Old 07-02-2016, 11:21 AM   #29
Long Island , New York
. . . and never scour the pan out with anything abrasive like brillo, etc.. Not even a rough scrub sponge IMO.
The best and oldest cast iron pans, the really used old ones, actually have a very thin layer of food coating the cast iron, which is baked on and in essence inert at this point.
"Seasoning" a new pan with oil simply starts a life-long process of coating the pan with a layer of oil/food on the microscopic level.
The pan should be hot with oil/butter before adding any food to it. Putting cold ingredients into a cold pan is a recipe for everything to stick together and make a real mess . . .
Have fun cooking!
Peter
PS -- The cast iron thread linked earlier has lots of hints like this in it:
http://www.airforums.com/forums/f484...ing-64047.html
There is also a Lodge skillet thread I forgot to link earlier:
http://www.airforums.com/forums/f484...et-145509.html
Old 07-02-2016, 03:44 PM   #30
cameront120's Avatar
1972 25' Tradewind
If you haven't found it yet, check out Jeffrey Rogers YouTube channel. He's a cast iron collector and cook who shares loads of great info.
https://www.youtube.com/channel/UCpD...pjAjdpqA5x6K6Q
North Vancouver, BC
Old 07-02-2016, 11:22 PM   #31
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Originally Posted by cameront120 View Post
I suspect that's because it's an eight year old thread!
Let's get things back on track.
Mmmm, bacon
bhayden is offline   Reply With Quote
Old 07-03-2016, 04:59 AM   #32
Putting the tow vehicle into the gear of Pork right now!
Old 07-03-2016, 08:08 AM   #33
1968 26' Overlander
Manheim , Pennsylvania
Flax Seed Oil
We recently picked up a new vintage cast iron and I did a Google search to figure out how the best way to get an a good hard finish on it. This article showed that Flax Seed oil is the best, but it is a process! Best suited for a cold winter day when you don't want to cook yourself out of the kitchen... I figured if I was doing one, I was doing them all at the same time!
https://www.cooksillustrated.com/how...ason-cast-iron
In summary, run your cast iron through the ovens Clean Cycle to burn off all of the old seasoning first! Let it cool for a day and scour it thoroughly. Then warm the pan, apply a very thin coat of good quality Flax seed oil, and put it upside down in a cool oven set to heat to 450-500 degrees. Cook for an hour after it preheats. Let it cool a few hours in the oven... Repeat five more times! Like I said, it is a process but it leaves a hard black surface that cleans off VERY easy.
SonOfAnder
'68 Overlander
http://www.airforums.com/forums/f44/...te-145553.html
SonOfAnder is offline   Reply With Quote
1958 Cast Iron P-trap replacement robandzoe Waste Systems, Tanks & Totes 45 12-20-2007 01:34 PM
Cast Aluminum Tailights ROBERTSUNRUS Lights - Interior & Exterior 8 01-28-2007 04:45 PM
chip in cast iron sink Dwight Cabinets, Counter Tops & Furnishings 0 06-28-2004 12:10 PM
Right cast iron manifold free Astrodokk Airstream Motorhome Forums 1 10-19-2003 09:04 PM
Stove top Black Cast Iron to go above eye tmeagle1 Stoves, Ovens & Microwaves 1 02-27-2003 10:49 PM
