Old 08-15-2016, 12:46 PM   #1
2016 23' Flying Cloud
Milwaukie , Oregon
Frying bacon triggers smoke alarm - what the....
Yesterday morning, relaxing in our 23' Flying Cloud on a misty morning on the Longbeach Peninsula, WA., I was frying bacon on the stove - one burner lit, vent fan on (vent fan open too), med. heat, 4 strips, not a big deal, and the smoke alarm goes off. Holy cow it's loud! We finally yanked the battery out of it (and later put it back in). There was no smoke. We opened the door and started the ceiling vent. Has this happened to anyone else? Is the stove vent not up to the task? If it's cold and rainy outside, do I still need to open doors and vents to cook? Thank you for any tips.
Mike
Horsfall is offline   Reply With Quote
Old 08-15-2016, 01:02 PM   #2
Long Island , New York
Welcome to the forum! Sorry you had to endure this, but IMO the new generation of smoke alarms is ultra-sensitive and unpredictable. I think you did the best you could, and may have answered your own question. Next time, try opening the roof vent closest to the bacon, and put the fan on low, making sure an upwind window or door is cracked open.
At home we have had to come up with lots of work-arounds like this for new smoke detectors installed after a renovation. A pain in the neck but the life you save may be your own.
How have you liked the new trailer otherwise?
Cheers,
Peter
PS -- It is possible that the invisible "smoke" included some burn-off from the cooktop's griddle and other related metal work -- of factory oil etc. applied to prevent rusting. Ditto for a new cast iron pan if you used one. Our dealer mentioned running the oven for an hour to burn it off similarly, but not sure if you have a propane oven.
Old 08-15-2016, 01:25 PM   #3
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
There was some previous of bacon inside setting off the alarm.
The answers ranged from taking the battery out for that use only, putting a plastic shower cap on it and what, you cook bacon inside?
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-15-2016, 01:37 PM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
This was a real problem for us, with anything on the stove. At first I just pulled the battery. Then I moved the smoke detector to the other end of the trailer. Now all is well.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-15-2016, 01:46 PM   #5
Goal15's Avatar
Dallas , Texas
Unfortunately it's not just bacon.... it's impossible to even make toast inside our 23. We use the shower cap solution..... actually any plastic bag that you can put over the smoke alarm. others have suggested hitting the quiet button before making the toast.
My best solution.... making toast outside. i kind of like making toast and coffee outside in the morning...just have to do my best to not wake my spouse with all my clattering around
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 08-15-2016, 01:54 PM   #6
2002 19' Bambi
Lafayette , California
When it was new, our 19' had the smoke alarm essentially above the stove and anything would set it off. The alarm now resides over the bed and no further problems. It isn't as if real smoke from a fire would have far to go to get to where the alarm has been now for years.
Tim
Tim A. is offline   Reply With Quote
Old 08-15-2016, 02:36 PM   #7
Milwaukie , Oregon
Thanks guys! I'll try moving it, or temporarily masking it, that is if I don't fry the bacon outside. It was cold.... I know, don't be such a glamper. Appreciate the feedback. MH
Old 08-15-2016, 02:56 PM   #8
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
The smoke alarm going off while making toast appears to be somewhat of an Airstream tradition.
Cheers,
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 08-15-2016, 03:23 PM   #9
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
So this might not apply to your specific model or year, but I discovered last summer (after only owning ours 6 years) that the ventline exhaust thingy outside the trailer has two little tabs that lock the flapper in place. Unless those tabs are turned out to allow the flapper to open, the exhaust hood inside the galley does essentially nothing other than make noise.
I think I might have actually been able to upload a photo!!! If so, on the left you can see one of the two tabs locking down the flapper.
teagues is offline   Reply With Quote
Old 08-15-2016, 03:49 PM   #10
Good point teagues, I missed that also when we got our new trailer recently.
Peter
Old 08-15-2016, 04:02 PM   #11
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Issue discussed prior. Suggestions included replacing with dual detection type smoke detector. More expensive, but not over the top.
The smoke detector issue came up yesterday. A group of WBCCI rally attendees were sitting around at happy hour when the smoke detector went off in the trailer we were siting behind. The oven was heating a the main dish for the pot luck dinner. So even seasoned AS folks struggle with this problem. We just reach up and touch the button on the unit and turn on more vent fans. Someday we'll get around to trying a different detector.
Good luck with yours. Pat
Old 08-15-2016, 04:18 PM   #12
FYI here are the search results for "smoke alarm"
https://cse.google.com/cse?cx=011403...arm&gsc.page=1
which include this recent thread when you add "bacon" to the search terms:
http://www.airforums.com/forums/f44/...nt-144540.html
As the ad for dog treats says, " I'm bacon ya' ! "
Old 08-15-2016, 06:47 PM   #13
Milwaukie , Oregon
Stove vent
Thanks for the tip. I did check that, and sure enough, it was open. Easy to forget that one, though. MH
Old 08-15-2016, 07:12 PM   #14
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
An Airstream is just like any tin can that must have air egress if one wants air to exit. Long way of saying that if you open a window a bit, all should be ok. Worked for me, but who knows? Jim
Jim Flower is offline   Reply With Quote
Smoke, Smoke Everywhere ncbambi 2008 Safari SE 14 07-25-2010 06:28 PM
Smoke alarm keeps 'alarming'... TennisMan 2007 Safari SE 25 05-03-2009 08:51 PM
Smoke Alarm? gaylejoe General Interior Topics 9 06-02-2008 12:06 PM
Furnace sets off smoke alarm silverback 2002 - 2005 International 37 11-12-2006 08:24 PM
smoke alarm frederic.c01 Interior Restoration Forum 9 08-06-2004 10:39 PM
