Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
Old 06-03-2008, 09:21 AM   #15
CombatMedic
Married to Soldiermedic
CombatMedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
Ofallon , Missouri
Alton Brown just did an epsiode not too long ago about dutch oven cooking you should go to foodnetwork.com and use a few of those recipes.
CombatMedic is offline   Reply With Quote
Old 06-03-2008, 09:45 AM   #16
loudruff
Profile:  1978 Argosy Minuet 6.7 Metre
Lorain County , Ohio
Originally Posted by 62overlander
I literally heard brakes squealing when I read that... You have a pannini maker that goes in a campfire? I must see a photo of that, please post one as soon as possible. I love a pannini, the guy that thought to put grill marks on my grilled cheese, was a genius. To be able to do this over a campfire was even more brilliant....
Mine cost me about $20.00 at a local hunting/fishing/sports store.
Here is the link: About Panini & Rome's Cast Iron Press
Lou
CP: W/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
AIR#2695
loudruff is offline   Reply With Quote
Old 06-03-2008, 10:43 AM   #17
62overlander
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville , Maryland
Lou
Just ordered one....
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
62overlander is offline   Reply With Quote
Old 06-03-2008, 11:32 AM   #18
Gwen
Gwen's Avatar
Profile:
Images: 12
This is great fun for kids:
Cut the top third off of an unpeeled orange and hollow out the peel.
Stuff a canned cinnamon roll into the larger part of the orange peel.
Top with remainder of the peeling and wrap in foil and bake over coals 'til done. You will need to check due to temp and thickness of the peel but the top of the orange will rise a bit when they are done. Then frost with the icing from the bottom of the can. - I mean the Pilsbury type that you get in the refer section where you peel the can and then whack it on the counter to open. These are so good and orangy too.
Oh, These are good too:
Cut a donut like you would a bagel and put a slice of pineapple and a bit of brown sugar in the middle. Wrap and heat in the coals 'til the pineapple is mushy. Tastes just like pineapple upside down cake!
Gwen is offline   Reply With Quote
Old 06-04-2008, 01:18 AM   #19
kstampa
kstampa's Avatar
Profile:  2004 28' International CCD
tampa , Florida
HERE'S ANOTHER
SIMPLE DOUGHNUTS IN A DUTCH OVEN
This requires some care
1. Bring about 1" of cooking oil to frying temp in your dutch oven
2. Put a hole through a canned biscuit and drop it in the oil and cook each side (about 4 minutes each side).
3. remove the doughnut and place on paper towels to remove excesss oil
4. While it's still hot, dunk it in a glaze made of mixed powdered sugar and milk and then roll it in brown sugar.
YUM
1987 Eagle Scout
Troop 188
Tampa, FL
kstampa is offline   Reply With Quote
Old 06-04-2008, 05:54 AM   #20
Steve & Susan
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
Butter the outside of two pieces of cinnamon-raisin bread and put them buttered side toward the pan in your pie-iron. Add several tablespoons of apple pie filling (peach works well too), close and cook on the campfire until the raisin bread gets crusty. The pie filling is HOT so be careful.
In a dutch oven - line it with aluminum foil for easier clean-up.
In the bottom, put two cans of cherry pie fillng and one drained can of crushed pineapple mixed together. Then take a yellow cake mix and in a separate bowl mix it with 12 to 16 ounces of lemon-lime soda - nothing else. Pour the mix on top of the pie filling/pineapple in the dutch oven. Close the lid and place on a bed of coals with coals on the lid as well. Check occasionally - it's done when the cake rises and turns a nice golden brown on top. You can sprinkle the top with powdered sugar before serving if there isn't enough sugar in there already for you! My Scouts LOVE this one and I'm betting you'll have visitors to your campsite with spoons in hand!
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 06-05-2008, 04:17 PM   #21
LuminumTraila
LuminumTraila's Avatar
Profile:  2006 19' Safari SE
NW of Boston , Massachusetts
two recipes
I like dutch ovens, but I also like campfire cooking that doesn't involve much cleanup. Here are a few I know about.
Baked Apples Core an apple and place it on a sheet of foil. Fill with a Tbsp. of butter, and your choice of sugar (brown or white), cinnamon, and nuts (I like walnuts). Wrap the foil around the apple and put it in the campfire for approx. 10 minutes, turning it with tongs to heat evenly and being careful not to poke holes in the foil. Remove and let cool for a few minutes before eating.
Here's one I haven't tried yet, but I think it sounds like a good one for kids of any size..
Doughboy on a Stick. Using the biscuit dough that comes in a pop-open container, wrap a piece around the end of a campfire stick. When it's browned, roll it in a little butter, sugar & cinnamon. Eat it right off the stick.
Doug & Jamie, AIR #650
LuminumTraila is offline   Reply With Quote
Old 08-04-2008, 07:56 PM   #22
corgikat
corgikat's Avatar
Profile:  2007 27' Safari FB SE
Mansfield , Massachusetts
This is always welcome when we camp. I think they are called Banana Boats. You take a banana with the peel on. Take a sharp knife and holding the banana so it looks like a smile, cut into the top layer of peel, and through the banana, but do not cut through the bottom layer of peel. Smush (technical term here) open the banana as you might a baked potato. Insert mini marshmallows and pieces of Hershey bar, or chocolate of your choice. Really pack it full. Wrap in heavy duty tin foil and place around the campfire, or even on the embers if the fire is well spent. Allow to heat until the marshmallow and chocolate melt. The skin keeps the banana from burning. When warm enough, take off the fire and open the foil. You eat it right out of the skin with a spoon and it tastes remarkably like a banana split without the ice cream. Yum!
Kat
corgikat is offline   Reply With Quote
Old 10-06-2008, 10:46 PM   #23
oph-rv
the biggoofball is mine
oph-rv's Avatar
Profile:  1973 27' Overlander
1972 Argosy 22
Beautiful Southern Connecticut , Gateway to NEW ENGLAND Unit
Cool
Lou
Thanks for the info. Amazon sells Rome products and I ordered a few today.
Pretty happy to buy a new well-made cast iron press; the ones I see on ebay are bidding high -- saw one go for $78 yesterday. I got the same functionality for 20 bucks on amazon.
Love this forum. Writing down all the great recipes too.
oph-rv is offline   Reply With Quote
Stories from the Campfire ArtStream Off Topic Forum 9 12-17-2006 09:53 PM
Campfire stories yukionna Off Topic Forum 24 05-25-2006 02:40 PM
Starting a campfire Tin Hut On The Road... 37 08-28-2005 10:09 PM
Gas Campfire jordandvm Off Topic Forum 29 07-31-2005 01:52 PM
centramatic alternative? bake315 Axles 7 11-18-2004 04:16 PM
