 foot run.
11-01-2017, 05:41 AM
#25
Micanopy
My understading is that a larger the hose equals more volume so more fixtures can be attached to the system. Pressure Stays the same. Kinda like the plumbing in your house. One fixture, 1/2 inch pipe from the source to the fixture. Three fixtures start with 3/4" pipe , tee off with 1/2 to the first, at the second tee off with 1/2 " to it and the third. Same pressure but more initial volume to handle the fixture.
Any professional gas guys out there?
Rick
11-10-2017, 11:17 AM
#26
sacramento
Originally Posted by Adventure.AS
I purchased the items from Propane Gear. After some email communication, I phoned them to get the kit for using the Q regulator and a 1lb tank. Below is the parts list for all of the items.
1/4" Female Brass Swivel Nut
SKU 951$3.49 USD$3.49 USD
1/4" High Pressure Propane Hose 350 psi
SKU 62$2.50 USD$5.00 USD
1/4" Hose Barb x 1/4" Female Pipe Thread
SKU 289161$3.99 USD$3.99 USD
1/4" Male Flare x 1/8" Male Pipe Thread
SKU 931$1.29 USD$1.29 USD
1/4" Male Flare x 1/8" Male Pipe Thread 90° Elbow
SKU 861$1.99 USD$1.99 USD
3/8" Female Flare Swivel x 1/4" Hose Barb
SKU 303821$3.99 USD$3.99 USD
Ferrule ¼” Rubber Hose 1” length Brass Hose .625” Ferrule
SKU 1822$0.75 USD$1.50 USD
WEBER Q RV Quick Connect Kit 12' Hose
SKU 325011$59.99 USD$59.99 USD
Can you show a picture of the setup please
11-10-2017, 04:39 PM
#27
2017 25' International
Niagara-on-the-Lake
, ON Canada
If you look on the Propane Gear website you will see the quick connect conversion kit. They have added a new product since I purchased - the Reverta-Q. This looks like it would work in conjunction with the first kit. In my setup with the parts purchased from Propane Gear I have to take off the conversion kit and attach the short hose, and regulator. This is a bit of a pain and I like the look of the Reverta-Q.
Ray B.
11-11-2017, 06:01 AM
#28
2008 30' Classic S/O
Hampton Beach
, New Hampshire
Weber Adapter Hose
Hi - We have a 2008 AS and it doesn't include a quick connect near the tanks. We also have a Weber Q grill that has worked well for us. We store it in a tote in the bed of the TV until it's needed.
Our solution to not using the 1lb cans was to get the Weber Adapter Hose. This lets us use a 20lb bottle that we can either refill or exchange at multiple locations. In a emergency it could be used to augment the AS propane supply.
The Weber adapter hose was an inexpensive and simple solution for us to avoid using the 1lb cans. https://www.weber.com/US/en/accessor...s/adapter-hose
For travel the bottle sits in a milk crate in the bed of the TV so it doesn't roll around. We also use a bungee cord to hook the crate to a cargo tie down to limit any other travel.
We've found that storage, setup and take down is quick and easy. All the grill stuff goes in the grill tote and the milk crate just gets hooked up and your off an running.
We're happy with the Keep it Simple process.
Tom & Wendy - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
11-11-2017, 06:29 AM
#29
Niagara-on-the-Lake
, ON Canada
Do you have a regulator on the 20 lb tank to get the gas to 'low pressure'?
Ray B.
11-11-2017, 07:13 AM
#30
Hampton Beach
, New Hampshire
Weber Adapter Hose
It's not necessary. The adapter hose connects to the existing grill connection. The regulator on the grill drops the tank pressure to usable levels for the burners.
11-11-2017, 07:55 AM
#31
Niagara-on-the-Lake
, ON Canada
OK, I see now that it is the same threading as the 1 lb bottles.
Ray B.
