Old 09-05-2014, 07:10 PM   #1
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Oven mats
I have the convection oven in my airstream and have a bit of an issue .. Whenever I am even slightly off level at a site, any dish I place on the turntable slides to the lower wall due to the turntables non-stick surface; at which the dish doesn't turn and the heating elements proceed to burn that side of the meal.
Can anyone recommend a mat or other solution (silicon pad?) that will add a level of grip between the turntable and a pot, and is temperature safe to 400F?
Thanks!
Ian
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 09-06-2014, 05:05 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A suggestion stolen from a sailboat… On each microwaveable dish, run a circular bead of DAP silicone sealant around the bottom. To get a smooth surface, after applying the silicone bead, press the dish onto a sheet of waxed paper until the bead sets. The waxed paper will peel off, laving a smooth, flat bead.
Then you'll have non-skid dishes instead of needing a nonskid pad. The stuff is food-safe, microwave-safe, and dishwasher-safe.
DAP Products - Silicone Sealants - DAP® All-Purpose 100% Silicone Adhesive Sealant
Don't know about its temperature resistance, though. The couple that gave me the idea only had a microwave on their boat, not a microwave/convection oven.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-06-2014, 05:29 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Amazon and others sell circular silicone mats meant for microwaves that have a temp rating high enough for convection ovens.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-06-2014, 06:35 AM   #4
IanPoulin's Avatar
Aldie , Virginia
Oven mats
Thanks all - yeah, the thought of silicone in my mind's eye is already as a lubricant/non-stick surface, so I am simply unsure of its ability to grip and hold. I'll check out some of the options to amazon and post back results here.
Discolored oven door glass on Magic Chef oven Ahzmyrah Stoves, Ovens & Microwaves 0 09-28-2007 07:45 PM
Outside MATS?? doorgunner Awnings 18 04-18-2007 09:12 PM
Oven VS no oven trogers713 Stoves, Ovens & Microwaves 36 10-30-2003 01:53 PM
