01-21-2015, 03:41 PM
#21
1973 31' Sovereign
Slidell
, Louisiana
Originally Posted by terryV
How much ice does one of those make in a day?
Their website says 33# a day, with first batch within 15 minutes! Is that the case?
So worth it!
01-21-2015, 04:10 PM
#22
2002 31' Classic
Monroe
, Iowa
So worth it!
Hmmm... how big is it, and how much does it weigh.
(Red will want to know that, also.)
01-21-2015, 05:45 PM
#23
1961 22' Safari
Union
, Oregon
I have a different (Mr Ice, or something) but similar brand -- 35# per day. The big deciding factor for me was power requirement. My little Honda EM650 generator, 650 watt, can run it. I have no idea how much power the other brands require, that is up to you to study. For size, it is about a 20" cube. and weighs less than my little generator which I lift with one hand.
Sam
01-21-2015, 06:21 PM
#24
King of the Zebra Speedo
Obrien
It's like you can read minds!
-Red, a little weirded out...
That was a lot more ice than I was expecting.
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
01-22-2015, 05:56 AM
#25
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by SteveH
You probably don't want to hear this, but we've learned to not use so much ice.
X2
Ice in water very good....ice in three fingers, not so much.
01-22-2015, 10:40 AM
#26
2001 25' Safari
Ridgefield
Before leaving on trips, I fill a gallon size zip-lock freezer bag with ice cubes and put it in our AS freezer. I also fill four ice cube trays and put them in the freezer. The cubes in the trays are frozen by the time we leave on our trips. I use the cubes from the zip-lock bag and replenish as needed from the cubes in the trays. Then, I refill the trays and put them back in the freezer. By the time the bag needs replenished, the cubes in the trays are normally ready to go. Make sure the trays are refilled at the end of each day and you'll normally have a fresh supply of cubes every morning.
01-22-2015, 11:28 AM
#27
1973 31' Sovereign
Slidell
, Louisiana
[QUOTE=Cannonball;1569804]Yeti makes a bracket that you can insert into the slot on the edge and lock the cooler to something with a cable lock.
I will have to check into that for my new cooler.... The 'Coolest' cooler - 60 quarts of style with a built in blender, music and way, way more
Can't wait for it to ship! ...and I'll need the ice for the margaritas!
01-22-2015, 11:31 AM
#28
1973 31' Sovereign
Slidell
, Louisiana
[QUOTE=ROBERT CROSS;1571130]^
X2
Whiskey Stones.... no watering down the whiskey!
