Old 07-18-2014, 09:15 PM   #29
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
When I outfitted my AS with a toaster I purchased a small Cuisinart model that fit perfectly in the cabinet. Recently in trying to multi-purpose everything i wanted a way to bake without propane if hooked up electrically. A toaster oven was the key; however, I researched them and found out about something called a flash oven. I must tell you that I used it when camping recently for the first time. Neat. They go on sale for about $99. A flash oven requires no pre heating. You put in what you want to cook and either use a preset button for commonly cooked items or the temperature timed method. I had some frozen biscuits to cook for breakfast. The package was 375 for 22 min I believe. I put them in a cold oven pressed 255 and hit 20 min. They were done in 15 minutes perfectly. It cooks fast. The drawback is the opening 10x10x4 or so. But it works as an oven for most things and toasts too.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-18-2014, 10:25 PM   #30
timmaah's Avatar
1999 25' Safari
On , the road
Stove Top Toaster all the way... My wife uses it almost everyday.
Amazon.com: Coleman Camp Stove Toaster: Sports & Outdoors
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 07-18-2014, 10:52 PM   #31
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
LIKE this toaster. Only trick is to pre-heat it, then plop on bread - and turn it when done to your liking. Works well with bagels too. If you put a piece of aluminum foil or a pot lid on top it's even faster. Inexpensive and compact. It uses the stovetop, so the exhaust fan will normally keep the smoke alarm from going off. Also available at Camping World if you're combining an order get free shipping.
Paula
Old 07-19-2014, 04:16 AM   #32
1978 31' Sovereign
1988 32' Excella
Linthicum , Maryland
Originally Posted by RuneM46 View Post
We have a Hamilton Beach combined with eggmaking (frying, scrambling & cooking). Just love it. Going to buy one for the AS as well
Sorry - made a mistake, it's a West Bend.
RuneM46 is offline   Reply With Quote
Old 08-02-2014, 07:55 AM   #33
BorninRI's Avatar
Providence , Rhode Island
I've have my Dualit for many years & expect to take it with me when I get my Airstream. It's a great reminder of what's to come.
BorninRI is offline   Reply With Quote
Old 08-02-2014, 11:43 AM   #34
How about a vintage Toastmaster?
https://www.google.com/search?q=toas...%3B2048%3B1536
We had one very similar to this when I was a kid. I know it was prior to WWII - thing lasted into the 1960's and probably could have been fixed. Certainly more durable than anything I could buy today.
Old 08-02-2014, 12:03 PM   #35
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I have the one I grew up with. It still works. I want to replace the power cord with a three prong plug with a ground before I use it. The heater wire elements are exposed inside the unit and should one break it could contact the metal housing. Back then most houses were crawl space with wood floors. With today's concrete slab on ground (or in an aluminum trailer with a damp carpet) touching the metal housing of a failed unit could be serious.
But it would look great in my trailer!
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-02-2014, 01:30 PM   #36
richw46's Avatar
Lexington , Kentucky
For my first marriage in early 1967 we received a Toastmaster toaster. My parents had one when I was growing up so I was really happy to get it.
I still have the Toastmaster, it still makes perfect toast every day and has never given me any problem. 45 years and still going strong, now that's quality. Unfortunately, the Toastmasters of today are nothing like that. Low quality is king these days. eBay is your best bet to get one of the old ones.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-27-2014, 10:46 PM   #37
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
We simply use one of those little camp toasters on the burner of our propane stove. Makes great toast... and no electricity!
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Old 08-28-2014, 04:33 AM   #38
Wayward's Avatar
Cary , North Carolina
This is a good all around solution for a 4-slice toaster. One sided toasting option for bagels and english muffins too
Adding to the good suggestion above: pre-heat it and then lower heat a bit. Toast whether or not we have AC power, and, when the weather is nice, we can use it outside on the grill.
Easy to stow - folds up to about the size of a saucer.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 08-28-2014, 05:43 AM   #39
Images: 59
Old school chromeplated Toastmaster Model 1B5. Still makes great toast.
Was over 20 years old when the '59 Tradewind was brand new.
Name:	1937 Toastmaster.JPG
Old 11-14-2015, 07:23 AM   #40
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Our Vintage Toastmaster got promoted for use in the AS.....
When I sprung for the "you got WHAT just to make Toast!!!" Breville....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
1962 Airstream Bambi camping trailer looks like the toaster when I was a kid eBay Watch Airstreams on eBay 0 01-15-2012 06:50 PM
About to Get a Flying Toaster Silversearch Member Introductions 18 10-17-2007 01:02 PM
Toaster oven recommendation Silverbee Cabinets, Counter Tops & Furnishings 4 10-18-2006 11:45 AM
Toaster oven Darrell Root Off Topic Forum 3 08-06-2006 07:52 PM
A new toaster for the Safari AYRSTRM2 Off Topic Forum 7 06-22-2005 09:39 PM
