Old 03-25-2008, 08:01 PM   #15
buckmaster's Avatar
1965 20' Globetrotter
1970 31' Sovereign
1972 25' Tradewind
Newport , Oregon
I have been dutch oven cooking for groups for a long time. I do not think there is a trick . What I do is wash a used oven with water only,( Never use dish soap) then heat it to dry all the moister then give it a quick spray with cooking oil. When oven is cool wipe out excess oil and store in a dry place until the next meal. This is just regular use and care for cast iron no big deal. over time the Iron will become very well seasoned and cook wonderful.
Bacon has to much sugar which burns it also will go rancid in a short storage time.
The main thing is to use it love it and eat well.
buckmaster is offline   Reply With Quote
Old 03-25-2008, 08:29 PM   #16
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Seasoning and Caring for cast iron cookware
This is the best that I have seen. I used this on my new cast iron and it worked perfectly.
Living life on the Road
deauxrite is offline   Reply With Quote
Old 03-26-2008, 06:06 AM   #17
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
When barbequeing outdoors on charcoal once the food comes off is a good time to season a pan...
Old 03-26-2008, 12:09 PM   #18
Jimandrod's Avatar
2008 28' Safari SE
Placitas , New Mexico
... another vote for frequent use and an occasional pound of bacon.
Never use soap
Never soak for long periods
Always wipe immediately, add a thin coat of oil, warm the pan slightly and wipe out any excess oil, store in a dry place
Jimandrod is offline   Reply With Quote
Old 03-26-2008, 01:38 PM   #19
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
We have a large collection of inherited cast iron for use on the wood stove (old Lange). Mmmm, Bacon. Yessss! If you're using oil try peanut oil as it has a much higher burn temperature than regular vegetable oil. If you can't tolerate the taste in a certain dish then canola (aka rapeseed) is next best.
Using a little (very little) soap on well seasoned cast iron is OK if reallly necessary but keep away from detergent. However, if it's really been screwed up you can "start over" with detergent and a run through the dishwasher. Just pull it out before the dry cycle or it might rust. If it's rusted you're down to bead blasting.... I'd fry a LOT of bacon before resorting to any of these methods though :+)
bhayden is offline   Reply With Quote
Old 03-26-2008, 01:42 PM   #20
DFord79's Avatar
Yakima , Washington
Lodge Manufacturing
Here is the instructions from LODGE CAST IRON COOKWARE. LODGE by the way is the accepted "airstream" of cookware if I may. It is the oldest, best selling cast iron in the business. I think they probably know best. It sure works for me.
DFord79 is offline   Reply With Quote
Old 03-26-2008, 01:59 PM   #21
Jimandrod's Avatar
2008 28' Safari SE
Originally Posted by DFord79
Lodge Manufacturing
Yup - this is THE definative way to season cast iron. I was looking for this on the Lodge web site but all I came up with was the use and care for Lodge Logic pre-seasoned cookware.
Old 07-01-2016, 09:24 AM   #22
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Seasoning Cast Iron
Greetings Stef. This appearance you spoke of on your cast iron is caused by NOT wiping the excess oil off before seasoning. A short outline of what I do is. Use virgin oil, preferably the FlaxSeed oil, as it has one of the highest smoke temp range. After cleaning the CI skillet (E-Tank, etc) I bake the CI in the oven for a few minutes, first to drive off all moisture then coat it lightly with virgin FlaxSeed oil. Thren take a drier cloth and wipe it dry again. (there will be oil on it, you just don't need to see it dripping or wet) Place in the top rack in the oven upside down. The lower rack, place a sheet of aluminum shiny side up. Turn on Oven to 300F for 30 minutes, then up the oven temp by 50 F for each 30 minutes..Finally at 450F to 500F, leave it for 2 hours..Turn off, and allow it to cool naturally for atleast 2 hours before removing. Many purist tht I know, will repeat this process 5 or 6 times to get that proper seasoning. First cook off use bacon. Nothing better~!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-01-2016, 11:22 PM   #23
bhayden's Avatar
1978 24' Argosy 24
I noticed the Lodge link no longer works. But you can go to this page and skip down to Refurbish Your Finish.
One thing I've found recently is that when I have some really stuck on gunk, like seems to happen with breakfast sausage, letting it soak with white vinegar or adding just a splash of vinegar to some water seems to do the trick. I'll caution that our cast iron is very old and has a base seasoning layer that's been built up over decades of use.
Lodge has been around for 120 years. But Wagner Ware had a small head start. They used to dominate the market and Wagner Ware Sidney accounts for about 1/2 of our collection.
Recently I've started using Avocado oil for cooking and have been very pleased.
Old 07-01-2016, 11:28 PM   #24
cameront120's Avatar
1972 25' Tradewind
I suspect that's because it's an eight year old thread!
North Vancouver, BC
Old 07-02-2016, 02:06 AM   #25
Long Island , New York
Ditto.
Here are the Lodge instructions:
https://www.lodgemfg.com/use-and-car...e-and-care.asp
FYI also -- a couple of newer threads about cast iron etc.:
http://www.airforums.com/forums/f484...ing-64047.html
http://www.airforums.com/forums/f484...ing-40090.html
Old 07-02-2016, 07:37 AM   #26
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Stef, thanks for starting this thread. I've always wanted a cast iron skillet but never wanted to end up not using it because I could not season it properly.
Now I will try it.
Dingo Girl is offline   Reply With Quote
Old 07-02-2016, 09:41 AM   #27
Tin Man
LY007's Avatar
1983 27' Excella
Charlottesville , Virginia
My wife is a great cook, shops at four or five different grocery stores every week.
She swears that her $20 Lodge iron skillet is her best piece of cookware. She never puts soap on it; just wipes it thoroughly with paper towels and rinses it.
That skillet has made a lot of yummy stuff.
LY007 is offline   Reply With Quote
Old 07-02-2016, 10:48 AM   #28
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Bake corn bread in the skillet 'bout 100 batches should do it.
Gearheart is offline   Reply With Quote
1958 Cast Iron P-trap replacement robandzoe Waste Systems, Tanks & Totes 45 12-20-2007 01:34 PM
Cast Aluminum Tailights ROBERTSUNRUS Lights - Interior & Exterior 8 01-28-2007 04:45 PM
chip in cast iron sink Dwight Cabinets, Counter Tops & Furnishings 0 06-28-2004 12:10 PM
Right cast iron manifold free Astrodokk Airstream Motorhome Forums 1 10-19-2003 09:04 PM
Stove top Black Cast Iron to go above eye tmeagle1 Stoves, Ovens & Microwaves 1 02-27-2003 10:49 PM
