11-05-2008, 09:03 AM
#281
1961 22' Safari
Union
, Oregon
What is life without an oven?
I have two propane ovens and I take one with me everywhere I go. I use a 1961 Safari to carry one of them and a 1949 Boles Aero to carry the other.
Sam
11-05-2008, 09:29 AM
#282
1999 34' Limited
Darien
, Wisconsin
When we ordered our 34 footer we specifically ordered it without the oven. The convection]micro combination unit does everything we want. Having the extra storage space is really nice, when we order another new one in a year or two it will be set up the same way.
1999 Airstream 34' Limited (The Cottage)
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
11-05-2008, 09:41 AM
#283
Pleasanton
We use our oven every trip, it is tradition to bake fresh cinnamon rolls at least once during the trip
______________________________________
Scott
2020 Caravel 19CB - "The Silver Pearl"
2028 Ford Expedition
11-05-2008, 02:45 PM
#284
1975 27' Overlander
Longview
I wouldn't know what to do without the oven when I'm at the deer lease.
- 06 F-250 4x4
- 80 FLH HD (restored)
- 75 Overlander (27 ft.)
- 1959 Ford 661 tractor (full restoration)
11-05-2008, 06:01 PM
#285
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Two minutes into a frozen pizza right now. After years in the Trade Wind where the oven didn't work, I'm thrilled to have one that works well.
Vaughan
11-05-2008, 06:12 PM
#286
1997 34' Limited
Charlottetown
, Canada
when buying our AS it did not have an oven...just the confection. I had them put one in...... great when boondocking or those cold stops in the middle of no where on route to sunny weather from the cold north.
11-13-2008, 05:52 PM
#287
1978 24' Argosy 24
Woodinville
Be aware of CO poisoning
Just a quick reminder that ovens should never be used to heat the trailer. Ovens are a major culprit in carbon monoxide production; especially when starting. The reason is the oven flame touches the heat spreader which results in incomplete combustion. This is one good reason you should never cook with the flames touching or coming up the sides of a pan .
As we're getting into the colder time of the year and more likely to be camping inside with the windows closed and running the gas heat consider investing in a good carbon monoxide detector. Inexpensive battery powered detectors that give a visual readout from 10-999 PPM are cheap now and very reliable (~$50). For a little over $130 you can get a low level monitor (CO Experts) that will sound a audible alarm at ~30 PPM. Haven't tested one yet but the DuPont 828 appears to be an import version of the FireAngel 828 build to european spec EN 50291:2001 which is far more stringent than the UL 2034 spec or CSA 6.19 (a little better) which don't require an audible warning until it's a 911 call .
11-16-2008, 09:59 AM
#288
2008 20' Safari SE
Colorado Springs
Fresh Apple Pie
Several years ago my wife and I were tent camping while waiting to close on a house. We ran accross some friends from Texas who were visiting family in Colorado Springs and staying in the same campground in their Airstream. One afternoon Mrs. Tilley broght down an Apple pie that she had baked in her oven.
After that apple pie, there was never any question for me......and my wife makes a fresh pie every time we take our Airstream out!
11-16-2008, 10:34 AM
#289
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
You are one Happy Streamer I bet!!!
12-01-2008, 03:28 AM
#290
Eau Claire
, Wisconsin
I tried baking cookies in my magic chef oven tonight but they got burned on the bottom and not cooked on top. These were not real cookies...just the frozen kind from the store. What am I doing wrong? Do I need one of those stones?
12-01-2008, 07:42 AM
#291
1972 25' Tradewind
North Vancouver
, British Columbia
I would try putting a pizza stone in the oven to help distribute the heat more evenly. I put mine on the metal shelf above the burner. Also, pick up an oven thermometer so you can confirm the temperature is where it is supposed to be.
North Vancouver, BC
12-01-2008, 08:49 AM
#292
Contributing Member
Austin (Hays County)
I found that a shiny metal sheet placed below the item being baked prevents burning about as well as a stone and is a lot smaller and lighter to store. I found the sheet I use in a kitchen department.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
01-09-2010, 09:29 AM
#293
1967 26' Overlander
Huntsville
, Alabama
Whether it needs it or not
Way back in Post #137, I posted a picture of my dirty oven which was later quoted in another post to help explain how the broiler works in a gas oven.
In Post #172, another member took the opportunity to show off his clean oven, and it made me feel kinda bad. But I was able to shake it off without doing anything.
The mothership recently posted a lot of documentation on their website dealing specifically with vintage Airstreams. Would you believe the cleaning interval on the old Magic Chef ovens is every seven years?
While the consequences didn't appear to be as severe as those associated with neglecting running gear balance, I was moved enough that the oven was warmed up last night, and then sprayed with E-Z Off. This morning, in 18 degree weather, most of a seven year buildup was removed. Although the E-Z Off had done its job, wiping the grime out was kind of tough because the rinse water kept freezing to the oven walls.
But it was worth it - I'm now good for another seven years.
Tom
01-09-2010, 10:02 AM
#294
1999 23' Safari
Perrysburg
, Ann Arbor
Congrats on the Cleanup ...
but my experience is that as soon as I expend lots of elbow grease on something like this (especiallly in very cold or very hot weather), it immediately fails in some non-repairable way and requires replacement. I think it's some corollary to Murpy's law that it be so.
01-09-2010, 01:42 PM
#295
1976 Argosy 24
Joplin
, Missouri
Probably a lower oven temperature, it may be heating hotter than the dial says. Crank it down about 25 degrees. And maybe move the rack one notch higher.
01-09-2010, 01:58 PM
#296
1964 22' Safari
Eagle River
, Alaska
Thanks for cleaning it!
Tom,
Thanks for cleaning that unsightly mess. Really, it looks great and if you hadn't cleaned it I would never have come across the AS documentation link.
There's some great stuff there! Mrs Safari64 says I've already spent 3+ hours going through it.
Oh, and 18 degrees?!? Warm spell, eh? It will have to warm up from -23F before I can clean mine.
What are you going to bake first?
Thanks for the info
Safari64
01-09-2010, 02:04 PM
#297
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
DW tip after I burnt the cr@p out of her special anniversary frozen toll house treats...don't put 'em on the cookie sheet frozen, don't preheat the oven, put a second sheet on the rack below and keep an eye on the damn things. Pass the Chip's Ahoy.
01-09-2010, 02:07 PM
#298
1974 Argosy 24
Science Hill
, Kentucky
we have never used our oven.....we had our other sob and never even turned it on....so when we redid the inside of our 1974 Argosy we pulled out the oven....and installed a micro/convection oven.
Kevin & Monique
New to A/S---Not to Honey Do's
Sweetie (lab) Snickers (lab) Blackie(lab)
Dotz(daschund) CB (daschund) Oh and 3 kids!!!
TAC# KY-3
01-09-2010, 02:41 PM
#299
2008 25' Safari FB SE
Land of fruits and nuts
I use mine all the time. And, after perusing this thread, I finally understand how to correctly broil something in it.
01-09-2010, 03:25 PM
#300
Master of Universe
Grand Junction
The chief use of our oven is to make garlic bread. That alone makes it worth while. Note this is not baking bread, but making garlic bread.
What else is nice, it works when boondocking and there are other uses for it.
Gene
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
oven out
74Sovereign |
Stoves, Ovens & Microwaves |
19 |
12-10-2003 06:03 AM |
Oven Thermostat
PeterH-350LE |
33 |
02-20-2003 09:39 AM |
Antenna & Oven Difficulties
Tamara |
General Repair Forum |
13 |
07-30-2002 04:33 PM |
Oven gas line broken
lbrodsky |
LP Gas, Piping, Tanks & Regulators |
4 |
07-23-2002 03:52 AM |
No Buns in this Oven
NSMITH |
2 |
06-03-2002 07:54 PM |
