Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
View Poll Results: How do you cook outside?
Campfire 54 19.57%
Charcoal with starter fluid 54 19.57%
Charcoal with chimney starter 32 11.59%
Propane grill 171 61.96%
Electric grill 10 3.62%
Solar oven 4 1.45%
Other - please describe 18 6.52%
Multiple Choice Poll. Voters: 276. You may not vote on this poll
Old 06-01-2004, 05:01 PM   #1
Edie's Avatar
Profile:  Dallas , Texas
Cooking Outside
Originally Posted by silver suz
Edie, would you set up a poll on outdoor cooking? How many use. campfire, charcoal with fire starter fluid, charcoal with chimney starter, propane grill, electric grill (and solar oven? or would I be the only one?? and how often for each. I am trying to find out how prevelant the charcoal fire starter is used by campers as the smell of this fluid knocks me out cold -like running into a glass wall. But others might find the results interesting too. By the way, parts of CA have banned charcoal fire starter from use as it is too toxic.
Thanks very much, Silver suz.
I received this message, so here it is.
Edie
Edie is offline   Reply With Quote
Old 06-01-2004, 05:06 PM   #2
Edie's Avatar
Now that I voted, I should explain the "Other" methods we use. We have used a wok, crock pot, hot plate, and Geo. Foreman grill to cook outside when using our MH.
Way in the past we used a campfire, but in Florida campfires are frequently prohibited.
Edie
Old 06-01-2004, 05:06 PM   #3
andyfuson's Avatar
Profile:  2004 25' International CCD
Stone Mountain , Georgia
I almost always cook outside at least once with Charcoal. I buy Match light so that I don't need the fluid. Usually. I keep a bottle on hand just in case. It makes campfires real easy to start as well. I just make sure nobody is looking.
andyfuson is offline   Reply With Quote
Old 06-01-2004, 05:29 PM   #4
Profile:
Send a message via Yahoo to silver suz
I use a little stove that has a 1 D cell battery and runs on anything-pine cones, leaves etc. I also use a solar oven on sunny days- nice to have the meal cooked and ready to eat when you get back at the end of the day. silver suz P.S. Andyfuson, nobody has to be "looking" to "smell" the charcoal fire starter. It's toxic stuff.
silver suz is offline   Reply With Quote
Old 06-01-2004, 07:55 PM   #5
andyfuson's Avatar
BUSTED
Old 06-02-2004, 07:58 AM   #6
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
forty years ago was my initiation to charcoal starter..i learned the hardway to allow time for the starter to burn off...that steak tasted like ****....im sure today in this politically correct world, that our wonderful EPA has mandated what can be used in the formulation. i have used all the methods to start a charcoal fire...although i like the chimney method, its just another piece of stuff to drag along and take up room. i dont see any advantage to matchlight, other then lining the manufacturers pocket with my money.
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 06-02-2004, 11:01 AM   #7
Profile:
The one thing I have when camping is time. So we use the grill rather a lot. And I like charcoal, which takes even more time. A chimney is too much to store, and lighter fluid is smelly, messy, and far to volatile to carry on board. So I use those compressed sawdust/wax fire starters. It takes longer, but hey, I've got the time!
Mark
Old 06-02-2004, 12:08 PM   #8
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Never use starter
You don't need to use charcoal starter. Use an ounce of corn oil on a piece of crumbed up newspaper or paper towel for the purist in a fire starter, which is easy to make from a coffee can. The best steaks are cooked right on the coals of a burnt down "wood" fire or real charcoal (not kingsford ) fire. The real stuff burns hotter and has real favor, no wax or limestone.
And grilling and B B Q are not the same thing.....
SOFI Member
Over59 is offline   Reply With Quote
Old 06-02-2004, 12:57 PM   #9
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Oh, boy! I can't wait to read the fall out (er, discussion) about that! So, who grills and who barbecues and what's the difference? I'm always ready to learn something new on this forum
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 06-02-2004, 02:48 PM   #10
norbert's Avatar
Images: 24
yes psychy....i do know the difference, so.......
HUSH PUPPY
norby
Old 06-02-2004, 03:06 PM   #11
andyfuson's Avatar
I'm actually surprised to see that propane is winning the vote. We airsteamers are just too fancy I guess.
Old 06-02-2004, 03:52 PM   #12
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Exclamation
What no one uses an electric grill? I chose other, we use several different methods depending on what is being cooked. We cook with charcoal, started with a chimney, we cook on a campfire, using grills and dutch ovens. I also have a small propane grill that we will use under the awning if the weather is to crappy to cook over the open fire. We also use crockpots, electric griddles, microwaves and manifolds BTW barbque is hand pulled, vinger based rubbed spiced, pork. With hushpuppies!
Aaron
WBCCI #2449 AIR #2495
Old 06-02-2004, 07:13 PM   #13
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Mae West said she made a campfire by rubbing two boy scouts together...
(for those of you under 60, Mae West was a movie star in the mid twentieth century, whose physical attributes caused, among other things, the nicknaming of inflatable life jackets Mae West's)
(No Longer at Inland RV)
Old 06-03-2004, 08:45 PM   #14
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
Mid twentieth Century?
Wasn't she done with her movie career before WWII? She was a very old lady who made cameo one-liner joke appearances on tv variety shows by the mid Twentieth century.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Cooking Pots John Stella's Kitchen 51 03-18-2008 11:57 PM
Thinking about replacing oven with microwave Stefrobrts Stoves, Ovens & Microwaves 36 01-15-2006 11:02 AM
Recipies Edie Off Topic Forum 25 05-29-2004 07:55 PM
