Old 09-15-2008, 08:10 AM   #253
Alice&Billis's Avatar
2006 25' Safari
Tyler , Texas
Quarter Sheet Pans
In the commercial cooking world there are sheet pans, half sheet pans, and quarter sheet pans. I believe most of the quarter sheet pans are square or nearly square and will fit that 14 x 14 space in the ovens. Here is a link but just about any restaurant supply (online or in-store should have them.
Sheet Pan - Quarter-Sheet
Hope this helps.
Alice&Billis is offline   Reply With Quote
Old 09-15-2008, 08:33 AM   #254
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
This past weekend was the Southeast-end-of-summer Thang Rally and I baked a Key Lime pie in our convection microwave after we arrived and got set up. Of course I was up until after mid-night baking, but it was worth it. This is the second time I have used the oven myself. Both times the pies turned out great and I got lots of compliments. My wife uses the oven just about every trip to bake bread for breakfast.
Family of Disney Fanatics
WBCCI# 4821
Old 09-15-2008, 08:40 PM   #255
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Yes, it was
Originally Posted by Minnie's Mate View Post
. . . Of course I was up until after mid-night baking, but it was worth it. . . . .
I had to steal what little taste I got right off the pie plate from under Nvstysly. It was worth it indeed. MM, that's got to be your signature dish.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
Old 09-15-2008, 11:17 PM   #256
Jim J's Avatar
2014 30' Flying Cloud
Images: 117
We have the combination microwave and convection oven and use both features frequently to warm up, defrost, cook, finish cooking, or defrost food items.
Jim J is offline   Reply With Quote
Old 09-16-2008, 07:49 AM   #257
Ottawa , ON
Do those ovens bake, as in make cookies?
Old 09-16-2008, 08:12 AM   #258
1971 27' Overlander
Baton Rouge , Louisiana
Magic Chef saves the day
We were without power for 2 weeks after Hurricane Gustav toppled thousands of trees in Baton Rouge. Funny, you don't realize how many things you can't make without an oven till you don't have one. The 71 Overlander served as an emergency kitchen since the range in our house is all electric. We baked cornbread, biscuits and cupcakes to perfection!
I don't like to use the Magic Chef in the summer because it generates too much heat but I promise that I will never remove it!
drobertson17 is offline   Reply With Quote
Old 09-16-2008, 10:44 AM   #259
2006 30' Safari
Orlando , Florida
Thanks Sugarfoot. That's the only pastry I make and it is Becki's and my favorite desert so I've had a lot of practice over the last 20 + years.
I don't know about cookies, but my wife has made biscuits, casseroles, and "pigs-in-a-blanket" for breakfast on nearly every camping trip in ours.
You do need to compensate by reducing baking time by 25% or reduce baking temp by 25 degrees.
WBCCI# 4821
Old 09-16-2008, 10:53 AM   #260
1998 28' Excella
Dolores , Colorado
We use our oven quite often while we are out camping. The problem we have had is a constant heat. We solved that by putting 4 fire brick on the lower shelf and that gives the oven a constant heat and it works quite well. It does have a tendancy to "warm up" the trailer but we get through it with our Fantastic Fans.
Member Four Corners Unit.
dogpound is offline   Reply With Quote
Old 09-16-2008, 02:13 PM   #261
Ottawa , ON
Sounds like baking to a novice like me...!
Old 09-16-2008, 11:16 PM   #262
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
Rivet
Say Bob, on the fire brick, just curious if those are the 4" X 8" X 3" ones or another product of which I am unaware? As I mentioned before, the 12X12 tile I had in the oven for temp. control cracked in two by placing it on the shelf above the burner. Fire brick would eliminate that for sure. Also, what configuration have you found best?
Thanks, sue
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 09-19-2008, 06:36 AM   #263
SteveH's Avatar
Common Sense , Texas
We do use our oven, but not for anything exotic...mostly things like baked potatoes for dinner and bisquits for breakfast. (Just love eggs, bacon, and bisquits for breakfast, and no, my colesterol is not high) We use the microwave for heating drinks and thawing frozen foods.
Regards,
Steve
Old 09-19-2008, 07:14 AM   #264
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Occasionally
We used it at the Texas Unit 50th Anniversary Rally last weekend. It gets used about once or twice a year and is a storage cubby the rest of the time for the toaster, frying pan, and crockpot.
I carry some silicone muffin pans and make cornbread or dessert muffins occasionally. Last weekend, we reheated a casserole.
John W. Irwin
WBCCI #9632
Old 09-19-2008, 07:39 AM   #265
1998 28' Excella
Dolores , Colorado
Sue; The fire brick are about 1 1/4" thick. They are more like a paver brick. We bought them at a True Value store locally.
Old 09-19-2008, 07:55 PM   #266
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Thanks for your reply and pm about the fire brick Bob. I'll have to check that out.
sue
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
oven out 74Sovereign Stoves, Ovens & Microwaves 19 12-10-2003 06:03 AM
Oven Thermostat PeterH-Airstreamer Stoves, Ovens & Microwaves 33 02-20-2003 09:39 AM
Antenna & Oven Difficulties Tamara General Repair Forum 13 07-30-2002 04:33 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
No Buns in this Oven NSMITH Stoves, Ovens & Microwaves 2 06-03-2002 07:54 PM
