Old 10-18-2014, 08:14 AM   #281
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by Panama Red View Post
Should the quest for perfect coffee ever end? Say you're lying (laying?) on your deathbed, and someone brings in a cup of coffee from a percolator, and having never tried it, you find it to be the absolute best coffee ever. Now, you missed out your whole life! Don't you feel terrible? Yes, I think you do...
-Red, not a percolator fan...
If perk coffee was my only choice, I would have to pass.
Bob Martel
WBCCI# 5766
Old 10-18-2014, 08:19 AM   #282
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Do we really need a perfect cup of coffee, how about a good cup of coffee.
Doug and Cheryl
Old 10-18-2014, 08:19 AM   #283
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I'm surprised by the number of instant coffee people on here. I understand it's ease of use attraction, but, unless it's changed tremendously since last time I tried it, as you with perk, I'll also have to pass...
-Red, starting the instant coffee argument...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 10-18-2014, 08:20 AM   #284
Panama Red's Avatar
Obrien , Florida
Blasphemy...
-Red, on a holy quest...
Old 10-18-2014, 04:29 PM   #285
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Blasphemy...
Alumalina next spring, Cowboy coffee over the campfire in my 11qt boiler. Bring your best mug.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-19-2014, 07:23 AM   #286
urnmor's Avatar
Berlin , Maryland
The search for the perfect cup of coffee is like searching for the Holy Grail. It will always go on and may never be found but the search is addicting. So the latest answer to the perfect cup of coffee is Bulletproof coffee. It is "upgraded coffee," blended with Brain Octane Oil (MTC oil) and unsalted grass-fed butter or ghee. This coffee is supposed to give you clear, focused energy and keep you feeling full. Some studies have even suggested that it aids in weight loss.
Clearly that is getting close of course i have not tried it yet.
urnmor is offline   Reply With Quote
Old 10-19-2014, 10:36 AM   #287
2013 25' FB Flying Cloud
Danville , Indiana
This is a great thread. Coffee is a vital topic to cover on an RVing forum. Iím pretty sure that the definition of ďcampingĒ requires the drinking of coffee in the morning, no matter how itís made. You ainít camping if you donít drink coffee.
To my way of thinking, the best java is made with a French press. The method (involving a plunger with a wire or nylon mesh filter) allows some dissolved solids from the coffee grounds to pass through the filter and end up in your coffee mug. This results in a coffee with substance to it: itís real coffee, not just brown water. Some object to the bit of sludge that sits in the bottom of the coffee mug, but thatís more of an aesthetic complaint, not a complaint about the coffee itself.
Admittedly, using a French press might be a little more work than the typical drip method of brewing coffee in that the used grounds arenít conveniently wrapped up in a paper filter ready for discarding, but shaking out the used grounds into a trash can and wiping out the pot isnít particularly difficult to do.
Don
donreitz is offline   Reply With Quote
Old 10-19-2014, 11:10 AM   #288
2011 23' Flying Cloud
Durango , Colorado
Originally Posted by Ahab View Post
Too hard to clean? You dump the grounds in the waste basket and wipe it with a paper towel. Whats so hard about that?
I wash my french press with soapy water and dump grounds and soapy water into the toilet. Added benefit - the suds are the last to come out of my sewer hose, and it is clean after 288 mornings over 3 years. No odor, and never use black tank chemicals. Of course, I only use French Market Dark Roast😊
JamuJoe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 10-19-2014, 04:03 PM   #289
Chelsea , Michigan
Images: 12
Nothing better than French Roast/French Press coffee!
Bob Martel
WBCCI# 5766
Old 10-19-2014, 04:42 PM   #290
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
I've probably posted in this thread, but here goes... The gospel according to Drathaar!
I use a Melita #6 cone filter that fits into the neck of a Stanely thermos. We use good French roast. The grounds are easy to deal with, and the coffee is truly great!
Old 10-20-2014, 02:39 PM   #291
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
It's all about perspective. When I'm at home, my coffee is done with exact measurements, on the proper grind setting, with the proper sitting time. When I'm waking up in the Airstream and tired from miles of hiking or gallons of drinking the day prior (or both), coffee is coffee. We have instant for when we are really tired or lazy, and we have a classic blue percolator that works just fine. Tastes "good" even with some grounds in there. When I go backpacking, I'm happy just to have the water hot enough to dissolve the instant coffee.
So to answer the original question of the thread? I looked into propane powered coffeemakers, and considering spending much $$$ on something fancier, and ended up with a pot for boiling water and a $20 percolator.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 10-20-2014, 04:15 PM   #292
LandSailor's Avatar
2015 27' FB International
Portland , Oregon
We use a Bialetti Moka Pot (comes in various sizes). Easy to use, easy to clean and great espresso type coffee. I also use a Nespresso Aeroccino Plus milk frother - yes it's electric and a bit spendy, but does a great job heating and frothing very quickly (550 watt draw). Favorite coffee is Caravan (Portland, OR), not only because my Kiwi husband calls our AS a caravan, but because it's really good and always fresh, fresh, fresh. A fun video on the Bialetti can be found on the Long Long Honeymoon site. Always great to start the day with a good hot cup of coffee. Cheers!
Ellen & John (Kiwi)
Gemma (Golden), Blue (Aussie) & Basil (African Grey)
Cruising the highways and byways with Silver Fern when not on the water.
LandSailor is offline   Reply With Quote
Old 10-20-2014, 04:22 PM   #293
Smokeydog's Avatar
Gonzalez , Florida
I've spent my time looking for the perfect coffee cup. Today I'm using a Nissan ultra. It's more of a desk type, not really good for travel.
1978 28.5 Avion Model M
2010 Tundra XSP
Hensley arrow
Pensacola, Fla.
Go Noles!
Smokeydog is offline   Reply With Quote
Old 10-20-2014, 04:39 PM   #294
dkottum's Avatar
This morning camped in Tennessee we were out of Chemex filters so pulled out two handy Folgers singles coffee bags. Not bad at all.
Do you have a backup plan?
Doug and Cheryl
1976 Airstream Argosy RV Trailer 26 Foot, Very Good Con eBay Watch Airstreams on eBay 0 06-15-2011 08:00 AM
1976 Airstream Argosy RV Trailer 26 Foot, Very Good Con eBay Watch Airstreams on eBay 0 05-26-2011 01:10 PM
1976 Airstream Argosy RV Trailer 26 Foot, Very Good Con eBay Watch Airstreams on eBay 0 05-22-2011 02:50 PM
1986 Airstream travel trailer rv 28 foot GOOD CONDITION eBay Watch Airstreams on eBay 0 05-17-2011 03:30 PM
Airstream Caravel Concession Trailer Mobile Coffee Shop eBay Watch Airstreams on eBay 0 03-19-2011 06:40 PM
