Old 05-15-2014, 06:57 AM   #15
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
My vote is for the Volcano. Get a charcoal chimney and I don't even take the gas burner. Works great and fires up quickly
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-15-2014, 07:08 AM   #16
Tincampers's Avatar
Sneedville , Tennessee
That is what I have been using so far as I have no propane tank. It does work quite well. Going to break in the dutch oven this weekend. I have a hankering for some peach cobbler!
Tincampers is offline   Reply With Quote
Old 05-15-2014, 08:11 AM   #17
aftermath's Avatar
Spokane , Washington
Q200 here. Rock solid but a tad on the large side. Probably would get the Q100 for the size and weight. Left the charcoal thing long ago because when we camp in the cold weather the propane grills are less of a hassle. The small propane canisters are easy to pack and much cleaner to deal with. IMHO
aftermath is offline   Reply With Quote
Old 05-15-2014, 08:18 AM   #18
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
We have the new Weber 2200, and I'm just getting used to cooking with it. It works great!
A bit of advice, and I won't go into the gory detail; configuring the Weber to work with the LP port on the newer Airstreams is a waste of time, IMHO.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 05-15-2014, 08:21 AM   #19
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I used a Q200 off a low pressure tap for years without a problem. Seems to me the Q's regulator would just pass the gas (!) with no need to regulate it. Any how, it worked well for me. YMMV.
2012 Dodge Durango Hemi/AWD
Old 05-15-2014, 08:30 AM   #20
Branson , Missouri
I like to have the option of a high flame to start with (if I'm grilling a steak, for example). And I just can't get that with the hookup you're describing.
The Weber I have has a built in thermometer. The low pressure hookup will get the grill to about 400 degrees, BUT the standard Coleman type tank connnection (for which the grill is designed) will get the grill to 600 degrees quickly.
2013 Suburban 2500
2011 23 FC FB
Old 05-15-2014, 08:31 AM   #21
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Napoleon Marine Grill - very satisfied.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 05-15-2014, 10:51 AM   #22
Wise Elder
Jammer's Avatar
2010 30' Classic
I have been very happy with our Magma Cabo. Burns hot, easy to clean, and they make a low pressure valve, which I bought this year.
Old 05-15-2014, 11:58 AM   #23
1981 31' Excella II
New Market , Alabama
I bought the Q1000. I figure Geek did his home work. It seems to cook well.
Perry
Old 05-15-2014, 12:51 PM   #24
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
I refill my !# propane bottles at home from the 20# bottle. I have not weighed before & after, but it seems that the small bottles don't get "full." However I carry a few of them and so far it works out fine with my Q220 (thermometer in the lid.)
I also had bought the cart and used it...once. You probably will not need it, but if you do need it I have one available in the SanFran Bay Area.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 05-15-2014, 01:31 PM   #25
Wayne&Sam's Avatar
Images: 21
Yes, I can see that. I've never run it off a canister, but on my low pressure line the flame did seem a little low. It was never an issue because I don't sear steaks, I only cook lower temp stuff, so I never really noticed.
Old 05-15-2014, 02:33 PM   #26
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I converted this Char-Broil portable charcoal grill to gas and wood. Ran a low pressure gas line to the back side of the trailer for it. It is heavy, but works great
ID:	211987   Click image for larger version
Name:	German_shish kabob3.jpg
Name:	German_shish kabob1.JPG
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 05-15-2014, 02:47 PM   #27
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by AWCHIEF View Post
CobbGrills is alive and well in North America. They have a new web site and all their products are still for sale. Home - Cobb Chef USA
I thought Firecraft was the North American distributor these days…
Cobb Grills : FireCraft
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-15-2014, 04:52 PM   #28
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If so it apparently is not an exclusive distributorship (sp).
MICHAEL
Portable Generator Marks Generators & Solar Power 38 11-04-2017 08:36 PM
BBQ grills mayco General Motorhome Topics 7 01-24-2014 07:54 AM
Propane grills for low pressure connection lakeviewerie LP Gas, Piping, Tanks & Regulators 9 11-18-2012 06:22 AM
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Cleaning the portable water systems after use Silvertwinkie Fresh Water Systems 4 07-01-2003 03:46 PM
